problem with getting CS3 to work in windows 7 64-bit
Oct 23, 2009 1:05 AM
My old XP computer (which I had CS3 installed) died and I bought a HP laptop with win 7 64-bit preinstalled. During installation of CS3, at about 75%, a warning popped up that said "adobepdf.dll is needed, pls insert the vista CD" . Since I don't have vista and I am using win 7, I hit ca
ncel and the installation continued with no problem, apparently.
After the installation is finished. When I tried to open Photoshop and acrobat, the program attempted to load up (I was able to see the grey screen of photoshop, but no logo) and would become "not responding" almost immediately and just stalled. With illustrator and indesign, I don't even see any screen, as if the computer just ignored me. However, under the "processes" tab in task manager, I could see the .exe files listed as "processes" but nothing under the "applications" tab. I checked the memory and it's obvious that memory usage has gone up once I tried to open the apps. Seems like the apps are taking up memory but did not appear. The only program that runs successfully is bridge.
adobe rep told me: Please follow the steps given  below:
Insert the Windows 7 CD-ROM to find AdobePDF.dll, go to the
AdobePDF.dll_64 in DATA1.CAB which is included in the Adobe install file
s. Copy the file to your system and rename it AdobePDF.dll and then install it.
Since I don't have the w7 cd (HP computer comes presintalled and doesn't include an OEM win7 disc) and I can't do the above. Plus, I am not sure my problem could be solved by the above. Any help would be greatly appreciated.
    Oct 23, 2009 1:23 PM   in reply to cyrilchong
    Is there a way to browse when that error comes up? There may be a folder on the harddrive with the installation files for windows.
    Bob
    Oct 23, 2009 2:21 PM   in reply to cyrilchong
    I had exactly the same problem and having been round in circles think I might have an answer...
    There is a knowledgebase article which refers to Vista 64 bit:
    http://kb2.adobe.com/cps/401/kb401731.html
    The technote linked at the bottom of the article: "333360: Support policy for Adobe Acrobat (8.0.x Windows x64)" suggests installing Acrobat 8.1 and that appears to have worked for me.
    The technote article is here:
    http://kb2.adobe.com/cps/333/333360.html
    and the Acrobat 8.1 download is here:
    http://www.adobe.com/support/downloads/product.jsp?product=1&platform= Windows
    (I went for "Adobe Acrobat 8.1 Professional and Standard update - English, French, German, and Japanese").
    Oct 24, 2009 1:21 AM   in reply to cyrilchong
    For me it worked immediately after installing the 8.1 update.
    This is everything I did:
    1. Did a clean install of Windows 7 Ultimate upgrade onto Dell Dimension 9150
    2. Installed full Adobe Creative Suite 3 Web Premium
    3. During installation, received the prompt 'insert Vista CD to find adobepdf.dll'.
    4. After viewing this forum/support site, opted to click cancel and continue installation without the file
    5. Read your original post and looked for adobepdf.dll, adobepdf.dll_64 and/or data.cab but could find any of them on Windows 7 CD or the CS3 CD
    6. Activated Dreamweaver (and therefore rest of CS3) over the internet
    7. Found the additional info about using 8.1 (download) rather than 8.0 (from CD).
    8. Without even trying to run Acrobat, I downloaded 8.1, and ran the update.
    9. Ran Acrobat without any problems.
    10. Ran Photoshop without any problems.
    11. Ran Adobe updater and my current Acrobat version is showing as 8.1.3.
    Perhaps you could try totally uninstalling CS3, and then repeating steps 2-11 above? Note that I did not try to run Acrobat after the initial install, which may or not be significant.
    Oct 24, 2009 5:49 AM   in reply to PaulF21
    I believe it is significant. Acrobat 8 was launched BEFORE Vista and required the 8.1 patch to work.
    The issue is likely to be the same with Windows 7.
    Bob
