Home/Support/
Forums
994 Views 7 Replies Latest reply: Oct 17, 2009 10:21 AM by stillpianoman RSS
stillpianoman User 9 posts since
Sep 29, 2009
Sep 29, 2009 11:18 PM
Premiere 6.5 Titler now causing Program Crash
After using Premiere 6.5 for several years on Windows XP with no problems, it now crashes and Windows kills the Premiere task when going into the titler. I completely uninstalled Premiere and re-installed it. Same problem. I bet Microsoft has received several dozen crash reports from me on this one. I usually do not connect this system to the internet, but at times I do and Microsoft updated windows sometime lately. In an effort to try to fix the problem I updated Windows to Service Pack 3. Titler still fails. I also have Premiere Pro which works, but I like 6.5 better. Has anyone run into this problem? I am lost without this tool.
  • John T Smith Star 12,830 posts since
    Oct 26, 2006
    1. Sep 30, 2009 10:15 AM (in response to stillpianoman)
    Re: Premiere 6.5 Titler now causing Program Crash
    That is usually caused by a bad font... you might search the forum for font manager to see what other people use to manage their fonts, and search for bad ones
  • Bill Hunt All-Star 44,747 posts since
    Oct 10, 2002
    This ARTICLE should give you some background on fonts crashing Titler.
    Good luck,
    Hunt
    Oct 10, 2002
    Thank you for your comprehensive report. I would not have thought to check user Type Styles, but will from now on. I plan on adding your report to my article on font issues with Titler.
    If you do find the problem font, and that font file is not corrupt, please report its name. That will likely help others. That is how we found the Deja Vu font, which was not corrupt, but killed Titler (thanks to Jeff Bellune's efforts).
    Now, I have also found several non-corrupt fonts, that will just not display in Titler. There are several versions of Isabelle, and Isabella, from a couple of foundries, that just will not display anything but boxes. Why? Can only guess that there is something in their metrics that smurfs Titler. It does not crash, but just will not display these.
    Your work is appreciated. Now, off to add your comments to my article.
    Hunt
    [Edit] Done. Your efforts and your post might well same others grief and get Titler up and running for them too.
    Message was edited by: the_wine_snob - Added [Edit]
    Oct 10, 2002
    Also, too bad that you cannot give yourself the "points" for the correct answer - you deserve them for good detective work.
    Thanks again for posting,
    Hunt
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
