I need help I have been working on a new form I want to have digatally signed. I add the digital signature box, in the test pdf it pulls in my digital certificates and works. Once I save the form and try opening it with adobe reader 9 nothing happens when I click the signature block. On the other hand when it is opened in adobe pro the signatures work. I am saving the file as static and tried several combinations of options and nothing seems to work. Can anybody give me some easy to follow instructions? I am using version 8. I appreciate any help.
That was the same problem I had. Basically all you have to do is once you build and save the form as a pdf is to open the pdf using Adobe Pro again then go to advanced and select enable usage rights in adobe reader, and save the pdf again. That will activate the extended capabilities for people using the reader, this also will enable users to save data in the form. Hope this helps, I went crazy looking for that.
Rich
I am having the same problem with signatures. I am including a form in a pdf portfolio to collect signatures from different users who have Reader. I make sure that features have been extended for reader. Most of the time they are okay. But every once in a while (at least one every two weeks) I get a user telling me they can't sign. No message or error of any kind, just a quick blink but no signature. As a work-around I've had to save a copy and re-extend features. This can be time consuming when there are a few documents I need to circulate. Please advise.
