this site displays perfect in ie8, safari, and firefox, but won't display in ie7/6 and aol, why? thanks
You don't mention what the problem is, however, viewing in IE7, I notice that menu items are not sitting inside the navbar.
You have quite a few errors on the page that need fixing.. when you create an ID, do not use spaces in the name:
eg::
id="boardman rotary"
should al be one word or separated with an underscore of hyphen
eg: boardman-rotary
Validation errors here:http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bryantaafe.com%2Frg%2F
fix those errors first and then see where the page stands.
You may need to give IE a conditional comment for the placement of the menu links..
hey nadia, the problem is that the spacing is not correct in aol and ie 6/7. if you take a look at it in ie8 and firefox you'll notice the spacing and the placement of the list items. i don't know what you are referring to when you say spaces in the id's. how would i apply a conditional comment for the other browsers? =) thanks a lot for your help
90% of browser problems start with malformed code.
Start by fixing the code validation errors described below:
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bryantaaf e.com%2Frg%2F
FYI: Div names cannot contain spaces. But they can contain hyphens or underscores.
Example:
Wrong: #division name
Acceptable: #division-name or #division_name or #divisionName
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
www.alt-web.com/
www.twitter.com/altweb
www.alt-web.blogspot.com
During testing in IE 6 an 7 the menu items are not sitting correctly. IE8 look the same as FFox.
This means you need to use a conditional comment to feed a different placement style to IE6 and IE7
This was a very quick test, so you may need refine it a little, but copy and paste the following just before the closing <./head> tag. I tested this on the index page. If it works, you can either copy and paste the CC on every page or feed a special stylesheet for IE only.
As you can see from the line in red I changed the bottom position from -8 for the other browsers to 6px for IE6 and 7. It worked for me using IETester.
See if it works for you in the 2 versions of IE.
<!--[if gte IE 7]>
<style>
#header ul {
list-style: none;
float: left;
position: absolute;
right: 0px;
bottom: 6px;
margin-left: 0px;
left: -5px;
</style>
<![endif]-->
