zolouchka77
Unable to create / open file
Oct 29, 2009 10:19 AM
hi
i try to create pdf with Output Service API Quick Starts, i copy code in the file in
Web service API so i call my output service.
i have a modele ComdeDynamiq.xdp
i have  a  xml file for merging : PurchaseOrder.xml
i add to url service ?blob=base64
but my method generatePdfOutput don't run at all : no file generate
and in my file output.xml where i put data in generatepdfOutputResultDoc.BinaryData there is :
<?xml version="1.0" encoding="UTF-8"?>
<printResult>
<status>2</status>
<requestId>611e915ba</requestId>
<context>7</context>
<messages>
<message>Unable to create / open file C:\creerPdf\Res.pdf.</message>
</messages>
<printSpec/>
</printResult>
i don't knom what doesn't run in my code?? i give it in attach files? is there somoene which could help me??
thanks
my code is below :
using
System;
using
System.IO;
using
System.Collections;
using
System.ComponentModel;
using
System.Data;
using
System.Configuration;
using
System.Web;
using
System.Web.Security;
using
System.ServiceModel;
using
WebReference;
<summary>
Summary description for outPut
</summary>
public
class TestOutPut
public TestOutPut()
// TODO: Add constructor logic here
public void Essai()
try
// Appel du service output
OutputServiceService outPutClient = new OutputServiceService();
outPutClient.Url +=
"?blob=base64";
outPutClient.Credentials =
new System.Net.NetworkCredential("administrator", "password");
//creation d'un blob pour stocker les données du fichier
BLOB inData = new BLOB();
//reference du fichier xml à merger avec le modèle :
String inPutFile = @"C:\\creerPdf\\PurchaseOrder.xml";
FileStream fs = new FileStream(inPutFile, FileMode.Open);
//on récupère la taille du flux du fichier et on crée un tableau de byte :
int longueur = (int)fs.Length;
Byte[] byteArray = new byte[longueur];
//on remplit le tableau de byte avec le contenu du file stream :
fs.Read(byteArray, 0, longueur);
//on rempli le blob
inData.binaryData = byteArray;
//option de run time du pdf
PDFOutputOptionsSpec pdfOptions = new PDFOutputOptionsSpec();
pdfOptions.fileURI =
"C:\\creerPdf\\Res.pdf";
pdfOptions.lookAhead = 300;
pdfOptions.generateManyFiles =
false;
pdfOptions.recordLevel = 1;
//render options :
RenderOptionsSpec renderOptions = new RenderOptionsSpec();
renderOptions.cacheEnabled =
true;
//Create empty objects to pass as arguments
//to the generatePDFOutput method
//These objects are populated by the method
BLOB generatePDFOutputMetaDataDoc = new BLOB();
BLOB generatePDFOutputResultDoc = new BLOB();
OutputResult outResult = new OutputResult();
//On crée le doc pdf
outPutClient.generatePDFOutput(
TransformationFormat.PDF, "BonCmdeDynamiq.xdp", "C:\\creerPdf\\", pdfOptions, renderOptions, inData, out generatePDFOutputMetaDataDoc, out generatePDFOutputResultDoc, out outResult);
//On ecrit les données vers output.pdf
//on rempli un tableau de byte avec les données de sortie
byte[] outByteArray = generatePDFOutputResultDoc.binaryData;
//On crée un nouveau fichier pour stocker les données
string FILE_NAME = "C:\\Adobe\\Output.xml";
FileStream fs2 = new FileStream(FILE_NAME, FileMode.OpenOrCreate);
//on ecrit le flux de données
BinaryWriter w = new BinaryWriter(fs2);
w.Write(outByteArray);
w.Close();
fs2.Close();
fs.Close();
catch(Exception ee)
Console.WriteLine(ee.Message);
    Oct 30, 2009 4:57 AM   in reply to zolouchka77
    Your code looks like you are trying to access one of the provided LiveCycle services (generatePDFOutput), so you don't need to create a workflow in LiveCycle Workbench.  Output provides the endpoint out of the box.
    It looks like your writing code in .Net, so there are a couple of things you can check.
    1 - you have a web reference OutputServiceService, does that point to the right LiveCycle server?
    2 - on the LiveCycle side is there anything in the log?  Is the request even getting to the LC box?
  • krishHexaware
    Dec 16, 2011
    Jan 12, 2012 9:58 PM   in reply to zolouchka77
    Hey,
    i am very new to adobe live cycle development.
    I hjave tried ur code to create dynamic PDF generation, it works fine but it is generating readonly PDF.
    I am not able select from dropdodn and also not able to enter in text box.
    could you please help and suggest me on this.
    Thank you
    Jan 13, 2012 5:42 AM   in reply to krishHexaware
    This is what the Output aspect of the product does; generate documents - no interactivity.
    For interactive PDF Forms - see the Forms aspect of the product
    Different set of API / Services; using same Designer form template.
  • krishHexaware
    Dec 16, 2011
    Jan 13, 2012 5:44 AM   in reply to Neal G. Davies
    could you please help me to get PDF on the fly from XML.
    which service API i should use to achive this
    Jan 16, 2012 6:14 AM   in reply to krishHexaware
    Sorry I am not a programmer but this page should help point you in the right dirction
    http://help.adobe.com/en_US/enterpriseplatform/10.0/WorkbenchHelp/WS92 d06802c76abadb-1cc35bda128261a20dd-7fb1.html
    Look at the renderPDFForm operation
