Home/Support/
Forums
1 2 3 Previous Next 16457 Views 127 Replies Latest reply: Feb 6, 2012 4:18 PM by NEC271 RSS
wabbi2434 User 4 posts since
Oct 15, 2009
Oct 15, 2009 1:14 AM
Photoshop 10bit support
Hello!
There are 16 and 32bit modes in PS, so my question is: can PS display 10bit color depth per channel if all other components support it? (i.e. Windows 7, ATI FirePro graphics card,10bit monitor connected via Displayport)
If not, will there be an update/plugin? Will the next version of PS support it?
I'm thinking about upgrading. Wouldn't make much sense if the software doesn't support it…
Thanks in advance
Hermann
  • Mylenium Community Professional 15,741 posts since
    Oct 26, 2006
    1. Oct 15, 2009 2:18 AM (in response to wabbi2434)
    Re: Photoshop 10bit support
    What would you require that functionality for? 16pc and 32bpc already far exceed those specs and even though they are dithered down to be displayed on your LDR devices, that should be more than enough to work with. Additionally, 10/12/14bpc support would only make sense, if you worked with a file format that also stores that info natively as well as requiring a whole lot of other magic in the color profile engine, the print engine, filter handling and so on. So by all means, this is much more complex than just shuffling around a few bits and bytes in the display routines, which in turn means it's not coming any time soon. Definitely not for CS5 and most likely not for CS6, either. You have to understand that any software vendor will have to weigh the development effort agains how many users would actually benefit from such a feature and currently that is probably only a fraction of a percent, so it is not a must-have feature. This may change as wider gamut devices become more affordable and thus more widespread used as well as OSs supporting them, but for the time being it is something most people have no need for.
    Mylenium
  • Zeno Bokor Community Professional 5,447 posts since
    Mar 13, 2009
    2. Oct 15, 2009 2:41 AM (in response to Mylenium)
    i think that he might be talking about output, support for 10bit monitors. The answer is no, Photoshop doesn't currently support that
    http://forums.adobe.com/message/2034801#2034801
  • klsteven-vBdprK User 259 posts since
    Dec 2, 2006
    4. Oct 27, 2009 4:37 AM (in response to wabbi2434)
    I`d also like to see 10bit display output in CS5. I have the impression that 10bit displays will be affordable soon. Some years ago a wide gamut display was extremely expensive. Now you can get very affordable Wide gamut displays. Same will happen with 10bit displays. There is the HP Dreamcolor and also 2 new Eizos for around 2000.-. Not cheap, but not totally out of reach. Would not surprise me, if you can get a 10bit display for 1000.- in one or two years from now. At this time many people will use PS CS5. So it should support 10bit display output.
    I once had a small program that simulated 10bit output via temporal dithering (or so). I tested many pictures. Some of the pics showed (very little) banding in certain areas (in PS and in the other program (when 10bit dithering was disabled). But you never knew wether the banding was in the file or because 8bit output was the limiting factor. When I enabled the 10bit output, you could see that in some of the files the banding went away. In other files it did not. So it was clear what was the reason for the banding. Sometimes the files, sometimes the 8bit display output.
    So if you want to judge your files on a very critical level 10bit output would really help.
  • Gustavo Del Vechio User 76 posts since
    Jun 5, 2009
    5. Oct 27, 2009 1:13 PM (in response to wabbi2434)
    I told "A file format caller Kodak CINEON is a 10 bit"
    I review it....3 channels together compose 10 bit in CINEON..
    Message was edited by: Gustavo Del Vechio
  • Chris Cox Adobe Employee 10,426 posts since
    May 20, 2006
    6. Oct 27, 2009 1:05 PM (in response to klsteven-vBdprK)
    Photoshop can't support greater than 8 bit/channel output yet.
    We tried, and the APIs still had problems.  We're working with the vendors to resolve those problems. (and trying to find good displays to test with that *really* output 10 bits or more per channel).
