PS CS4 almost unusable with snow leopard
Aug 29, 2009 2:55 PM
  Latest reply: LarryFulmer, Mar 26, 2011 2:24 PM
Replies 1 2 3 4 5 ... 9 Previous Next
    Sep 3, 2009 2:58 PM   in reply to NoSongs
    One thing I have seen that I haven't seen mentioned on this thread is that for some reason, SL wants PS's Scratch Disk to be set to the Boot Disk. So if, like me you had the Primary Scratch disk set to another dive, set it back to your Mac's boot disk and see if that helps.
    Sep 3, 2009 4:10 PM   in reply to mikebhm
    mikebhm wrote:
    ATI 3870 here, with lots of crashes.
    If CS4 did not crash in Leopard you could always test by copying the  ATI drivers from Leopard to Snow Leopard and see if that makes any difference. Be sure to save the Snow Leopard drivers so you can copy them back.
    Sep 3, 2009 8:43 PM   in reply to Was DYP
    I have been all over the forums trying to stop getting emails from
    every post on this thread.  The site indicates that it's turned off,
    I've NEVER asked for these emails before and have never gotten them
    before.  How do I stop getting an email every time someone posts to
    this discussion?  Thanks!
    Sep 4, 2009 8:18 AM   in reply to NoSongs
    For the past 5 days I've been cruising the internet forums, blogs, and communities, including this one, in search of an answer to my CS4 crashing issues...
    A common factor that I'm finding across the board, is that people complaining about CS4 crashing own ATI graphics cards. So in hopes that we may be closing in on the cause of this problem... who out there is having crash issues that have an ATI card with CS4 + Snow Leopard.
    My Problem:
    On open / saves on PS, ILL, and InDesign, especially exporting PDFs from InDesign the program simply crashes/closes. Also, placing new links/photographs crashes. No pinwheel of death, no freezing. The program simply shuts down. Often times a crash report doesn't even come up for Adobe or Apple.
    I have this issue on 2 different computers - a MacPro and my MacBookPro  - both sport ATI cards.
    Sep 4, 2009 8:32 AM   in reply to jjcliff
    I have an Nvidia GeForce 8600m GT. I have all the same crashes you all have. Running on a MBP3,1 Core 2 Duo, 2.2GHz, 4gb ram (crucial branded),
    Sep 4, 2009 8:47 AM   in reply to jjcliff
    You seem motivated so I'll reply to you :-)
    The way to approach this is to use something like Crash Reporter: http://en.wikipedia.org/wiki/Crash_Reporter_%28Mac_OS_X%29
    or Shark: http://developer.apple.com/IPhone/library/documentation/DeveloperTools /Conceptual/SharkUserGuide/SystemTracing/SystemTracing.html
    I have never dug into these tools on OS X as I spend most of my time using Linux as a desktop and my (daughter's) iMac with SL and CS4/PS (with ATI card) has no problems.
    It looks like one can increase the verbosity of Crash Reporter without having to install CrashReportPrefs from the Developer Tools by running (from a terminal command window):
    defaults write com.apple.CrashReporter DialogType developer
    You probably have to prefix that command with sudo, i.e.:
    sudo defaults write com.apple.CrashReporter DialogType developer
    and you will be prompted for your user password.
    Hopefully once you have increased the verbosity using the above when a CS4 app crashes it will display some debug information. If enough people post debug info perhaps some commonalities would surface
    Shark looks even more full featured but requires a greater effort.
    Hope this helps.
    Cheers
    Sep 4, 2009 2:30 PM   in reply to NoSongs
    I did a simple upgrade from Leopard 10.5.8 to Snow Leopard today. I run Creative Suite 4, primarily Photoshop 11.0.0 and Illustrator. I didn't not have any problems using Illustrator but Photoshop crashed every time I tried to save a file, specifically with the "Save for web" dialog. I upgraded to 11.0.1, and removed all third-party plugins, but the problem persisted. I uninstalled Photoshop with Adobe's uninstaller and then reinstalled Photoshop and upgraded again to 11.0.1, but the problem persisted.
    I was able to duplicate the crash 100% of the time. Once I saved a file for the web, Photoshop simply crashed without an error message. I was only met with the Crash Report utility.
