Andrew.Groom
Macromedia Dreamweaver 8 - Crashes on opening
Oct 28, 2009 3:44 PM
I have successfully been using Dreamweaver 8 for a few months, then suddenly this morning on opening the program, it would not start. It was closed succesfully the night before but this morning, the program try's to open but the opening box loads up to "Initalizing CSS styles" then just sits there. I have tried opening a number of times, uninsatlled and re installed it, and finally did a system restore to the night before, it all does the same thing. ITS SOO FRUSTRSTING!!! Can anyone help with this, i am really desprate.
I welcome any suggestions,
Andrew
    Oct 28, 2009 3:51 PM   in reply to Andrew.Groom
    i experienced the same thing ... been using it for 3 years and this morning it did not work. worked with adobe ALL day -- 6 different techs and multiple customer service techs. not until just now ... they infomed me that they do not provide tech support for 8 anymore ... after all day of people knowing.
    yes ..frustrating. sorry no sulution ... just the same exact timing and situation. i think they are forcing the upgrade for $199 .. which due to deadlines and absolutely no anwers ... is the only solution. nancy
    they also gave me these links:
    1 -- this one
    2 -- adobe.com/go/supportportal
    might be something online in a google search. good luck!
    Oct 28, 2009 4:47 PM   in reply to Andrew.Groom
    yep - same. just downloaded the upgrades and tried that ... still crashes. out of time and patience ... so getting closer to the desparate upgrade~ you can do the 30 day free trial of dreamweaver CS4 if you need to do something soon ... and deal with customer service in relaxed time. my tech guy said that the second link .. supportportal ... will get back to you in 4 hours .. just provide as much detailed info as you can ... operating sytem details . every little detail. might work.
    try this:
    http://kb2.adobe.com/cps/401/kb401096.html
    I also just got this email from tech support Adobe:
    h6. This is from the DW FAQ Page
    http://forums.adobe.com/thread/429114
    h2. Crashes, installation, JavaScript errors, and unexplained problems
    If Dreamweaver is acting erratically, or if you see a message saying "the following JavaScript error(s) occurred",  it's usually a sign of a corrupt cache file. The first thing to try should always be to delete the file cache. If that doesn't work, delete your personal Configuration folder. Full instructions are in /thread/494811.
    * /thread/437079
    * /thread/494811
    * /thread/417116
    * /thread/494812
    Oct 28, 2009 4:35 PM   in reply to Andrew.Groom
    If Dreamweaver is acting erratically, or if you see a message saying "the following JavaScript error(s) occurred",  it's usually a sign of a corrupt cache file. The first thing to try should always be to delete the file cache. If that doesn't work, delete your personal Configuration folder. Full instructions are in Deleting a corrupted cache file.
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    www.alt-web.com/
    www.twitter.com/altweb
    www.alt-web.blogspot.com
    Oct 28, 2009 4:56 PM   in reply to Andrew.Groom
    Re: Macromedia Dreamweaver 8 - Crashes on opening
    cache file.
    CS4 installation problems
    Dreamweaver crashes on start up
    Locating your personal configuration folder
    Nancy O.
    www.alt-web.com/
    Oct 28, 2009 5:12 PM   in reply to Andrew.Groom
    congrats! still no luck here ... but it does go through the update of site cache .. then still crashes. any ideas??
    Oct 28, 2009 6:03 PM   in reply to nancy hauck
    Hi Nancy H,
    Did you try deleting the personal config folder?
    Which OS are you on?
    (if win - not being condescending, just checking bases here)
    Did you receive an OS update recently?
    Any chance you picked up a virus or trojan, have you run an anti-virus scan of your HD lately?
    Have you run Clean Disk & Disk Defrag lately?
    Nancy O'Shea
    www.alt-web.com/
    Oct 28, 2009 6:37 PM   in reply to Nancy O.
    just did this ... but did not realize that removing site definitions meant removing all the style sheets .. so all info is there but no style .. and can't figure out how to GET files ...if that would even work .. not sure. -- IF I just upgrade . will that work?? -- also .. i restored old site definitions .. so even more confused.
    11. Re-create the Dreamweaver Site preferences.
    Re-create the Dreamweaver Site preferences file to eliminate problems that a damaged Site preferences file might cause.
    Note: Re-creating the Dreamweaver Site preferences file will remove all site definitions.
    To re-create the Dreamweaver Site preferences file:
    1. Quit Dreamweaver.
    2. Do one of the following:
      • If you're using Dreamweaver CS3, rename the Users/<username>/Library/Application Support/Adobe/Common/9/Sites/Site Prefs file to Site Prefs Old.
      • If you're using Dreamweaver 8, rename the Users/<username>/Library/Application Support/Macromedia/Common/8/Sites/Site Prefs file to Site Prefs Old.
    3. Start Dreamweaver. Dreamweaver creates a new Site Prefs file.
    If the problem continues, then the Dreamweaver Site preferences file isn't the cause. To restore site definitions, quit Dreamweaver, then delete the new Site Prefs file and restore the original name of the previous Site Prefs file.
    Apr 19, 2011 8:05 PM   in reply to Andrew.Groom
    Sounds like a currupted file, take a read here
    http://forums.adobe.com/message/2350147
    GAry
