Until relatively recently (a month or so ago?) I had absolutely no problem watching embedded videos. Then, out of nowhere, my laptop started shutting down every time I tried to watch a Flash video online. I eventually realized the problem was auto-shutdown due to massive overheating - my laptop's normal temperature while browsing is around 60-70 C, and any time I watch a Flash video (especially any sort of high-quality Flash video) this jumps up to about 95 C for a few minutes before auto-shutdown. If I leave the Flash video running in a minimized window or an un-focused tab (anywhere where it isn't rendering to the screen), the temperature returns to more reasonable but still seemingly high levels (about 85 C).
This seems crazy to me, considering I can run several hi-def videos simultaneously offline (using Windows Media Player Classic) without my laptop breaking a sweat. I've made sure I have the latest Flash Player updates, and I've tried a number of browsers (IE, Firefox, Chrome, Opera, Safari), with nearly identical results in every one. I can't watch most videos online anymore, and nothing besides Flash Player causes my laptop to overheat like this, including 3D modeling/animation software and video processing/editing software. Can somebody help me out here? Does anybody know what's going on with this?
Thanks in advance for any help -
I've heard of this, but we've never been able to make it happen in house. And we test many thousands of pages of SWF content daily.
So I'm not sure what to advise. If you were in San Francisco we might be able to arrange to take a look..
One thing you could do is uninstall (using the uninstall app), then get Flash Player 9 from the archived players technote and see if it stops happening...
If you're interested in going to that level of troubleshooting, please open a web support case (http://www.adobe.com/support/contact) and post back the case #.
Ok, I tried Flash Player 9, with almost no change in temperature - so I finally bought some compressed air, opened up my laptop, and cleaned out the air intake, fan, & heat sink. This cleaning reduced my average laptop temperature by about 10-15 C down to a much more comfortable level (~50-55 C).
The dramatic increase in temperature still happens when running Flash Player (it jumps up from 50-55 C to about 80 C), but this temperature is now within my laptop's operational limits, and shutdown no longer occurs.
So yeah, thanks for the response, I hope my experience might help anybody else with this issue - though I do have to admit that I still find it kind of puzzling that Flash Player is the only piece of software on my computer that causes this kind of temperature increase.
Flash is definitely causing my MBP a meltdown!!! For a flash site like youtube or hulu or espn.com or any site similar, my CPU usage goes +100% and it's all the webkit flash plugin in Safari.
I've updated to 10.6.1 with the latest flash plugin and still the same results. The only thing I can do is avoid flash sites all together until you guys at Adobe recognize the problem and put out a fix.. which I suppose will be never so thanks a lot for overheating my hardware.
same thing happens to me, I can watch youtube but if i watch my space viedo my computer will overheat and shut down in 20 minutes, i freeze a bottle of water and put it inside my computer that extended the limit to 30+ mins....
boot up the computer again, cool down for 5 mins with my cpu fan on, then watch again.
Something is not right here
The same thing happens to me. http://forums.adobe.com/thread/494975?tstart=90
Your work PCs might be more powerful and/or have dual cores that don't cause the CPU to spike to 100%, or perhaps they just have better cooling. I find it VERY hard to believe Adobe can't reproduce this problem in-house - it happens to me on 2 different vintage machines that are configured completely differently, and it can be observed using Firefox, Chrome or IE. I suggest the Adobe engineers try going to facebook and playing some Fishworld!
In some other threads, it is said that Adobe lets flash animations always run in maximum quality by default; this can be a problem.
Web pages that use intensive Flash Player use make older pc's suffer because of this decision about always-in-high-quality graphics.
Why doesn't Adobe implement a global configuration override so that the user can choose the default quality of Flash Player videos? Or perhaps let us customize a global fps setting? Too hard to develop? This can reduce the 100% cpu saturation to something a bit lower.
Although marked as answered, I think this question is not answered yet because Flash Player causes overheating even after cleaning fan and heat sink.
@dtforhan: >> "I still find it kind of puzzling that Flash Player is the only piece of software on my computer that causes this kind of temperature increase"
All the people with and older cpu and knowledge enough to open Task Manager while playing flash movies will agree.
Why doesn't Adobe implement a global configuration override so that the user can choose the default quality for Flash Player videos? Or perhaps let us customize a global fps setting? Too hard to develop? This can reduce the 100% cpu saturation to something a bit lower.
For anyone interested on solving this issue or a similar one, please login to https://bugs.adobe.com/flashplayer/ then search and VOTE for all opened questions that match as exactly as possible to yours in order to increase their importance. Adobe asks not to mix OS's in questions; for example, if your Flash Player plays slowly in Windows, don't vote for a question about slow playing in Linux.
This seems to be the right way to make flash developers pay attention to this kind of problems.
This may be related to a well-known issue with the Flash/Shockwave browser plugins that cause CPU spikes, and occurs on both Windows and OSX. It may cause problems even when there is no Flash on the page. It's most likely an implementation problem with Adobe. Uninstalling Flash+Shockwave player fixes the issue. :|
Firefox thread documenting behavior:
http://support.mozilla.com/en-US/forum/1/415618?forumId=1&comments_thr eshold=0&comments_parentId=415618&comments_offset=80&comments_per_page =20&thread_style=commentStyle_plain
well I don't have CPU problem. yes, it is jumpint to 100% and load is high but the problem that I have is more scarier. my GPU is going wild if I run any flash video or go to any flash site. I have MBP 3.1 SantaRosa 2.2GHz 128GB SSD Muskin Calisto, 4GB RAM GSkill and Nvidia 8600GT (which have know issue with overheating and GPU meltdown), so the flash plugin is the mayor problem for me (and probably for everyone that has 8600GT chip on MBP). when I say GPU is going wild I ment literally wild, it jumps from 45ºC to 95 -105ºC just in about 10 seconds. Adobe programmers have major problems with security issues and I can understand that, but developing something that can harm your device is just wrong. MBP is very expensive machine and I can't just buy another one....
please do something to improve flash on OS X
Believe me
I don't need to be here at all
its just that adobe has done such a stupid thing and employed hardware aceleration without every possible pc setup at their disposal, am I even here.
my pc is shutting down from overheating, and I play the latest gpu intensive games without any problems. If all of my data came from the hard drive there would be absolutely no need for hardware acceleration, and internet data is not ready to take on hard drive data. Get off the hardware acceleration gig, you or the internet is ready for hardware acceleration. I m gonna make sure that microsoft is not so anal as to just let other companies take the rein like apple.
In short the solution is for adobe to release flash player without hardware acceleration
I have two Dell Latitide E6400 series laptops and flash causes the CPU to overheat on both (one has a dual core CPU and the other has a quad core processor). Glad to see I am not the only one who does not have this problem. I will be moving to an Ipad which supports HTML5 and does not have this problem.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