  • Mikrotom User 8 posts since
    Dec 9, 2009
    7. Jan 31, 2010 6:20 AM (in response to Chris Cox)
    Chris, please, can you present actual state of Adobe aproach to implement 30bit color depth viewing in Photoshop CS5? I am writing little article about whole 30-bit viewing situation and it will be fine to have right information. Thanx in advance.
    Dec 2, 2006
    8. Jan 31, 2010 6:40 AM (in response to Mikrotom)
    In addition to Mikrotoms request I would like to know, what would be needed to display 10 bit, IF CS5 (or later) would be able to do it.
    What OS, what graphics card (only Quadro, or also "Consumer"-card), what monitor? Would this Eizo do it:
    http://www.eizo.de/monitore/color-graphic-lcds/24-zoll/CG243W.html
    According to specs it can display 10bit, although only by dithering.
    Dec 9, 2009
    9. Jan 31, 2010 7:57 AM (in response to klsteven-vBdprK)
    This is really easy nowadays. Windows 7 has native support for 30-bit color depth, nVidia produces complete row of Quadro FX card with 30-bit color depth (even ATI does with FirePro cards), drivers are working good, DisplayPort can transfer 30-bit content to displays and HP/EIZO/others made lot of LCDs with native 30-bit support. The one and only missing piece of chain is SW application wich will be capable to utilize new API functions and manage out true 30-bit per channel output...
  • dec9 Contributor 4,227 posts since
    Aug 20, 2007
    10. Jan 31, 2010 9:16 AM (in response to wabbi2434)
    Since the ability to detect color differences varies greatly between humans anything above 24 bit is a waste of time. Unless a woman is a tetrachromat.
  • Hudechrome-sd9sPI User 3,330 posts since
    Aug 11, 2002
    11. Jan 31, 2010 11:01 AM (in response to dec9)
    It would not make much sense to have 10-12-14 bit functionality for monitor purposes if the other output devices didn't. Banding for instance. How much aggravation would be encountered to see banding in a print which isn't present on screen? I would want to be forewarned.
    It would be interesting if klsteven could print examples of both images displaying banding in 8 bit but certain images in 10 bit did not band, on a 16 bit printer. I believe canon has 16 bit printers.
    Banding is my #1 concern these days. Agressive moves with Shadow/Highlight followed by agressive moves in Black and White produce serious banding (as well as other noise components, but the banding is a deal breaker). I could, of course, test it myself and see if the 16 bit file which shows banding on screen and in print shows on the 16 bit printer. Probably will.
    Dec 9, 2009
    12. Jan 31, 2010 11:04 AM (in response to dec9)
    This is common mistake. You definitely need much more than 256 color steps in each channel. Creative photography in BW usually produces lot of banding in smooth transitions between black-greys-whites...
    Aug 11, 2002
    13. Jan 31, 2010 11:33 AM (in response to Mikrotom)
    Well, I wouldn't call it a mistake!
    I've explored it sufficiently that I have tentatively ruled out equipment problems, so it comes down to limits of processes.
    I first encountered it years ago with a scanned image of a mountain reflected in a mirrored surface of still water. The banding in the sky's reflection blew me away.
    It's at least one of my legacy images that cannot be adequately handled in digital form. Curiously, returning to that site at the appropriate time with a digital camera did not show banding until I made the conversions. Then it was the sky that banded!
    I have some workarounds but they do not always work.
    Aug 20, 2007
    14. Jan 31, 2010 1:02 PM (in response to wabbi2434)
    If the reviews can be trusted for the Eizo. I did not look in the Eizo forums for the real story.
    I did check out the new Dell U2410, just for the heck of it, and the reviewers love it and it has no problems. However, in the Dell forums there are all sorts of Dithering problems and Photoshop problems found in a 7 page thread with the ICM that Dell has duplicated. A fix is in the works. So everything a person reads on the net is not exactly fuzzy kittens.
    Aug 11, 2002
    15. Jan 31, 2010 1:44 PM (in response to dec9)
    Test, test test!
