Thought i would chime in with similar issues. been using lightroom since 1.0 with no issues importing via fw400 card reader. once i picked up a lexar fw800 reader it would corrupt about 2-3 files per import. You can re import them and they files are fine. the corruption is very random. had amazon send me a new reader thinking that was the issue but same problem. I them purchase the sandisk fw800 reader and I am having the very same issues. i've tried countless cf cards (all pro grade lexar and sandisk cards) as well as cable after cable and same issue. it's always to different files. getting really frustrated. I'd move back to my fw400 reader but since the new macbook pro's only have fw800 i'm kind of stuck and importing 20-30 gigs via usb readers are painful. I have the issue on both my macbook pro and my 8 core macpro (problems go away when using a fw400 reader on the macpro). attached is what the corruption looks like (the amount varies from image to image). i've also noticed that some will initially look corrupted like this and then once the standard preview gets rendered it's fine, others are not so lucky. please help
http://homepage.mac.com/bmarvin/filechute/lightroomcorrupt.jpg
In my observations this is directly related to Lightroom. I have just installed the newest version and it still happens. Canon 40D (RAW+jpeg).I have used different memory cards, downloaded to my desktop using the built in card reader, using a Firewire card reader, copying form the CF card; I have recently looked back at images from over a year ago which had not been edited or altered at all, had been just fine and watched as Lightroom, as it painted the thumbnail panel at the bottom, turn a good image into a piece of junk, multi-colored lines and all, right before my eyes. Occasionally, I can deleted a photo from a folder, and re-import seperately, and sometimes Lightroom leaves it alone, sometimes it jacks it up. I no longer trust the software.
This has been going on for the past 4-8 weeks I would say. Getting corrupt catalog notices had never occured until that time, now it is a never-ending process. I wait and watch Lightroom mess up images. (I have had LR since it was new and have loved how it has evolved. I really like the poroduct when it works right. I am very disappointed, to say the least). Messes up new images, old ones that have been just fine until I took a recent look at them.
The only saving grace is that I tend to shoot multiple images...some may get hijacked by Lightroom and others may be ignored. I have no idea at this point what to do. I have run MEMTEST and my machine's memory is fine, graphics card has an up-to-date driver. I do not beleive that so many variables can change, yet Lightroom not be the culprit. Ugh.
I have the same problem and it is a ACR problem for sure.
1. I have the latest updates on LR and CS4
2. Both have the same problem when opening the same CR2 file
3. I have a Canon 40D
4. The same CR2 files are opened just fine with the Canon DPP.
I tried to delete the side car file and repimport in the hope that all changes are kept there and therefore the corruption may be contained there as well. Nothing seems to impact the corruption.
The funny thing is that when you point to the file before importing the thumbnail LR and CS4 generate looks fine. They both actually show the proper full size image for a second and then part of the image is whited out with some diagonal lines here and there.
Also, many times this problem does not occur with the first time import but later one after a few times the file has been access / processed by LR2 / CS4. But I can't make out any particlar patern to recreate. However, once it happens the file will never recover.\
I wish I could share one of these files with one of you to see if the problem occurs across different computers or is it something local to me at this point with the specific file. (size limit is 5MB and 40D raw files are larger ![]()
I had this problem in two forms: corruption during download and corruption of old photos. By corruption I mean big blocks of white or pink or other colors--sample JPEG attached. I first blamed my new Lightroom software, but now I think that is like blaming the messanger for bad news. The first thing I did per this discussion thread was to run various Dell and Microsoft diagnostic tests on my memory and then on my hard drive where the photos are. No problems reported. After more searching and testing here is what I think caused the two problems.
1. The download corruption was due to some sort of incompatibility between my new Lexar flash cards and my Sony card reader. This was true for RAW and JPEG photos. The corrruption was random and unpredictable, sometimes 1 out of 40 photos, other times 20 out of 40 photos. And also some sort of incompatiibility between these Lexar cards and my USB powered hub by Targus. So I eliminated the Sony card reader and now use a Lexar card reader, and I plug the Lexar card reader directly into a computer USB outlet, not through a hub. No more corruption problems when downloading.
