From silverlight to flex
Sep 1, 2009 2:40 PM
Hi
I'm an moderately experienced Silverlight programmer and I'm just starting with Flex. I'm beggining to understand the language but I'm running at problems trying to accomplish similar tasks in Flex.
1) Flex can declare a variable as type Function but can it declare a variable as a specific function? (i.e. a C# delegate)
For example
Is the following possible where SomeFunction is defined elsewhere? If so how is SomeFunction defined.
var value:SomeFunction;
2) I understand the syntax "var value:*" but what is the name for this type of declaration?
3) Does Flex support abstract classes? Does Flex support abstract methods?
4) Does Flex support reflection (i.e. querying an object type definition)? If so how does this work?
5) Is it possible to convert value in "var value:*" to a string for debugging (i.e. dump the properties and their values to the trace command)?
    Sep 2, 2009 7:38 AM   in reply to bk843746
    Hi
    For example
    Do you mean this:
    var traceParameter:Function = function (aParam:String)
        trace(aParam);
    traceParameter("hello"); // hello
    or
    function traceParameter(aParam:String)
         trace(aParam);
    var otherFunction:Function = traceParameter;
    you can find more in the flex help under Functions
    I'm not quite sure about this one but I just simple call it * type(very creative )
    No, it doesn't support abstract classes... but there is some sort of workaround, in your "Abstract" Class create the methods and in each abstract method just thorw an Error indicating that this method has to be overriden
    Yes, look in the help for getDefinitionByName and getQualifiedClassName... here is a Sample to dinamically create a class
    var ClassReference:Class = getDefinitionByName(getQualifiedClassName(entity)) as Class;
    var tmpClass:* = new ClassReference();
    you can also get the class attributes by calling
    describeType() wich returns a XML with the class definition or calling ObjectUtil.getClassInfo
    also, you can use a string to query an object lets say, person["name"] is the same of using person.name, it is pretty dynamic but not recomended for performance and code bad practice reasons...
    I haven't tested this one but you could cast the object to String -> String(value) or try the toString method
    Hope some of this can be usefull
    Gus
