browser issues!
Sep 4, 2009 6:41 PM
this site displays perfect in ie8, safari, and firefox, but won't display in ie7/6 and aol, why? thanks
    Sep 4, 2009 10:49 PM   in reply to mediastream13
    You don't mention what the problem is, however, viewing in IE7, I notice that menu items are not sitting inside the navbar.
    You have quite a few errors on the page that need fixing..  when you create an ID, do not use spaces in the name:
    eg::
    id="boardman rotary"
    should al be one word or separated with an underscore of hyphen
    eg:  boardman-rotary
    Validation errors here:
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bryantaafe.com%2Frg%2F
    fix those errors first and then see where the page stands.
    You may need to give IE a conditional comment for the placement of the menu links..
    Sep 6, 2009 11:24 AM   in reply to mediastream13
    90% of browser problems start with malformed code.
    Start by fixing the code validation errors described below:
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.bryantaaf e.com%2Frg%2F
    FYI: Div  names cannot contain spaces.  But they can contain hyphens or underscores.
    Example:
    Wrong: #division name
    Acceptable:  #division-name or  #division_name or  #divisionName
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    www.alt-web.com/
    www.twitter.com/altweb
    www.alt-web.blogspot.com
    Sep 7, 2009 7:31 PM   in reply to mediastream13
    During testing in IE 6 an 7 the menu items are not sitting correctly.  IE8 look the same as FFox.
    This means you need to use a conditional comment to feed a different placement style to IE6 and IE7
    This was a very quick test, so you may need refine it a little, but copy and paste the following just before the closing <./head> tag. I tested this on the index page.  If it works, you can either copy and paste the CC on every page  or feed a special stylesheet for IE only.
    As you can see from the line in red I changed the bottom position from -8 for the other browsers to 6px for IE6 and 7.  It worked for me using IETester.
    See if it works for you in the 2 versions of IE.
    <!--[if gte IE 7]>
    <style>
    #header ul {
        list-style: none;
        float: left;
        position: absolute;
        right: 0px;
       bottom: 6px;
        margin-left: 0px;
        left: -5px;
    </style>
    <![endif]-->
    Sep 7, 2009 7:32 PM   in reply to Nadia-P
    This may help you as a reference point regarding Conditional Comments:
    http://reference.sitepoint.com/css/conditionalcomments