    I was able to avoid a crash by disabling the OpenGL option in my Preferences > Performance. Immediately upon deselecting this option I was able to successfully save the for the web without a crash. I have not yet reinstalled third-party plugins to test further.
    I hope my experience helps someone out there as this is a very frustrating issue.
    Below is the profile for this particular system. Not the video card as this may be related to the problem.
    Model Name:    iMac
      Model Identifier:    iMac9,1
      Processor Name:    Intel Core 2 Duo
      Processor Speed:    3.06 GHz
      Number Of Processors:    1
      Total Number Of Cores:    2
      L2 Cache:    6 MB
      Memory:    4 GB
      Bus Speed:    1.07 GHz
      Boot ROM Version:    IM91.008D.B08
      SMC Version (system):    1.45f0
    Chipset Model:    ATI Radeon HD 4850
      Type:    GPU
      Bus:    PCIe
      PCIe Lane Width:    x16
      VRAM (Total):    512 MB
      Vendor:    ATI (0x1002)
      Device ID:    0x944a
      Revision ID:    0x0000
      ROM Revision:    113-B9090C-181
      EFI Driver Version:    01.00.327
      Displays:
    iMac:
      Resolution:    1920 x 1200
      Pixel Depth:    32-Bit Color (ARGB8888)
      Main Display:    Yes
      Mirror:    Off
      Online:    Yes
      Built-In:    Yes
    Sep 4, 2009 3:39 PM   in reply to wayneswhirld
    Yes, everyone (in all apps) will gain more stability once Apple patches a few of these SnowLeopard bugs.
    Sep 4, 2009 3:40 PM   in reply to Jasondbecker44
    The Adobe crash reporter is already sending us all the details, and you can view the details that it gathers before sending them to Adobe.
    Sep 4, 2009 3:41 PM   in reply to Smellkid
    Smellkid - please read the existing replies before posting.
    Crashes on save and open (and lots of other times) are a common problem in MacOS 10.6, in many applications.
    Apple is working on it.
    Sep 4, 2009 5:32 PM   in reply to Chris Cox
    Please reread my post. I was trying to offer a solution that worked for me to everyone else.
    My apologies for trying to help.
    By the way, I read the entire thread.
    Sep 4, 2009 6:11 PM   in reply to Chris Cox
    This is not a common problem. Yes some people are having this problem but not all of us. I have not had one crash on save and open yet.
    And there is a reason some of us are not having this problem.
    Sep 5, 2009 1:22 PM   in reply to Cindy-
    I am using:
    ATI Radeon HD 2600 XT:
      Chipset Model:    ATI Radeon HD 2600
      Type:    GPU
      Bus:    PCIe
      Slot:    Slot-1
      VRAM (Total):    256 MB
      Device ID:    0x9588
      Revision ID:    0x0000
      ROM Revision:    113-B1480A-252
      EFI Driver Version:    01.00.252
    ... and crashing all the time.  Re-installed SL and re-installed PS CS4 - no improvement.
    Sep 5, 2009 7:45 PM   in reply to Smellkid
    Thanks much. I have same equip except ati radeon hd2600. Will try
    Sep 6, 2009 1:29 PM   in reply to Chris Cox
    Chris,
    Thanks for your post on this subject.  It's good to hear from someone that the problems being reported are seen as valid.
    There are, of course, two crash reporters.  Apple's and Adobe's.  Does Apple share data with Adobe, or does anyone know whether Apple has acknowledged this problem?
    Also, I most certainly hope that Adobe is getting the right data.  The latest crash that I experienced (opened a JPEG, modified it, then tried to save the modified version with a different name) generated Apple and Adobe crash reports, but when I looked at the crash data to be sent to Adobe, I found that it was pointing to an XQuartz crash, not the PS crash.
    Uh, just to make myself feel better, I'm appending it to this posting.
    Can I presume everyone else out here is seeing the same thing?
    Finally, my own personal opinion: I haven't upgrade any critical systems to Snow Leopard as yet.  I think issues like this are to be expected.  Chris, I  just would ask whether there is one place you can point CS4 (PS and the suite in general, since I like others are seeing this in all of the CS4 apps) for updates?  It'd be good to know asap about any workarounds or solutions that are developed.
