JackBush
The famous Photomerge Panorama problem is resolved!
Feb 21, 2009 3:15 PM
The PSE7 Panorama Error problem that has plagued me and that I've posted about here is now resolved. And this may help others who are still having it.
I run a program I found a long time ago called CCleaner. I assumed that, whenever I ran it, it cleaned everything bad, including the Registry. My good wife said no, it doesn't, and showed me how to clean the registry. There was a ton of junk in there and out it went. Tried the Panorama and eureka!, it worked.
CCleaner is a free program.
Thanks to all who made suggestions.
    Community Member
    Mar 10, 2009 5:37 AM
    I had a problem wwith photomerge stopping or crashing.
    I removed the preferences file and let photoshop recreate a new one and this solved the problem.
    FROM ADOBE:
    Re-create the Photoshop preferences file.
    Re-create the Photoshop preferences file to eliminate problems that a damaged preferences file might cause.
    Note: When you use this solution, Photoshop will create a new preferences file and you will lose custom settings associated with your current preferences file. However, the file you rename in step 2 is your original preferences file. If you determine that the preferences file is not causing the problem, then you can restore your custom settings by following the instructions below.
    To re-create the Photoshop preferences file:
    1. Quit Photoshop.
    2. Rename the Adobe Photoshop CS4 Prefs.psp file (for example, to Adobe Photoshop CS4 Prefs.psp.old) in the Documents and Settings/[username]/Application Data/Adobe/Adobe Photoshop CS4/Adobe Photoshop CS4 Settings folder.
    3. Start Photoshop. Photoshop creates a new preferences file.
    If the problem continues, the preferences file isn't the cause. To restore custom settings, delete the new preferences file and restore the original name of the previous preferences file.
    Oct 4, 2009 9:02 AM
    None of these worked for me.  I have had the same problem, and tried all the posted fixes to no avail.  After lots of exchanges with Adobe, they finally suggested something that worked for me.  Download and install the trial version of Elements 8.  Panorama worked OK in this.  I then tried it in Elements 7, and it worked OK as well.  I then uninstalled Elements 8 trial version, tried Panorama in Elements 7, and it still worked. I have used it successfully to merge 6 large JPEGS.  Still doesn't get to the root of the problem, but is another fix to try.  It worked for me and I now have a fully functioning program.
