Sebastian Beer
Premiere Elements 8, Problem Displaying MP4
Oct 7, 2009 6:08 AM
I recently installed Premiere Elements 8 together with Photoshop Elements 8.
After this I also installed Quicktime from the homerpage of Apple. (Contrary to what PE told me I had no choice between different versions of Quicktime.)
Basically everything works fine however I have aproblem with my MP4-files which I took with my Sony T900.
I can view them perfectly in the organizer but not in Premiere Elements 8. While the sound is played correct instead of the pictures there is displayed a red square only. Viewing in Quicktime directly does work perfectly.
I would be very gratefur for any hint or comment.
Sebastian
    Community Member
    Oct 7, 2009 6:30 AM
    Community Member
    Oct 7, 2009 8:24 AM
    Well, as we always says, with millions of computer configurations out there, your mileage may vary. And if it works for you, it works. You may just have some codec installed that supports the clips.
    But it most likely won't.
    Premiere Elements will work with AVCHD MP4 files. It usually will not work with MP4s from non-standard video sources, including still cameras. Conversion is really the only way to ensure success every time.
    Community Member
    Oct 22, 2009 6:26 AM
    Community Member
    Oct 22, 2009 12:53 PM
    Sebastian,
    This pertains more to PrPro, than to PrE 8, but many have found that Apple'sH.264 does not play well. Many have gone to the Lead, or the MainConcept H.264 and have had far better results.
    Also, some users have reported issues with Apple's QT Player 7.6.4 and some Adobe products. I have 7.5.5 and it seems very stable and there are no conflicts. [Going back a bit, the entire 7.4.x version group were death to most Adobe products, and it was not until 7.5.5 that Apple got this ironed out.] The Apple site used to have an archive of older versions of QT Player. Last time I looked, it was still there, but you had to navigate a bunch to get to it. That had changed from the old days, when the link was just to the left of the QT Player page.
    Good luck,
    Hunt
    Community Member
    Oct 23, 2009 4:24 AM
    You can also check if the same file is playing well in the PRE embedded organizer. If it is playing fine there, then it might very well be a bug in PRE timeline.
    Community Member
    Dec 22, 2009 6:31 AM
    Just wondering, I had the same issue, and I tried to rename the filename to .qt instead of .mp4 and that worked in the editor.
    Since I got it to work I thought maybe it was worth a shot for you.
    I tried the same thing, using premiere elements 7 and it worked there, then tried premiere elements 8 and got the red box as described. After just testing with some extensions, the .qt extension seemed to make Premiere Elements 8 read the file correctly.
    Anyway hope it works for you as it did the trick for me.
    I had quicktime player 7.6.5 installed.
    Community Member
    Dec 22, 2009 7:26 AM
    Have we established yet whether these MP4s are coming from an AVCHD camcorder or from another type of camera (a still camera, Flip or pocket camcorder) that shoots in a non-AVCHD MP4 format?
    These are very different formats and different rules apply.
    Premiere Elements and the Organzer are not likely to be able to support video from taht Sony t900 in its native format, as I discussed in my original post.
    Community Member
    Dec 22, 2009 8:48 AM
    Sebastian,
    Glad to hear that you got it running for you.
    Now, just to recap for others, and myself, the fix was to take your MP4 files, and rename them from [File Name].MP4 to [File Name].qt. Is that correct?
    Thanks for your response,
    Hunt
    Community Member
    Dec 22, 2009 8:56 AM
    I'm glad to hear that it worked
    Hunt,
    You got it right.
    Community Member
    Jan 24, 2010 10:04 AM
    Great, and thanks for reporting. With some of the tangents in the thread, I just wanted to make sure I had followed along and picked up on the fix.
    Until this thread, I had not even heard of the QT file extension. That's already two things that I've learned this morning.
    Thanks for the clarification and also for having the fix for Sebastian.
    Appreciated,
    Hunt
    Community Member
    Jan 24, 2010 10:05 AM
    Great news! It is a shame that Adobe took so long to report, but they probably had to do some lab testing on their end. Thanks for reporting and furnishing the "cures."
    Good luck,
    Hunt
    Feb 8, 2010 12:23 PM
    Sebastian:
    I've followed your thread on this, and boy am I happy that someone has found a solution... I'm at work right now,
    but I will try it when I get home... you see, I just bought PE 8 this week for my son and told him (after all of my prior
    research) that we WOULD NOT have to continue spending time with video converters anymore.. well, to my
    surprise, we installed PE8 this past weekend and tried importing our first MP4 file (generated from a "GOPro Hero"
    action cam) and we were shocked to see that PE8 wouldn't read it!  So I had to explain to my son (he's 12) that there
    has to be some quick solution out there, as I could NOT believe that PE8, just released, would not support MP4!
    Anyway, I noticed that your long awaited response from Adobe suggested one of the fixes as reinserting the Plug In
    file from PE7 into the PE8 program folder... I'm wondering if you would be willing to email me that plugin from PE7
    since I did not previously have PE7... my email is:   ski102205@yahoo.com
    Any help on this would be greatly appreciated, and also make things easier for my son as he is getting really good
    at creating skateboarding/snowboarding movies, but is looking forward to being able to just import his MP4's without
    many extra steps and work-arounds...
    Thanks so much!
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