2. Corruption of old photos--this affected about 200 photos out of 13,000 on my hard drive. They were all taken before December, 2007. What happened December, 2007? I bought a new desktop computer, and tried to transfer files from the old desktop to the new using "Laplink PCmover Essentials: Migrates applications with Easy Transfer cable." This software and cable made a mess of many of my programs. Maybe XP to Vista created additional problems. Anyway, I think these 200 photos got corrupted during various transfer attempts and computer crashes from old computer to new computer. I didn't discover these corrupted photos until recently, where it appeared Elements 5.0 Organizer (before I bought Lightroom) was corrupting them before my eyes, but of course it was seeing thumbnails from memory at first, then the actual photo with corruption. I think my backups were bad because a few months ago my external hard drive failed so I had to back up all my internal hard drive photos from scratch to my new external hard drive. At the time I thought all my photos were intact and fine.
So I hope my diagnosis above is correct and I can move forward. I have revised my backup procedures. How to repair the 200 corrupted photos? I don't think I can, bummer, but may try a few ideas and am open to your suggestions.
Good luck folks!
Tom W
YES A POSSIBLE SOLUTION (cut-to-the-chase at the bottom):
my equipment:
iMac - 2.33Ghz core2duo - 4GB RAM - Snow Leopard
External USB 1.5TB+ where the RAW files go
Lexar firewire 800 CF card reader (this was introduced into my workflow... things started to get corrupt when I factored this into the equation)
Genaric USB card reader
16GB Kingston @ 133x (a few of these... could be the problem too)
16GB SanDisk Extreeme III 30MB/s
5D mkii
Lightroom 2.5 (CAMERA RAW 5.5)
back story: I've only been searching for about a few hours (after I discovered the corrupt files). I called Adobe... not the people you want to call when you have a fustrating situation like this... cause you get and indian guys, who is hard to talk to and super slow and pretty much said there is no solution. He didn't see if there where other people who had this problem or ask another support person... just cannot fix it. Shame on Adobe for hiring people who are hard to talk to and don't really understand. Adobe support = F in my books.
Sorry, back to the backstory. I had no problems or any corrupt files until recently. I would get one here and there, but no to the point that ever twenty pictures a few in a series would be corrupt and have white and pink lines and such.
Possible problem: There could be multiple factors it could be, and I'm slowly pining them down. I ultimately think it is combination of equipment I have especially pertaining to the LEXAR Firewire 800 card and the Kingston 133x cards. I'm definitly gonna change up my combination of equipment. My speculation is I think the LEXAR 800 is ripping the files too fast from the card reader.
MY SOLUTION:
I faced the fact... this is an project from a month ago and I've used my CF cards numerous of times, so I know the pictures are gone... no way to recover them from the cards again. So I did find a program called FILE JUICER (mac only, sorry) that extracts the JPG from the RAW file. Works great... even better is that the JPGs are all 21 mega pixels, yippie! So thanks File Juicer for saving the day!
I hope the person who ends up with the same problem will find this post.
Thanks for this tip. I believe a few of my RAW photos got corrupted on import due to a faulty USB hub and a faulty Sony card reader. I salvaged a good part of my corrupted RAW files using the free PC software called "Instant JPEG from Raw" at http://www.rawworkflow.com/
I took these photos with my Canon 50D, set up for RAW only, no jpeg. This software still managed to extract a hidden 1 mb jpeg in each corrupted RAW file, and the jpeg was miraculously not corrupted. So a 1 mb jpeg is better than nothing! I imported these extracted jpegs into Lightroom 2 by specifyingCopy photos to catalogue without moving, Information to apply none and none. Also Preview--Minimal. I hope this never happens again!
By the way, I have some old corrupted photo files that are jpeg. This software extracted a small jpeg that was not corrupted from these jpegs, but the extracted jpeg is too small to be of much use to me.
Good luck!
Tom Wilberding
That's the embeded JPG preview, the thing you see on the LCD screen on
the back of your camera, I believe. All RAW files have an embedded
JPG, don't they?
Copy photos to catalogue without moving, Information to applynone and none. Also Preview--Minimal. I hope this never happens again!
Congratulations! Glad you were able to get back at least most of what
you needed.
Good luck!
Tom Wilberding
