ENIGMACODE
Is there a way to copy attributes from one composition to another?
Oct 5, 2009 5:00 PM
I'm using After Effects 7.0
I'd like to copy the same Zoom attributes from one composition to 30 photographs.
In Final Cut, you can copy attributes from one clip to another. Or from one still photo to another.
Is there a way to do that in AE 7?
Thanx
Mike
    Adobe Employee
    Oct 5, 2009 5:07 PM
    What do you mean by zoom? Scale? If so, you can just select the Scale property from the layer you want, copy and then select all other 30 layers and paste. If there were any keyframes in the original layer's Scale property, they will be pasted from the current time.
    From CS3 onwards, you can also copy whole top level property groups (for example, the whole "Transform" property group) and paste it to other layers.
    Adobe Employee
    Oct 5, 2009 5:34 PM
    EDIT: I see you edited your question, so I am editing my reply.
    To copy the scale of a layer, open the main twirl of that layer and you'll see the Transform properties group. Open the twirl for that, and you'll see Anchor Point, Position, Scale, etc. Click on "Scale" and copy it (Edit > Copy, or Control+C on Windows/Command+C on Mac). Then select the other layers and just paste (Edit > Paste, or Control+C on Win/Command+V on Mac).
    Such a broad question
    Anytime you add a new item you imported to the timeline or composition panels, it becomes a new layer.
    Anytime you duplicate an existing layer (Edit > Duplicate), you get a new layer.
    Anytime you split a layer (Edit > Split) you get a new layer.
    Anytime you copy a whole layer (target the name in the timeline panel) and paste it, you get a new layer.
    You also create layers when you use the Shape tools, text tools, or create a new solid layer, etc.
    This list could go on and on, so instead, I invite you to read the After Effects Help section on Creating layers specifically, and the whole chapter on Layers and properties, in general. If anything isn't clear for you, then let us know.
    Adobe Employee
    Oct 5, 2009 7:04 PM
    Enigma: Look at the beginning of my (modified) last reply. I explained in detail how to copy scale (or other transform properties) from one layers to others.
    Community Member
    Oct 7, 2009 4:54 PM
    Gave up on Motion, eh?
    You can duplicate a layer and all of its parameters and animation and then replace the contents of the layer with new media.
    See the manual for "replace." Basically, you select a layer, then select an object in your project list, and option-drag it to the timeline. Drop it on the selected layer. It's a bit tricky first few times.
    bogiesan
    Community Member
    Oct 8, 2009 8:53 AM
    Sorry, Mike, I remember your many posts on the video forum at apple.com as you were ramping up a major project. I, obviously incorrectly, assumed you would have been using the other applications in your Final Cut Studio package all this time.
    You're going to love AE, very complex, though.
    Support traffic at the cow is faster and thicker but the signal to noise ratio is far better here.
    bogiesan
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
