Sep 23, 2009 8:18 PM
flash.* casses not showing in code completion
Like (0)
Hello,
I just installed Flex Builder 3 in my home computer, and almost none of the classes under flash.* appear under code completion. The only one that shows in code completion is flash.errors. None of the others are there. All the mx.* classes seem to be working fine.
The problem is only on code completion. If I manually type flash.display.MovieClip, it finds the MovieClip class in compile time, no problem.
I have a copy of Flex builder 3 working just fine at work.
Does anyone knows what the problem is, and how to fix it?
Did anyone have this problem before?
A number of my colleagues are experiencing the issue, but I am not. I have found this post below:
http://rjria.blogspot.com/2009/09/flash-package-missing-code-hinting-l ost.html
We've tried recreating the workspace, but this did not resolve the issue. We don't have time to reinstall the SDK or FlexBuilder at the moment.
The solution we found was to run the 3.0.2 Updater:
p_m_williams -
That solved it! Thanks so much for the info, now everything is working perfectly.
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
