DavidShulman
Steps to add vector path objects to AI document
Oct 5, 2009 7:02 AM
Hi to all AI gurus,
I'm novice AI developer (though generally experinced C/C++ dev) .
I have simple FileFormat plugin , my plugin can read some custom format vector file , similar to SVG , I would like to add strokes - path objects into new AI document.
As for this moment, I can read my file and have all vector data stored in memory ..
However I don't understand when exactly a new AI document has been created or how I can do this.  I've checked TextFileFormat sample in SDK but still missing something.
Desired sequence is  (having all data already prepared):
  1. Create new AI doc with specific dimensions , I have  AIDocumentSetup but how can I set width/ height , units and DPI
  2. Insert new vector coordinates == crarete new PathArt objects
  3. Redraw entire doc
thats it.
I just need some basic guidance here regarding these 3 point. Any sample code, link, would help.
Many thanks,
David
Message was edited by: Davidbubu
    Oct 5, 2009 8:14 AM   in reply to DavidShulman
    for source code samples, you could have a look at SnipperRunner project!
    We could find a lot of cool stuff in here!
    for the first point:
    here it is a sample from the sdk:
    try {
            SDK_ASSERT(sAIActionManager);
            SnpDocumentActionHelper::VPB vpb;
            SnippetRunnerParameter* parameter = SnippetRunnerParameter::Instance();
            ai::UnicodeString documentName = parameter->GetString(ai::UnicodeString("Document name"), ai::UnicodeString("MyDocument"));
            vpb.SetNewDocumentName(documentName);
            ai::FilePath profilesFolder;
            result = sAIFolders->FindFolder(kAIUserWritableStartupFileFolderType, false, profilesFolder);
            aisdk::check_ai_error(result);
            ai::FilePath defaultPresetFilePath = profilesFolder;
            defaultPresetFilePath.AddComponent(ai::FilePath(ai::UnicodeString("Pr int.ai")));
            ai::FilePath presetFilePath = parameter->GetFilePath("New Document Profile", true, defaultPresetFilePath);
            vpb.SetNewDocumentSettingsFile(presetFilePath);
            SnpChooser chooser;
            AIDocumentColorModelValue documentColorModel = chooser.PickDocumentColorModel();
            vpb.SetNewDocumentColorModel(documentColorModel);
            ASReal documentWidth = parameter->GetReal("Document width", 612.0);
            vpb.SetNewDocumentWidth(documentWidth);
            ASReal documentHeight = parameter->GetReal("Document height", 792.0);
            vpb.SetNewDocumentHeight(documentHeight);
            AIDocumentRulerUnitValue documentRulerUnit = chooser.PickDocumentRulerUnit();
            vpb.SetNewDocumentRulerUnits(documentRulerUnit);
            AIRasterResolution rasterResolution = chooser.PickDocumentRasterResolution();
            vpb.SetNewDocumentRasterResolution(rasterResolution);
            AIPreviewMode previewMode = chooser.PickPreviewMode();
            vpb.SetNewDocumentPreviewMode(previewMode);
            result = this->NewDocument(kDialogOff, vpb);
        catch (ai::Error& ex) {
            result = ex;
    for the second point, you could do as follow:
    ASErr result = kNoErr;
        try {
            // Create new art item in the document.
            result = sAIArt->NewArt(kPathArt, kPlaceAboveAll, NULL, &artHandle);
            // Define path segments.
            AIPathSegment segment = {{0,0},{0,0},{0,0},false};
            segment.corner = false;
            short i = 0;
            segment.p.h = 300;
            segment.p.v = 300;
            segment.in.v = 200;
            segment.in.h = segment.out.h = segment.p.h;
            segment.out.v = 400;
            result = sAIPath->SetPathSegments(artHandle, i++, 1, &segment);
            segment.p.h = 400;
            segment.p.v = 400;
            segment.in = segment.out = segment.p;
            segment.p.h = 500;
            segment.p.v = 300;
            segment.in.v = 400;
            segment.out.v = 200;
            // Keep path open.
            result = sAIPath->SetPathClosed(artHandle, false);
            result = ex;
    why do you to redraw the document?
    is there a special need?
    you do not have to do that after adding a new Art in the Artwork tree.
    Hope this will help you.
    Thomas.
    Oct 5, 2009 8:38 AM   in reply to DavidShulman
    SnippetRunner is a sample project published in the AISDK.
    If you have already downloaded it, you could find it, and some more in:
    \Adobe_Illustrator_CS3_SDK\samplecode
    \Adobe_Illustrator_CS4_SDK\samplecode
    No need to redraw, let Illustrator do it for you!
    Thomas.
