The most accurate answer comes from (Ping_Zheng).
Thanks mate.
I am having this problem too. I have always scanned through PS using Twain. But now I have new PS - CS4 and new scanner - Canon pixma MX 330. When I go to Import, there are no options to scan. I also don't see anything like WIA support there.
I ended up using the software that came with the scanner but it is very VERY awkward to use.
Any suggestions?
Not SURE my facts are correct plus I use an Epson scanner so this may not be informative to you. I think WIA is just a Windows program to run a scanner. However it is very basic with only simple settings. Not ideal for quality scans. I've never used it. If it were an printer, rather than a scanner, for instance, you would not be able to print at best settings for best print.
In the past, (CS1) I did use twain but all it did was bring up my Epson scanner software. Since PsCS4 I just use Epson scanner software and save in a folder I call SCANS. I then open from Bridge into Photoshop.
I don't understand when you say the software for your scanner is very awkward. There is nothing in Photoshop that tells your scanner what settings to use for scanning. That HAS to be done in your scanner software. I would think that Canon would have pretty straight-forward software.
it is awkward because I can NOT use PS. the software that comes with the scanner is very complicated to use - to find the image and where to save it and all. When I used to use CS2 and my Twain/epson setup, the image would just pop up on the screen after scanning. this software does not do that - it is a pain...
I would like to just import through PS if anyone has a clue. and I am on a Mac.
thanks
thanks
I was about to ask which version of Windows you have till I saw you are on a Mac.
Ask here:
http://forums.adobe.com/community/photoshop/photoshop_macintosh
You can scan using Photoshop, if you take the risk of installing the TWAIN plugin.
But so many buggy scanner drivers have been causing crashes for our customers that we moved the TWAIN plugin to an optional install. We tried for many years to get the scanner vendors to fix the bugs in their drivers, but the number of crashes due to scanner drivers just kept going up.
Do you want crashes, or convenience?
Your scanner comes with stand alone scanning software -- if that crashes, you don't lose the rest of your work in Photoshop.
MartyR707 wrote:
I am still mad at Adobe for discontinuing support for GoLive. They even took their discussion boards down!!
What's this then?
http://forums.adobe.com/community/golive/golive_general_discussion
Since PsCS4 I just use scanner software and save in a folder I call SCANS. I then open, from Bridge, into Photoshop. On some days, I do dozens of scans. I don't see how this is a burden. It actually seems more efficient. Did you purchase a "high end program" to do photo editing? If so, Photoshop seems to be a great choice. Did your scanner not come with software?
MartyR707 wrote:
The scanner came with software. It is just cumbersome to use.
No one reads Post #3. Michael posted this: Or better yet use VueScan from http://www.hamrick.com.
I have used it in the past. Excellent. Just check your scanner is covered and go for it...
Hi there, bumped in this thread trying to use my new Canon mp 640 to scan a photo on Office 2003. It seems they've done away with the (Insert from Scanner) just like PS CS4 has done with file acquire twain - I read most of the posts here, some say the new scanner install should create menu on the programmes (all of them??), Adobe employee says they dropped it because of too many crash with it. I, too, come from PS cs2, it was a breeze to acquire a pic into ps cs2 -There may be progress but some is just going backwards. Perhaps for the savies and those who use it every day it's just a matter (and must) of getting use to it. as for the rest of us....?
For what it's worth! I looked in W7 under 'Devices and Printers" and there were listed some of the printer's multifunctions one was "scanner". from there I was able to start and import from its scanner the import was defaulted to Library/picture and video I think, and as someone said previously I guess it's just a matter to chose an appropriate folder if one does not like this folder. Still does not solve my problem with Office - ok, yes I can import from that folder too into office! Oh I forgot, for those who don't know, pictures from any folder can be dragged into PS it easier to import once that particular folder is open.
All these years I have used office 2000 that I found very simple but recently I updated a lot of stuff. WXP to W7 64 bits, Was given an oem copy of office 2003 so installed it and trying to get used to it. CS2 suite to CS4 because I just bought a High Def. camera, well all is out of whack now. an heaps of software won't work anymore. I'm just about to update brain 1942 to brain 2011 I'm not sure it's out but I really need it. Meanwhile you might be able to explain to me how to insert from scanner in Office 2003 as for me under "insert" there's no "from scanner" facility.
Thanx DC9
I have a CanoScan 8800F, which I can use through Twain (PSE, CS5/32-bit) or WIA (also with CS5/64-bit). The WIA interface offers only very rudimentary functionality (eg no activation of backlight for scanning transparencies). I don’t buy the argument that I should not tie up a $1000 piece of software for $200 (or so) piece of hardware. When I scan, and particularly when I scan old off-color slides, I don’t know beforehand if I can salvage the image with post-processing or if I should adjust the scanner settings. If I scan from Photoshop, I can adjust color and tonality, and I fail to salvage the image, I can re-scan with different settings, while the slide is still in the holder.
Some say that it is silly to a tie up a $1000 piece of software for $200 (or so) piece of hardware. What, then, do you call investing money and learning time for another piece of software if I already own Photoshop and can use it?
The present implementation of the Twain scanning with the 8800F is suboptimal, however. For instance, if I have been scanning slides and the scanner driver is set up for color transparencies, and I then configure the scanner for scanning paper (by removing the slide holder and inserting the back plate which blocks the backlighting), my next attempt to scan aborts with an error message that the scanner is unable to scan slides, probably because the backlighting is blocked. The scanner UI, along with the tab for adjusting scanner settings, is visible in the background, but I can’t access it because of the error message. And when I acknowledge the error message, the scanner UI disappears. I must physically re-configure the scanner to scan slides, then select paper scanning (in the software) and again re-configure the scanner for scanning paper.
Best regards,
Antero
You should always adjust the scanner settings to the best possible result before scanning. Just leave a little headroom to avoid clipping.
Epson software has curves and levels and a big preview window. I used to have a Canon scanner, and as far as I recall it had pretty good pre-scan adjustments as well.