    Message was edited by: KMPetersonBoston - filetype "crash" apparently not allowed, changed to .txt
    Sep 6, 2009 1:42 PM   in reply to NoSongs
    No problem here. Mac Pro 2008 with 6 GB of RAM, Radeon 4870. I installed on top of 10.5.8. So far so good. It this problem is exclusive to certain systems, I would think that the problem systems all have something in common. Is something modified on a clean 10.6 install that remans unchanged on an upgraded system?
    Sep 6, 2009 1:45 PM   in reply to KMPetersonBoston
    Yes, Apple has acknowledged the problem.  They are working on a solution now.
    We're still gathering the crash reports for MacOS 10.6.  It takes time, because the TFSInfo crash happens all over the place.
    There are other Apple crashes that also happen in multiple places, but less often.  We're trying to narrow down the circumstances of those crashes and document them for Apple.
    We don't have any updates yet, but you should keep an eye out for updates from Apple.
    Unfortunately we don't know details of the bugs in Apple's code, so we don't know of any workarounds at this time.
    1   com.apple.DesktopServices          0x98888a79 TFSInfo::~TFSInfo() + 29
    Yep, most common crash on MacOS 10.6, affecting all applications.
    Again, Apple is working on a fix.
    Sep 7, 2009 1:13 PM   in reply to LarryGRC
    Hi Larry,
    In your post did you say that you did  just an upgrade from 10.5.8 to 10.6 and your CS4 is working just fine? Do you also have installed LR 2.4 and is it also working fine?
    Jim
    Sep 8, 2009 11:06 AM   in reply to NoSongs
    Photoshop CS4 runned like a clock on Leopard. On 10.6 (updated) i get in all kinds of strange problems.
    1. Getting "Could not save "File.psd" becuase the file is already in use or was left open."
    The only app that has the file open is Photoshop. I got no other apps even running. I turned of Spotlight for all the directories (app directory, cache directory, File directory and so on). The only way to get rid of it (for a couple of hours) is to reboot.
    2. Yesterday there was a new "error" message. Totally new. "The disk copy of "file.psd" was changed since you last opened it. Do you want to save anyway?"
    I reproduced the problems with restarting. Turn off spotlight, Launch only Photoshop. The strange thing is that the feeling is that the errors come random. Can work for a couple of hours without glitches. Then it pops up.
    It's not a serious problem. But it's annoying.
    Sep 8, 2009 2:31 PM   in reply to Deluxive State
    Those sound like some part of the OS, or some other app you have installed, is playing with the files while you work in Photoshop.
    Both messages mean that something OUTSIDE of Photoshop has locked or changed the file.
    Sep 10, 2009 3:47 PM   in reply to NoSongs
    Sigh.. Just installed the Snow Leopard 10.6.1 update but photoshop still crashes at the same point (about 10% in opening a 1.2Gb file).. I guess this makes the chances of a swift solution from Apple smaller as i dont see them releasing updates weekly..
    Sep 10, 2009 6:19 PM   in reply to DaDj
    I also installed OS X 10.6.1 and Photoshop CS4 is much better.  The crashes during save seem to be gone (at least in my initial testing).  Yea!
    I am still getting a crash each time I quit Bridge.
    Sep 10, 2009 7:59 PM   in reply to vcina
    I also installed the 10.6.1 Update, and just worked on and saved four largish TIFF's in a row! Woohoo. I haven't, however attempted to save any JPG's yet. But, it is definitely an improved situation.
    Model Name:    iMac
      Model Identifier:    iMac4,1
      Processor Name:    Intel Core Duo
      Processor Speed:    2 GHz
      L2 Cache:    2 MB
      Memory:    2 GB
      Bus Speed:    667 MHz
    Sep 11, 2009 8:19 AM   in reply to NoSongs
    So apparently the crash on save problem with Photoshop CS4 seems to have been fixed with Mac Os X 10.6.1?
    I was experiencing it too...
    Thanks for updating this thread!
    Daniele
    Sep 11, 2009 9:36 AM   in reply to NoSongs
    10.6.1 did not solve anything for me. Photoshop still crashes after "saving as", and other functions. I have a MacBook Pro 13 2009
    Sep 11, 2009 9:41 AM   in reply to rafaelcaro
    Ouch...
    I have a Unibody MBP 15'' (Late 2008).
