This discussion is locked
Announcing Commercial "Pay-per-Use" Pricing
Apr 26, 2010 10:29 PM
Hi all,
To all those eager to hear about our pricing, I'm pleased to be able to share this with you all.  As of today, the LiveCycle Collaboration Service (LCCS) is available for purchase on a "pay-per-use" model -- worldwide!
DimensionPriceDescription
Live Stream Bandwidth$0.49 USD per GBUp/down live stream bandwidth, such as real-time audio and video. P2P stream via RTMFP is excluded though LCCS will gracefully switch connection methods if a P2P connection cannot be established or maintained.
Push Messages$0.10 USD per 1KPush messages are data messages in to the service. Data messages out are excluded. Some examples of data messages include chat messages and shared cursors. Push messages assist in collaborative workflows between clients.
User Minutes$0.01 USD per HourUser minutes is the amount of time that a connection is maintained to the service. If there are 3 connections maintained over a 5 minute period, the total user minutes for that session is 15 minutes.
Note: Though multiple currencies are supported and your payment card will be charged in the appropriate currency, the developer portal interface and billing emails will be in English and USD only.
For more detailed information around our pricing model, please see the attached FAQ.  Sign up now for a free account and/or upgrade your account now via our developer portal.
For those who we can't get anything past, we'll explain the rebranding later...
Fang
Replies 1 2 Previous Next
    Oct 5, 2009 1:31 AM   in reply to Fang Chang
    Great congratulation !
    One question how could we see our quota usage in chat and presence message vs the rest ?
    - Our 'Test' Edoboard button may stay to try the plateforme 'interface' only without AFCS connection.We were using AFSC even for the non shared demo.
    - The largest cost is connection time, we should add a 5 min inactivity timer to auto disconnect the user.
    hum .. I was reading 1cens a minute my bad.
    Otherwise it seems very afordable great !
    Greg
    Calculating status...
    Oct 5, 2009 2:40 AM   in reply to Fang Chang
    Will you offer a plan that is suitable for high usage clients.  I plan to use the service for hours a day, with 30 - 100 concurrent users at a time.  In that case the current pricing but not be that reasonable.  It might be more affordable to go with a connect pro pricing plan.  I think there should be an unlimited usage plan for example 100 concurrent users unlimited meetings or at least something similar.
    Oct 5, 2009 3:12 AM   in reply to Fang Chang
    Great congratulations to LCCS team!
    BTW, are there any new features available along with 1.0 SDK released?
    I checked the release notes but only found the update for 0.94 and earlier.
    Jinni
    Oct 5, 2009 8:29 AM   in reply to Jinni Cao
    Hi ,
    There are some bug fixes and whiteboard enhancements as far as SDK is concerned. There are new examples on whiteboard demonstrating them.
    Regards
    Hironmay Basu
    Oct 6, 2009 9:26 AM   in reply to Fang Chang
    Can you give an example of how the "Live Stream Bandwidth" cost (non-P2P) would be applied, i.e.:
      - 1 host and 1 participant using video for ten minutes streams X amount of up and down bandwidth, costing $XX
      - 1 host and 1 participant using video AND audio for xx minutes...costs $XX
    Also, where does the whiteboard fit in this, as a "Push Message"?  If so, an example cost of using Whiteboard, if applicable.
    I think this would be very helpful for those (like me) who aren't familiar with the type and amount of actual data passing through the service.
    Oct 8, 2009 1:54 PM   in reply to David_Welch
    Hi DB,
      I think the best way to try this out is to use the Room Console, available in the developer tools tab of the SDK Navigator. Log into a room, and check out the "Logs" tab. Run and user your application on the same room, and watch the graphs and message count being displayed there. Note that the bandwidth graph is only the bandwidth down for one client, so you'll want to multiply it by the number of users you may have logged in for the final result.
    Hope this helps,
       nigel
    Oct 15, 2009 11:25 AM   in reply to Fang Chang
    Hi, Fang/Nigel.
    Any further thoughts on "behind the firewall" deployments of ALCS?
    Rick Bullotta
    Burning Sky Software
    Oct 20, 2009 9:36 PM   in reply to Fang Chang
    why is the live stream bandwidth showing when my application does not have any video or audio? I was just testing the app and under live stream bandwidth it says 0.003 GB ?