    Aug 20, 2007
    16. Jan 31, 2010 8:43 PM (in response to Hudechrome-sd9sPI)
    Ha, you love it don't cha.
    Dec 9, 2009
    17. Feb 1, 2010 1:24 AM (in response to Hudechrome-sd9sPI)
    It cant be tested any way, because there is not such a application with abilities to display 30-bit content... It is not just Adobe who is little bit behind HW. Even ACDSee and all of other viewers does not displays content using real 30-bit output :-(
    Dec 9, 2009
    18. Feb 1, 2010 1:22 AM (in response to klsteven-vBdprK)
    List of current LCDs with true 30-bit display abilities (input, inner calculations and panel):
    Hewlett Packard - LP2480zx DreamColor (24″, S-IPS, 1920 × 1200, 100% Adobe RGB, 12-bit LUT, DP, LED)
    Eizo - SX2262W (22″, PVA, 1920 × 1200, 95% Adobe RGB, 12-bit LUT, 16-bit, DP, CCFL)
    Eizo - SX2462W (24″, H-IPS, 1920 × 1200, 98% Adobe RGB, 12-bit LUT, 16-bit, DP, CCFL)
    Eizo - CG243W (24″, H-IPS, 1920 × 1200, 98% Adobe RGB, 12-bit LUT, 16-bit, DP, CCFL)
    Eizo - CG232W (22,5″, S-IPS, 1920 × 1200, 97% Adobe RGB, 12-bit LUT, 16-bit, HD-SDI, CCFL)
    Dell - UltraSharp U2711 (27″, IPS,  2560 x 1440, 98% Adobe RGB, 12-bit LUT, 16-bit, DP, CCFL)
  • Bill_Janes User 555 posts since
    Jul 22, 2006
    19. Feb 1, 2010 6:35 AM (in response to Mylenium)
    Mylenium
    Opinions vary on how many levels the human visual system can distinguish. 8 bpc may be sufficient to prevent banding, but barely so. However, 10 bpc on the system and software side would allow an extra two bits for calibration. Some high end monitors do have 12 bit LUTs for this purpose, but does it make sense to have two LUTs?
    Aug 20, 2007
    20. Feb 1, 2010 8:47 AM (in response to Bill_Janes)
    For me, having 2 LUT monitors, would be a waste of money for what I do.
    Aug 11, 2002
    21. Feb 1, 2010 9:37 AM (in response to dec9)
    Love testing is an oxymoron. Ask any test engineer!
    As for untestable, it's a matter of perspective. And ingenuity.
    Dec 9, 2009
    22. Apr 12, 2010 12:20 PM (in response to wabbi2434)
    So, what is the situation in CS5? Does anybody already knows? Still no 10-bit per channel color output?
    Mar 13, 2009
    23. Apr 12, 2010 12:27 PM (in response to Mikrotom)
    Nope, still no support
    May 20, 2006
    24. Apr 12, 2010 2:22 PM (in response to Zeno Bokor)
    Actually, the 10 bit/channel display path is working quite well in CS5 - on cards and displays that support it.
    Again, we've been working with the manufacturers for a while to get it working...
    Dec 2, 2006
    25. Apr 12, 2010 3:05 PM (in response to Chris Cox)
    Chris, that great news. I guess, you should make that public so that users know this as a CS5 feature. Do you know wether the new Fermi cards will output 10bit or will Quadro cards be required? And what about ATI?
    May 20, 2006
    26. Apr 12, 2010 3:30 PM (in response to klsteven-vBdprK)
    I don't have all the details on hand.  We should be documenting the requirements for 10 bit display when we get closer to shipping.
    Dec 2, 2006
    27. Apr 24, 2010 4:04 AM (in response to Chris Cox)
    Chris,
    I still couldn`t find anything in the system requirements for PS CS5 for 10bit output. Where will I be able to find details?