    So I guess I'll be holding off on the upgrade for a little longer.
    Sep 11, 2009 9:48 AM   in reply to rafaelcaro
    I think this problem is not as widely pervasive as some might think. My Mac Pro is running just fine, no crashing, no issues. So that leads me to believe that is has to be something commonly found in certain setups but not on all setups. I am using only moder Open Type fonts on my system, and I am not sure if this might have a baring on things, but in the past, I have had issues with certain applications misbehaving due to a corrupted font, or an old font format that is no longer fully supported on OSX. I have not had any problems whatsoever, so why are some having such a hard time an others are not?
    Sep 11, 2009 9:53 AM   in reply to Pinkletson
    I think it has something to do with fonts too. I have not had a crash since I upgraded to 10.6. I use FontAgent Pro and have it manage my system fonts. I have also disabled all the fonts that FontBook will allow me to disable.
    Sep 11, 2009 9:58 AM   in reply to Pinkletson
    I have tried to do an installation formating the hd, and just an update. Same problems in both. Maybe is a trouble with the fonts, I just disable de Menlo font, but nothing changes.
    Sep 11, 2009 10:04 AM   in reply to Pinkletson
    Exactly, I have a Mac Pro too and it's running smoothly. No crashes at all.
    It's my MBP that's giving me such a hard time...
    I can't think of specific differences between the two systems other than drivers and hardware-related stuff. But I see that other MBP owners aren't experiencing such problems, so I'm left wondering where the problem could come from...
    Sep 11, 2009 10:10 AM   in reply to napdan
    fonts
    Sep 11, 2009 10:35 AM   in reply to Cindy-
    I guess that could be it. But it's strange that the crashes happen on Save even in documents without any kind of text in it.
    Sep 11, 2009 11:25 AM   in reply to napdan
    And how hard would it be to turn off all your fonts and find out?
    Sep 11, 2009 11:30 AM   in reply to Cindy-
    I've reverted back to Leopard days ago because I can't afford lowering my productivity right now. That's why I can't test it.
    Thanks anyway for the tip.
    Sep 12, 2009 11:11 PM   in reply to jb510-LJ0JJQ
    Hi. I have a white MacBook 2.2GHz 4 GB RAM and installed Snow Leopard last Sat and Photoshop CS4 seems to be working much faster opening files, just a faster workflow, much better performance than 10.5.8. But anytime Apple releases a new system it's a crap shoot for some until all the bugs are worked out. Hope everyone gets up and running soon.
    Sep 16, 2009 6:39 AM   in reply to Cindy-
    I haven't installed Snow Leopard yet, and won't do so till I get assured that all those bugs have been resolved, but, just for arguments' sake, how to proceed to check if a certain fon type is causing all that havok?
    Sep 16, 2009 9:42 AM   in reply to hani7up
    One thing I should note before anything else is mentioned. Search all you Fonts folder and make sure you have no duplicate fonts.
    First of all I would clean all caches and then reboot. If you are still having crashes then start on fonts. A font manager would come in real handy here.
    Disable all fonts except the necessary system fonts. Clean the font caches again and reboot. If your crash free now add a few fonts back in at a time. If crashing starts you can probably narrow it down to the last fonts you installed.
    Sep 16, 2009 3:23 PM   in reply to NoSongs
    I agree what DYP said, and you need to realize that a large percentage of us in this forum have 2000-5000 fonts to manage.
    I use font doctor to fix things like duplicates, damaged fonts, etc in my font library. I advocate using font agent pro as well for management.  I run coctail, reset the PRAM, disk warrior, and sign on as a single user using fsck -fy sometimes. I'm not sure if this helps you, but I use ifreememory to keep my system running as fast as I can push it.
    With all of this going on, I have never had a problem with the PSC 4 suite.
    I've been using "Snow" for several days now and the above makes things work "perfecto".
    Sep 17, 2009 12:34 PM   in reply to casca2000
    Things seem to be pointing to Snow Leopard no longer likes Postscript type 1 fonts, while Leopard did. It seems from reading posts these may be carry overs from some installers, could even be Adobe's, in the users home folder/Library/Fonts folder. Use Apple's Font Book to resolve duplicates and validate your fonts and then use the updated FontNuke 1.1.6 to clear cached copies. See if that helps.
Actions