    Also about the user per minute section it says $0.01 per hour per user
    so if user one connected @ 8am and user two connected at @ 8:30am @ 8:59am will this account be billed $0.01 for each user or will it only bill the one who has been on for an hour ? I'm trying to understand how this will work for application where you have users going in and most may not even stay for an hour...
    Oct 21, 2009 7:53 AM   in reply to izunna
    Bandwidth is bandwidth is bandwidth (and the term "live stream bandwidth" is confusing.
    We count the size of the data sent and received (including data messages), so if for example you are transferring images as data messages they will count as bandwidth used.
    User time is calculated as the total connection time of each user, so if you have one user connected for an hour and then another user joins for 30 minutes you will have 1h 30m of user time. Also, we bill for the total connection time for the month, so if you have users connecting to the rooms for only a few minutes at a time they will still contribute to your total connection time for the month and you will be billed for it.
    Of course if you don't convert any application to "paid" you can still use the system for the equivalent of $15 of usage per month, so the best thing to understand how the pricing model work is to run some test application and check the usage.
    Oct 21, 2009 12:12 PM   in reply to Raff.
    Thanks for the reply. I did run one of the chat application i'm developing through the system and it will be nice to have list of actions that might count as push message. E.g I only tested the application connecting to the server and the application connecting to one collectionnode. But it says  my push message is 254. So does this mean connecting to the server counts towards your push message count?. .. I didn't send any chat message. Just login and log out few times.
    Oct 21, 2009 12:56 PM   in reply to izunna
    Hi Izunna,
      You will incur a little bit of messaging hit for joining the room and publishing your presence (UserManager pushes a message to others in the room). A list of messages incurred by the framework itself is a good idea - we'll look into getting that documented. In general, it should be a pretty tiny amount of your cost.
      thanks
       nigel
    Dec 19, 2009 1:03 PM   in reply to Fang Chang
    so AFCS is no longer free ?
    Regards
    fox
    Dec 19, 2009 1:22 PM   in reply to whomzour
    We still have a free offering available for development and non-commercial use. With the new quota system you get $15 worth of free usage a month and if you need more or you want to bring your application commercial you can upgrade your account and select which applications you want to pay for and the maximum montly payment / usage you are willing to incur.
    Jan 7, 2010 6:05 AM   in reply to Fang Chang
    I am planning a video chat app, and this seems to be an affordable solution. Please confirm my calc.
    A room with 8 users, 1 user is multicasting to 7 others during 2 minutes. That is 8 streams altogether. Video is at 160 kbps, so here we go:
    8 streams * 160kbps * 120 seconds = 153 600 kbit / 8 bit = 19 200 kbyte = 18 Megabyte
    18 Megabytes is not that bad.
    Jan 7, 2010 8:42 AM   in reply to Mickey79
    Great, thanks for the post!  And, with P2P, almost nothing!
    David
    Jan 7, 2010 5:34 PM   in reply to Fang Chang
    Wow, thanks guys. That is massively awesome.
    So basically, I wont even need to build a separate solution for Adobe Stratus to use P2P, but it is built into LCCS.
    Fantastic.
    Jan 17, 2010 11:15 PM   in reply to Fang Chang
    Hi All,
    Below is our usage report for the LCCS. Can some one help me understand how adobe arrived at the figure $0.17 little confused with the push messages.
    DescriptionUnits
    Live Stream Bandwidth0.030 GB
    Push Messages1239
    User minutes188 minutes
    Total$0.17
    How many concurrent users are supported at any given point of time?
    Thanks in advance.
    Regards
    Thresholdsoft
    Jan 18, 2010 5:00 PM   in reply to Fang Chang
    Thanks for the reply Fang.
    My other question was about.
    Let us suppose we are conducting a training session, is there any limit on the number of users who can log-in?
    Thresholdsoft
    Jan 29, 2010 3:41 PM   in reply to Fang Chang
    Can I send video as binary data using NetGroup or BinaryPublisher? Will I be able to use P2P? Thanks!
    Jan 29, 2010 6:41 PM   in reply to tonyv2010
    I am not sure I understand your question completely.
    BinaryPublish publishes a binary "file" to our temporary local repository, so while you can upload a small video and share it (via download) for the duration of a session I don't think it's what you want to do in your use case.
    NetGroup is one of the p2p features that will be available in FlashPlayer 10.1
    LCCS does support p2p connections and p2p a/v streams and it will use the NetGroup feature for data sharing between peers (I think, I am not familiar with that part of the code, but in any case we will provide p2p data sharing when 10.1 will be available)
    Feb 8, 2010 9:26 PM   in reply to Raff.
    hi Raff,
    Thank you for the reply! Sorry for getting back to this rather late. Let me rephrase my question here.