  • shoot me now-d3u3se User 430 posts since
    Aug 11, 2002
    28. Apr 24, 2010 4:19 AM (in response to klsteven-vBdprK)
    Well great. I just bought a NEC P221 because I didn't see any need to spend fancy money on hardware that couldn't live up to its potential. While the NEC has a 10 bit internal LUT, it has only DVI connections and so is doomed to receive 8 bit input forever.
    Still, it's the nicest monitor I've had that wasn't a CRT.
    Now, to recap. Win7 has high bit capability and CS5 apparently has it under the hood somewhere. So, THIS generation of hardware and software finally gets us there?
  • SDHD2010 User 1 posts since
    Apr 29, 2010
    29. Apr 29, 2010 4:34 PM (in response to shoot me now-d3u3se)
    there's support with Firepro from ATI: http://www.amd.com/us/Documents/ATI_FirePro_Adobe_10-Bit_FAQ_030910.pd f
    It works with CS5 on Win7.
    May 20, 2006
    30. Apr 29, 2010 6:21 PM (in response to klsteven-vBdprK)
    We haven't documented it yet - we're still working on it. (yes, there are more complications than you could imagine)
    Dec 2, 2006
    31. Apr 30, 2010 2:27 AM (in response to SDHD2010)
    SDHD,
    That PDF is very interesting. Did you try it with this card and CS5?
    Do you also have a link to something similar from nvidia?
    I`m wondering why this feature is only available to the pro cards. I guess, it`s not expensive.
    Some day I guess it will be standard to all cards.
  • laglaph User 4 posts since
    Sep 18, 2009
    32. Apr 30, 2010 3:04 AM (in response to wabbi2434)
    I asked Adobe support about 10bit/colour channel support and the Nvidia Quadro FX1800 and they referred me to the after effects OpenGL supported card document.
    www.adobe.com/products/aftereffects/opengl.html
    It does not mention 10bit/colour channel at all.  Why can't we get a straight answer? like "no", "yes", "we are still working on it" rather than pretend answers?
  • emaini User 36 posts since
    Apr 30, 2010
    33. Apr 30, 2010 10:12 AM (in response to wabbi2434)
    Hello, I am new to the forum in terms of posting.   I usually only read the responses but 10-bit support peaked my interest to the point that I felt like posting.  I apologize if the question is stupid but I have had this lingering question for a long time
    My understanding is that to get 10-bit color a lot things need to come together
    The underlying OS has to support it
    The Video Card needs to support it and you need use DisplayPort
    The Monitor has to have a 10-LUT (or in the case of the new NEC PA24W, a 3-D LUT) and supports wide gamut aRGB
    The Video Driver has to support it so that software can be written against it
    Finally, Adobe PS has to write software maybe even specific to a card/driver to display the information correctly
    Then, I assume, so that all this work is not lost, I assume you need a 16bit printer driver as well to complete the workflow (which I believe Epson has at least on the Mac but I do know that Vista/Win7 does support)
    So, given the above and given that many tutorials today prior to CS5 say "Work in aRGB or ProPhoto", how does one do that if all we have is 8bit sRGB monitors?  Can we possibly see the difference?
    I am just trying to understand how tutorials and books tell us to use wide gamut color spaces when we all have sRGB and PS only to this point only supports sRGB and we only just now have the possiblity of getting 10-bit wide gamut support.
    I am obviously missing something or don't understand what is happening under the hood.
    Hopefully my response is not stupid and someone more knowledgeable can explain.
    May 20, 2006
    34. Apr 30, 2010 4:00 PM (in response to laglaph)
    Read what I already said.
    Yes, "we're still working on it".
    Dec 9, 2009
    36. May 19, 2010 3:59 AM (in response to Chris Cox)
    I can confirm that PS5 still does not displays pictures in 10-bit per channel format. Its a shame. Once again SW is far behind HW...
    Dec 2, 2006
    37. May 19, 2010 4:33 AM (in response to Mikrotom)
    Mikrotom,
    which graphicscard, OS, monitor and monitorconnection (displayport?) did you use? And how could you tell, which bitdepth is displayed?
