Home/Support/
Forums
12584 Views 34 Replies Latest reply: Feb 18, 2010 1:44 PM by Don550 RSS
badprogrammer User 20 posts since
Aug 31, 2009
Aug 31, 2009 10:49 PM
So you Cannot Install Flash Player(Failed to Register ):Solution
Hi to everybody
Today i had a rather nasty encounter with the dreaded error "cannot register" blah blah
It was an ordinary Flash Player update But it went BAD
So now what.
I went to the infamous 19166 page
I read the instructions
I downloaded the unistaller
I run the uninstaller-cleaner.....gues what ZERO
I searched more.....
I found the Reset ACL ....yupi this is the source for all my problems.
I downloaded ...i run it ....guess again.....ZERO
I still can install Flash player
I tried restarting the machine numerous times,cleaning the flash directory,cleaning the flash player directories in application but the result was a big FAT ZERO.
I know there are solutions:
1. Format the machine by yourself (this was the cure for another machine a couple months ago...luckily i  am a PC Technician so no problem but restoring everything back it time consuming)
2. Contact a technician as i read somewhere and probably pay him to *again* reformat the machine or make a complete the restore
BUT fear not here is the solution
All you need is a wonderfull little utility called Regmon    http://technet.microsoft.com/en-us/sysinternals/bb896652.aspx
and the offline Flash Player Installer (google it i cannot find right now)
Close everything that is running (it is not essential but it will help)
Run the program.
Now you have a very fast scrolling window that shows every activity...it is really fast but  don't worry leave it working
Run the offline installer
It should try to register the Flash10c.ocx but (ofcourse) it won't and pop the error message
Fear not we are going to beat the damned thing
Close the installer
Remember the Regmon utility that is gather every activity.
It has a little button called "stop autoscroll" ....click it
Also it has a filter option somewhere
Go to the filter options and choose to show only the activities related to Flash installer...i put "Flash_installer"
Scroll down to the list and sometime you will see the region regarding the Flash Installer activity....it should be marked RED
Scroll down this area untill you will see in the columns "RESULT"    the First "ACCESS DENIED" it points to a path of a registry folder this the source of all your problems ***
Fire up regedt32 (not regedit)
Find the folder in the registry ( in my case it was something like {CD@7xxxx} ....right click it give full permission to every user group you find and close regedt32
Rerun the Installer
YES it registers
Go to a flash site ....oops it asks again for flash installation ( at least it did in my case) no problem go through the online installation
and YES IT WORKS!!!!!!
After a good 2.5 hours i had again Flash.....
P.S i know it is not a very good guide but when i have time to make my web site i will have a complete guide with photos and everything.
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