    I wrote an application on Stratus, which supports P2P data sharing among peers. It relies on NetConnection and NetStream, whose send() function is especially helpful. To connect to Stratus you just need to call NetConnection.connect(Stratus_address_+DEVELOPER_KEY). NetGroup, when released, will be very helpful too.
    I wonder if such an application would be portable to LCCS?
    Thank you very much!
    Feb 9, 2010 12:08 PM   in reply to tonyv2010
    We are adding p2p data sharing to LCCS, that uses the same primitives you use to connect to Stratus and then establish p2p connections to peers (and we'll be using NetGroups to group peers)
    So, yes, you'll be able to write p2p applications for data messaging that use the LCCS data messaging model. But you will not be able to reuse your low-level code you wrote for Stratus, since we don't expose the NetConnection interface.
    The nice thing of using LCCS vs. Stratus is that your application can leverage both client-server and p2p configuration depending on the number of user connected and network conditions. Or, you can start with client-server configuration and then switch to p2p if you find out that your typical use case is, for example, a few users mostly on the same local network. Or start with p2p and later reconfigure for client-server if your typical use case is a large number of users, or users that normally are on networks that don't allow or perform poorly in a p2p configuration.
    Feb 10, 2010 5:09 AM   in reply to Raff.
    I see. Thank you very much!
    Feb 12, 2010 2:03 PM   in reply to tonyv2010
    Sorry to bother you with another question Raff, when you say "start with p2p and later reconfigure for client-server if your typical use case is a large number of users,...", do you mean you will switch to hub-and-spoke when the number of peers in one room are high? I am under the impression that P2P works better when there are more peers.
    Feb 17, 2010 3:37 AM   in reply to Fang Chang
    I have some questions regarding the free usage and the monthly limits.
    In the Dev Portal I currently have 3 "Applications". My "default" application says "Free" under "Montlhy Limit" and the others have a dollar limit.
    1. Does that mean that the $15 free I get each month only is usage on my "default" application ?
    2. Which again means that I can not have an application running that have $15 free usage and after that usage is billed ?
    3. The limit I have set does that get reset on the first of every month or on the day I get charged ?
    Feb 18, 2010 2:37 AM   in reply to Fang Chang
    Okay - one more question then.
    Looking at "Usage this cycle" is that then usage since the last charge or usage since the first of the month?
    It should of course in my opinion be since last charge but I'm in doubt because when I open a Report for that application the begin date is the first of the month up till today.
    Feb 22, 2010 10:17 AM   in reply to jesperkc
    (Sorry for the delay, I'm coming back to speed after a vacation)
      You're right of course, the "cycle" refers to your billing cycle, which,
    if you've paid the $5 upgrade fee, starts on the day you made that payment
    (you're billed every month from that day). If it's a free account, we just
    use calendar months.
      Our reports could be smarter - you're able to change the range for the
    report graphs, which default to calendar months. I'm making a note that we
    should remember your billing date and use that for the graphs.
      nigel
    Feb 23, 2010 4:13 AM   in reply to Nigel Pegg
    Another thing you should probably look into:
    I changed a Monthly Limit from $15 to $50. After I logged out and in again it said FREE.
    After another logout and login it correctly said $50 though.
    Feb 28, 2010 6:49 AM   in reply to Fang Chang
    Two questions I really hope someone can answer. FYI I am building a simple 1-to-1 video/text chat, currently on Stratus, but sick of the downtime, etc..
    1) When a communicating over a p2p connection, are we still charged for messages?
    2) If I have 100 people randomly chatting with eachother, what percentage would you expect to fall back to hub-spoke?
    Thank you!
    Feb 28, 2010 8:03 AM   in reply to campuslive
    Currently we have p2p only for audio/video and not data messages.
    a) If you are using p2p for audio/video, then you are not charged for that stream. You are charged only for the connection time.
    b) Currently we don't have p2p for text chat. But in future when we provide that feature, you won't be charged for text chat for any number of users. However, for audio/video chat, it falls back to hub-spoke the moment its more than 3 people or someone doesn’t have player 10 or firewall.
