Revision: 9948
Author: rfrishbe@adobe.com
Date: 2009-09-02 19:44:59 -0700 (Wed, 02 Sep 2009)
Log Message:
Spark Primitive Text Changes. See http://opensource.adobe.com/wiki/display/flexsdk/SparkTextPrimitives+Decision for the full information and reasoning for the decision. The main changes are:
Replace SimpleText with Label, a UIComponent version of the same component
Instead of extending GraphicElement, RichText will extend UIComponent (like Label will)
All of the spark text components will move to spark.components.*, so there will be spark.components.Label, spark.components.RichText, and spark.components.RichEditableText
The base class for SimpleText and RichText, spark.primitives.supportClasses.TextGraphicElement, will now extend UIComponent (instead of GraphicElement) and be moved and renamed to spark.components.supportClasses.TextBase. All of our text skin parts will now be typed as TextBase instead of TextGraphicElement
For now, RichEditableText and RichText will co-exist. Performance numbers showed that it may be possible to collapse them, but we don't have the time right now to do this. We will revisit this later on, time permitting.
QE notes: Jody and Brian have been helping out coordinate this change
Doc notes: I updated some ASDoc examples, but more work needs to be done here
Bugs: -
Reviewer: Gordon
Tests run: checkintests, Jody and Brian have been running tests
Is noteworthy for integration: Yes
Modified Paths:
flex/sdk/trunk/development/eclipse/flex/sparkTest/src/SkinTest.mxml
flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/ Window.as
flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/ WindowedApplication.as
flex/sdk/trunk/frameworks/projects/airframework/src/spark/components/ windowClasses/TitleBar.as
flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark /SparkChromeWindowedApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark /WindowedApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark /windowChrome/MacTitleBarSkin.mxml
flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark /windowChrome/TitleBarSkin.mxml
flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIM ovieClip.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent. as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField. as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProto Chain.as
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/ButtonBarExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/CheckBoxExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/DataGroupVirtualizationExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/DropDownListExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/GroupExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/HSliderExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/ListExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/NumericStepperExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/PanelExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/ToggleButtonExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/VSliderExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/ex amples/AnimateColorEffectExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/ex amples/AnimateTransitionShaderExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/ex amples/CrossFadeExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/effects/ex amples/WipeExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/exa mples/DescendantSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/exa mples/IDSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/exa mples/PseudoSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/exa mples/TypeClassSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDow nList.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.a s
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.a s
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextAre a.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextInp ut.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPl ayer.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaCl asses/VolumeBar.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/ButtonBase.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/ItemRenderer.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/SkinnableTextBase.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/core/CSSTextLayout Format.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Button BarFirstButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Button BarLastButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Button BarMiddleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Button Skin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckB oxSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Defaul tButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Defaul tItemRenderer.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDo wnListSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSlide rSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelS kin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioB uttonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/Toggle ButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSlide rSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoP layerSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaC lasses/fullScreen/ScrubBarSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaC lasses/normal/ScrubBarSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/ButtonBarFirstButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/ButtonBarLastButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/ButtonBarMiddleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/ButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/CheckBoxSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/DefaultButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/DropDownListSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/PanelSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/RadioButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/ToggleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wirefram e/VideoPlayerSkin.mxml
flex/sdk/trunk/frameworks/spark-manifest.xml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/AccordionTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TabNavigatorTes ts.mxml
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FXGCompil er.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2S WFTranscoder.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/Sta ndardDefs.java
flex/sdk/trunk/mustella/mustella.swc
Added Paths:
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/LabelExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/RichEditableTextExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/RichTextExample.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.a s
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Label.p ng
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEdi tableText.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEdi tableText.png
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichTex t.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichTex t.png
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/RichEditableTextContainerManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/RichEditableTextEditManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/support Classes/TextBase.as
Removed Paths:
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives /examples/RichEditableTextExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives /examples/RichTextExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives /examples/SimpleTextExample.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEdi tableText.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEdi tableText.png
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichTex t.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichTex t.png
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/SimpleT ext.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/SimpleT ext.png
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/support Classes/RichEditableTextContainerManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/support Classes/RichEditableTextEditManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/support Classes/TextGraphicElement.as
Like (0)
