While I am actually in editing mode within InContext, I can't seem to cut/paste a line from one paragraph and add it to another. I can cut the line but not paste. I have gotten the below window, but even ctrl-v doesn't work. I can cut and paste from another application into the editable areas.
I am on a PC.
Anyone else have this problem?
Doug
I am having the exact same problem and error message in FireFox 3.0.11 (have tried with earlier FF versions and Safe Mode with no success). I also have IE 8 but it doesn't support InContextEditing.
Maybe 1% of the time it will paste, but I can't pinpoint why it works when it does. Thanks for any help.
Hello dbraphael,
I've made several tests using Firefox 3.0.11, on Win XP, on your site (the about/history.html page). I can copy text from an editable region and paste it in the same editable region, or in another, using CTRL+C and CTRL+V schortcuts. I can also paste text copied from notepad files.
Can you please try to open the Error Console (from Firefox Tools - Error Console) and let us know if there is any error that appears when you try to copy/paste? Clear the console first, then try to copy/paste while leaving it open. Let us know if there is any error listed.
Also, can you please attach a screenshot with the plugins that you have installed and enabled? And another thing, are you aware that any plugin that you have installed might have changed the CTRL+V shortcut to something else (some other action?)
Thank you,
Florin
Hi JagerSmithPC,
Same questions:
Also, can you please attach a screenshot with the plugins that you have installed and enabled? And another thing, are you aware if any plugin that you have installed might have changed the CTRL+V shortcut to something else (some other action?)
Thank you,
Florin
dbraphael,
Great idea mate, but unfortunately your solution did not work for me. I disabled both MS DRM plugins and restarted FireFox and still did not have the ability to copy/paste.
Florin,
After following dbraphael's advice and disabling the DRM plugins I also cleared the error console and, from when I enter my site to when I attempt to paste I receive the following messages:
Thanks again for any assistance!
JagerSmithPC,
I have read that these plugins and can be difficult to remove or disable. Did you check to see if they were still disabled after restarting FF? I actually deleted them from my system.
Check out this thread:
http://forums.mozillazine.org/viewtopic.php?t=418289
Doug
Is this happening all the time, on each copy and paste?
Or it's working for a while than it suddenly stops working?
Is this happening on a specific page or on all pages? Please provide a link to a page where copy&paste doesn't work and eventually invite me as an editor (dpopa@adobe.com).
Here are answers -
Is this happening all the time, on each copy and paste? - yes
It did work for a while then stopped. Then yesterday worked once. Then
stopped.
I'm only working on one page..
Please provide a link to a page where copy & paste doesn't work and
eventually invite me as an editor (mailto:dpopa@adobe.com).
http://www.mullummusicfestival.com/includes/ice/
ide.html#page=artists.html
Please help. Thanks STU
Hi, I'm the web designer. Here are answers from the client Glenn who
is doing the updates.
He has tried on a PC and a Mac. Works fine for me.
stopped.
STU
Graphic » Web Designer
Re: Can't cut and paste while in editing mode 02 6684 1256
Re: Can't cut and paste while in editing mode 02 6684 6917
Re: Can't cut and paste while in editing mode 0431 678 616
Re: Can't cut and paste while in editing mode stueadie@bigpond.com