    Hironmay Basu
    Feb 28, 2010 8:31 AM   in reply to Hironmay
    Hironmay, correct me if I'm wrong here but in scenario a), doing a p2p video
    call, you are still charged for "messaging" because you must still be
    connected to the LCCS service.  There are still control messages being
    passed back and forth almost like a sideband channel between the two peer to
    peer clients.  You won't be charged for the stream but there is still a
    smaller charge for the messaging in this case.  That's my understanding of
    how all this works anyway.
    -Eric
    Feb 28, 2010 10:49 AM   in reply to esteimle
    This makes sense to me, though I don't see why messages couldnt be passed in the p2p stream as we do successfully with Stratus.
    My concern is really the amount of users that require the fall back to hub-spoke. The difference in cost with an app serving tens of thousands of users could be tremendous.
    Assuming we detect and force Flash Player 10.1+ use in our app, what % (very roughly) might we expect to have to fall back due to firewall issues?
    By debugging ChatRoulette's code I noticed they've increased their FMS server cluster from 5 to 12 boxes. My guess is there is a pretty large % of fallback for whatever reason.
    -jared
    Feb 28, 2010 11:10 AM   in reply to campuslive
    Yep welcome to my world, we worry about the same thing with our LCCS video
    chat.  Besides if you could pass messages over p2p, how could they charge
    you for connect time?  I forget how but you can force no hub and spoke if
    you want.
    Oh and btw, this might not apply to you but right now you can't do video and
    audio chat with three people without getting forced into hub and spoke.
    Something to do with the maximum number of p2p streams that are currently
    allowed before fall back.  One of the guys mentioned changing that in a
    future release though.
    I've been assuming (dangerous I know) that firewall/NAT fall back will
    happen whenever someone is behind a symmetric NAT, a dual NAT or a very
    restrictive firewall.  So that would be users in some corporate environments
    (certainly not our small startup office), and probably home users running
    firewall programs on their PC that are set to be very restrictive.  So hard
    to come up with a percentage really, but I'd wager that most people who are
    just behind typical home routers will be just fine.
    -Eric
    Mar 1, 2010 9:15 AM   in reply to esteimle
    First up, for P2P audio/video chat, as long as you're just doing 3 people
    or fewer in a room, and they all have permissive firewalls, you'll be fine.
    We are adding P2P data, likely within the next 2 months (it's more
    complicated for us, since we wanted to fit it properly within our existing
    dev model). As Basu says, you won't be charged for P2P usage. I'm making a
    note that one of the features we should add in is the ability to prevent a
    user from connecting unless they can get RTMFP to work.
      That said, in all cases, you'll still have some control messages sent hub
    and spoke (for example, for setting up the peer connections), and you'll
    still have connection time charges (RTMFP still requires a persistent
    connection to the service, which eats a small portion of our capacity).
       nigel
    Mar 1, 2010 9:35 AM   in reply to Nigel Pegg
    Nigel,
              Can you clarify this statement " First up, for P2P audio/video chat, as long as you're just doing 3 people or fewer in a room, and they all have permissive firewalls, you'll be fine."
    In a previous thread where I asked about three man a/v chat I asked:
    Is there a limit on the number of P2P streams allowed by the flash player?    I've got three way video chat working and there's a message in my debug log that says:  "The total stream limit for P2P streams have"   and then it cuts off.   I grepped the source and didn't find that warning/error message.
    So I'm guessing it's about to tell me the number of streams have been reached?   Beyond the fact that 3 upstream video chats is probably all most connections can handle, is this a hard limit in the player or a soft limit based on available bandwidth?
    Thanks for the help.
    -Eric
    To which Hironmay later responded:
    If you are doing both audio and video for all three , It won't work. However, if you are doing only video then all three can share video.
    So, the logic says the number of streams of any user multiplied by number of other users (except him) should not be greater than 3. So, if I am sharing both audio and video and there are two more people, then it becomes 4, which makes it fall back to hub-spoke.
    Hope this helps
    Hironmay Basu
    To which you responed:
    Yeah, in this case, for every user that's receiving your stream, you have
    to stream separately to them. So if I'm videochatting with 3 folks, I'm
    pushing 3 streams - it's a lot for most uplinks to handle (many have their
    hands full with just 1).
    What we could consider doing is adding an API to StreamManager, such that
    you could declare the stream limit and override how much pushing you think
    your users can handle.
    nigel
    So does this mean you  have removed this restriction or that there is a new API in StreamManager I need to look up and add to our code?
    Not trying to be a d*ck just want to make sure I'm on top of things.
    Thank You,
    Eric
1 2 Previous Next
