arnold.25
TabElement Not Supported with TextLayout Framework
Sep 30, 2009 3:41 AM
Hi
     I am creating application using textLayout Framework with Flex 3(SDK 3.4).
     I write a code like i have two SpanElements i.e. spanElement1 and spanelement2 ans one TabElement.
         code like this:
// First Span--------------------------------
        var paraElement:ParagraphElement = new ParagraphElement();
        var spanElement1:SpanElement = new SpanElement();
         spanElement1.text ="A";
         paraElement.addChild(spanElement1);
// TabELement-------------------------------------------------
        var tabElement:TabElement = new TabElement ();
         paraElement.addChild(tabElement);
// Second Span--------------------------
        var spanElement2:SpanElement = new SpanElement();
         spanElement2.text ="B";
         paraElement.addChild(spanElement2);
The output of above code is :----------------
          A
          B
What i want Output like-----------------------
        A     B
TabElement gives output same as the output of BreakElement
so how can use TabElement.
If anyone know the solution of above problem then please reply .
    Adobe Employee
    Sep 30, 2009 2:07 PM
    You also need to set tabStops.  For example, paraElement.tabStops = "36 72".
    By default in current player a tab without a tabStop results in a new line.  Current thinking is that's a bug and player will add default tab stops.
    Richard
    Adobe Employee
    Oct 5, 2009 10:16 PM
    The problem here is that you have more tabs than tabstops, so the extra tabs take up the remaining space on the line.You can either just use one tab, with one tabstop set where you want it, or use multiple tabs with multiple tabstops.
    I also notice you're using an older build. You can get a newer (improved!) build posted as part of the Flex Gumbo SDK.
    Here's some newer code that would work:
    <?xml version="1.0" encoding="utf-8"?>
    <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="paragraphFormat()">
        <mx:Script>
            <![CDATA[
                import flashx.textLayout.container.ContainerController;
                import flashx.textLayout.elements.SpanElement;
                import flashx.textLayout.elements.ParagraphElement;
                import flash.text.engine.TabAlignment;
                import flashx.textLayout.formats.TabStopFormat;
                import flashx.textLayout.formats.TextLayoutFormat;
                import flashx.textLayout.elements.TextFlow;
                private var textContainer:Sprite = null;
                public function paragraphFormat():void
                    textContainer = new Sprite();
                    var textFlow:TextFlow = new TextFlow();
                    var paraFormat:TextLayoutFormat = new TextLayoutFormat();
                    paraFormat.paragraphStartIndent = 15;
                    paraFormat.paragraphSpaceBefore = 15;
                    paraFormat.paragraphEndIndent = 15;
                    paraFormat.paragraphSpaceAfter = 15;
                    paraFormat.textIndent = 8;
                    var tabStop1:TabStopFormat = new TabStopFormat();
                    tabStop1.alignment = TabAlignment.CENTER;
                    tabStop1.position = 100;
                    var tabStop2:TabStopFormat = new TabStopFormat();
                    tabStop2.alignment = TabAlignment.CENTER;
                    tabStop2.position = 200;
                     var tabStop3:TabStopFormat = new TabStopFormat();
                    tabStop3.alignment = TabAlignment.CENTER;
                    tabStop3.position = 300;
                    paraFormat.tabStops = [tabStop1, tabStop2, tabStop3];
                    textFlow.hostFormat = paraFormat;
                    var p:ParagraphElement = new ParagraphElement();
                    var span:SpanElement = new SpanElement();
                    span.text = "123\t\t\t456.";
                    //trace("text : "+ span.text);
                    span.fontSize = 32;
                    p.addChild(span);
                    textFlow.addChild(p);
                    textFlow.flowComposer.addController(new ContainerController(textContainer,400,500));
                    textFlow.flowComposer.updateAllControllers();
                    canvas.rawChildren.addChild(textContainer);
        </mx:Script>
        <mx:Canvas id="canvas" width="720" height="540"  backgroundColor="#ECE9D8" verticalScrollPolicy="auto" borderColor="#000000"  />
    </mx:Application>
    Adobe Employee
    Oct 9, 2009 12:31 AM
    Well, you could just add a lot of tab stops; doesn't hurt to have too many. Or if for some reason you don't want to do that, you could programmatically count the tabs and add the correct number.  I'm afraid I don't have a better solution.
    - robin
    Adobe Employee
    Oct 9, 2009 12:32 AM
    I was maybe a little to quick there. We do recognise there's a problem with the tab stops. You ought to be able to set up default tab stops at intervals. But you can't do that today, so failing that, the best bet is to define enough for what you need.
    - robin
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
