Hello all
I am encoding using the latest FMLE from a Niagara 6116 (osprey) SDI input (PAL)
544kbps video, 56kbps audio, Main profile, level 3.0, input 640x360, encoding to 480x270, CPU Never topping more than 55% but the output from Main Profile looks like the frame rate is about 15fps, the encoder reports a steady 25, the input is 25. If I change to baseline then it looks fine.
I would like to use the main profile to get as much quality out of this as possible.
Any ideas? Suggestions?
I am having exactly the same issues.
I have input from SDI card. All other formats work well (vp6, h264 baseline) and cpu (quad core xeon 2.0) never goes over 50%, but when switching to main profile h264 encoding the video appears to be stuttering or as MatthewQuinn is reporting looking like a lower framerate.
Is there any solution to this problem?
Im using PAL, the source is interlaced so I put on the deinterlace option. I have tried without deinterlacing, but the problem remains.
I noticed that if I change the quality in flash player in the browser window from high to low the framerate appears to be smoother (but with visible pixels). Im unsure about if there is a difference between high and medium. This is no issue due to low lack of CPU in the client PC since CPU never goes high.
If adobe comes up with a solution I would be happy if you could post it here in the forum (:
Same to me, I was looking for an answer too...
I'm trying to stream in PAL and all I can tell is that for sure this is not a matter of CPU power, neither RAM or bandwidth lack. I've tried every possible combination of bandwidth, resolution or any other setting but nothing to do: in "baseline" setting, the stream is perfect (in smoothness but with some artifacts), but using "main" (which would give a perfect image) the stream starts to frameskip regularly as if it does 15 fps or so. Also this happens in WinXP and in Win7 too. Some other test:
-Tried almost 3 differents acquisition cards (Pinnaclesys, Terratec and other) thinking that it could be a matter of drivers, but nothing.
-Tried to play the stream in the same streaming PC. Nothing.
-Tried to play the stream in the same server (FMS) PC. Nothing.
-Tried to play from a third PC which is neither streamer nor server... Nothing.
-Tried installing the server on the same PC that is streaming (this to exclude some bandwidth problem). Nothing.
-Tried to install the server in a PC into my local net... Nothing (again, it looks like the problem is not bandwidth-related).
The input and the output preview windows in Flash Media Live Encoder 3 both runs very well, never skipping a single frame! Trying to disable one or both of them changes nothing. Also tried downgrading from FMLE 3 to FMLE 2.5 changes nothing (yes, I've also tried this!)
A curious note: it's not a "real" frameskipping, it looks like this: after some number of frames which the stream appears to have the right speed, then some frame it's decelerated, then there's a little number of accelerated ones, and it's very regular in terms of time.
It's like you see someone walking regularly, then after some step he take a little slow step, and then a very quick step and you can see him where he should be if he was not slowing and hurrying (but you can notice this quick slow-fast motion). I saw a similar effect (much less noticeable) in TV News when they play some NTSC-converted-to-PAL video material (i.e. some reports coming from USA).
Hope to hear some news, thanks!
