When trying to insert or update records into a MySQL database, some people get an error message that looks similar to this:
Warning: mysql_real_escape_string() [function.mysql-real-escape-string]: Access denied for user 'ODBC'@'localhost' (using password: NO) in C:\htdocs\mysite\TMPbcn96qcid9.php on line 20
The username might also be SYSTEM, instead of ODBC.
The problem is that you're trying to interact with the database using a temporary file (the clue is in the file name, which begins with TMP). This prevents PHP from accessing the MySQL connection, resulting in access being denied.
The solution is simple:
As long as your testing server definition and MySQL connection details are correct, you should now be able to insert and update records.