    Dec 9, 2009
    39. May 19, 2010 7:08 AM (in response to klsteven-vBdprK)
    Tested it on nVidia Quadro FX1800 + EIZO SX2462W connected via Displayport + Windows 7 Professional 64bit + actual drivers and patches.
    I simply draw a grayscale gradient and can clearly see steps /banding/ between each color. When i switch mode of file to 8-bit per color, the picture remains the same
    Dec 2, 2006
    40. May 19, 2010 10:19 AM (in response to Mikrotom)
    Mikrotom,
    there still may be one component that could cause the banding you see: The monitor color profile itself. Maybe you could use sRGB as monitor profile just for test purpose and try again. Maybe you also should disable any LUT loaders and also reset the monitor to its default settings just for testing.
    May 20, 2006
    41. May 19, 2010 12:46 PM (in response to Mikrotom)
    Not really. The HW (and drivers) aren't quite ready for prime time.  We're still working on it.
  • Aleve Sicofante User 9 posts since
    Aug 12, 2010
    42. Aug 12, 2010 10:57 AM (in response to wabbi2434)
    Has there been any progress about this? I'm about to configure a system for a customer and I'll be using a NEC PA241W monitor, which supports both extended gamut and 10-bpc input.
    Windows 7 is ready.
    NVidia Quadros are ready.
    Is Photoshop CS5 definitely ready?
    Any official documentation on the subject yet?
    May 20, 2006
    43. Aug 12, 2010 3:43 PM (in response to Aleve Sicofante)
    AMD/ATI has some driver tricks that enable 10 bit in some cases.
    But our full support is still waiting on driver testing.
    Aug 12, 2010
    44. Aug 14, 2010 2:45 PM (in response to Chris Cox)
    Thanks Chris, but from your reply I don't quite get if you mean you're testing ATI drivers or drivers in general. Nvidia officially supports 10 bpc output on their Quadro drivers (NOT on the GeForce series), that's why I have selected them for my Photoshop customers' builds.
    So may I ask specifically if you currently provide support for the Nvidia Quadro series, since their drivers do officially support 10 bpc?
    May 20, 2006
    45. Aug 16, 2010 6:34 PM (in response to Aleve Sicofante)
    We are testing drivers in general.
    We can't say which cards/drivers we'll support at this time.
    Dec 2, 2006
    46. Aug 17, 2010 2:45 AM (in response to Chris Cox)
    Chris,
    could you try to convince nvidia that they should support 10bit output also on the Geforce cards and not only on their Quadros? IMO there`s no need for a Quadro for Photoshop and so I guess 99,99% of PS users don`t have a Quadro. I`m pretty sure that the Geforce hardware can do 10bit and only the drivers are limited. Since nvidia and Adobe seem to cooperate very well, maybe they listen to you.
    Aug 12, 2010
    47. Aug 17, 2010 5:37 AM (in response to klsteven-vBdprK)
    I don't know how much pressure Chris or Adobe can put on Nvidia, but I definitely second that. My customers cringe at the price when I tell them they need a Quadro for a 10 bpc workflow.
    EDIT: Oh, and I'm positive about it being just a drivers issue. I'm in conversations with some manufacturers who offer GeForce cards with DisplayPort and they say it's just the drivers that don't allow them to put 10 bpc on the output.
  • Dorin Nicolaescu-Musteață Contributor 3,090 posts since
    Apr 4, 2008
    48. Aug 17, 2010 6:14 AM (in response to wabbi2434)
    I might be wrong, but why not just dither 16-bit data for 8-bit display, as Lightroom 3 does, for example? Even the finest gradients seem to look really smooth for all practical purposes. At least there's no need to depend on third parties (displays, graphics cards, drivers, OSes).
    Or am I missing something obvious (not so obvious)? Is anyone willing to educate me?
    May 20, 2006
    For the same reason you don't sprinkle salt on broken glass and call it a window.
    Photoshop already dithers when going to the display, because that's the only real option available.
    But the 10 bit display path is much higher quality.
1 2 3 Previous Next
Actions
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
