Locked
Premiere Pro - Insufficient Media Error - Please help!
Sep 14, 2009 Sep 14, 2009
Hi, everyone!
I'm working in Adobe Premiere Pro (CS3), taking 3 thirty second video clips, and putting them together, along with an audio track, to make a 1:30 video background with music.
I'm trying to apply a short cross dissolve to each of the video clips. When I do, I get an error message that there is insufficient media and some frames will be repeated.
This is a mystery to me, because each of the thirty second clips is clearly longer than the cross dissolve transition.
The transitions seem to play fine in Premiere, but do not appear to show up in any render so far (I've tried .avi, .mov, and .wmv)
Any idea why I might be getting this error, and how I can correct the problem?
56.1K
LEGEND , Sep 14, 2009 Sep 14, 2009
my clips are longer than my transition in terms of duration.
I there any way I can "add" handles?
The full Duration of the Clips is long enough, but your Handles are not. These are "created" when you set the In & Out Points on the Clip.
If your Clip has a tiny triangle at the Head, and/or Tail, that means that it has zero Frames as Handles. Reset the In & Out Points to get the Handles.
Good luck,
Hunt
Start reading about handles. The help file is a good place to start. And get some basic education in video editing if you want to use PR. Consumer applications do not have this steep learning curve and may serve you better.
Participant ,
Nov 02, 2009 Nov 02, 2009
You know Harm I've read a number of your posts including some of your replies to me and in pretty much all of them you've come off as a jerk, contributer or not.  Telling him to go study video editing is not helpful at all.  I've used a number of other pro video editing programs and I've never had to do this in order to make a cross dissolve work, I just drop it in between two clips and it just works, unless I want it to work differently than a normal cross dissolve is supposed to, then I can change it.  Heck even older versions of Premiere didn't require this step.  Regardless of how Premiere works telling someone to go read the manual or go learn video editing is not what these forums are for, they're called support forums after all.
That depends.  If he does actually go off and study video and can then perform the task better, then it really was helpful.
Yes, you have.  Any proper transition needs handles.  This is a universal concept, and applies to all editors, all media, and all software programs.  Some programs, Premiere included, may try and 'cheat' the transition by repeating frames or with some other method, but that is not then a proper transition.
Yes, they have.  All NLEs always have, and always will.
I would argue that Premiere Pro, and hence these forums, are for those who have already learned video editing.
First lean, then do.  This applies to any activity.  Those who try and skip step one and show up here looking for help do often meet with some backlash.
Participant ,
Well SpeedEdit certainly doesn't.  I've never seen frozen frames in a transition like I do with Premiere Pro CS4 (If I don't adjust the handles first).  When I was first learning Premiere back in school years ago all I had to do was drop a cross dissolve between two clips and bam, a nice smooth dissolve from A to B, unless I specifically set it to do otherwise.
So you suggest that people should not come here to aid in their learning?  If that's the case I'll just move to CG Talk, I like learning on forums.
Contributor ,
Mar 01, 2013 Mar 01, 2013
I agree. This is a forum for Premiere Pro and people should feel free to ask questions about Premiere Pro in these forums.
Insufficient media error means your clips do not have handles.
Trim of 15 frames of the left clip on the right side and 15 frames on the left side of the right clip.
Then your transition will work properly and no error message,
Thank you, I will try that.
Can you clarify how I do this, Ann? I tried...went into Project Manager, did "Include Handles: 30 frames".
Then opened the new "trimmed" project.
I still get the error message.
Did I miss a step?
Here's some background on Handles:
Good luck,
Hunt
Thank you, Hunt! This is helpful, but my clips are longer than my transition in terms of duration.
Our video editors are tied up on other projects, so it's up to me to figure this out and finish up this project for the client.
Any help you can give is most appreciated!!!
Good luck,
Hunt
Two easy ways to set the In & Out Points on your Clips are:
In the Timeline, zoom in a bit. Click-drag on the Head, and/or Tail of the Clip, watching the Info Panel to make sure that you allow enough Handles for the Duration of the Transitions' settings.
These can also be set in the Source Monitor with the In Point bracket and the Out Point bracket.
Good luck,
Hunt
Ah, I understand now, Hunt - and it worked!
Thank you so much!
Great news. The concept of Handles is a bit abstract, when one first approaches it. Once the editor is able to make the connection, it's then clear from then on. For me, it was easy, as I came from a cine background. We did not call them "Handles" back then, but they were physically easy to see and understand in A-B Roll editing. If one did not have enough Frames, the Transition could not be printed from the A and B roll. It was also a bit easier to grasp, when NLE's still used A-B Roll layouts. Now, with everything on the same Video Track, these Handles are behind the scenes.
Things like those little triangles that I mentioned are clues, but they are tiny, located up at the corner of the Head and/or Tail, and so often overlooked. Many have no idea what they are, and some have probably never even noticed them.
Good luck, and glad that we got it sorted,
Hunt
Message was edited by: the_wine_snob Corrected spelling
Guest
Feb 27, 2013 Feb 27, 2013
Im having this same problem with my cross dissolve. Ive re read all these messages and i still dont understand how to set the handle. and i dont see any triangle in the timeline. Im using cs5.5 could you please help?
This article goes into a bit more info on Handles: http://forums.adobe.com/message/3058164#3058164
The concept was easy with cine, and also when one edited with A-B Roll editing, as one would overlap the Clips, by the number of Frames necessary. With an NLE, and single Track editing, it is a bit more difficult a concept to grasp.
Can you post a screen-cap of your Sequence, showing the Clips, where you wish to add the Cross-Dissolves?
You will ONLY get the "triangles," if that is the end of the full Clip. If you have a longer Clip, which has been Trimmed, then you will not get those, but, depending on your Trimming, might not get what you expect.
Good luck,
Hunt
Guest
I only get the repeated frames after i color correct clips. It works fine to just drag and drop for original footage.
Feb 28, 2013 Feb 28, 2013
Thank you for the screen-cap. If you look at the Head of the first Clip, and the Tail of the second Clip, you will see the little "triangles" that indicate no more media. They are marked here:
Because of the Transition, between the two Clips, we cannot see if there is also a triangle at the Tail of the first Clip, and the Head of the second Clip. If you Delete the Transition for a moment, you can see whether the triangles appear. If so, they indicate that you do not have any more media, beyond, or in front of the Tail and the Head of those two Clips.
If those ARE the ends of the Clips, then just click+drag on the Tail of the first, and then the Head of the next, to set the In & Out Points, enough to allow for the Cross-Dissolve. When you click+drag, the "triangle" will disappear, as you WILL have more media, beyond the new Head and Tail, that you see. That meida will be your Handles, and allow you to apply a Cross-Dissolve. When you do Trim, make sure to allow sufficient Frames for those Handles (will depend on the Duration of your Cross-Dissolve).
Good luck,
Hunt
Guest
im sorry to keep bothering you but i still dont understand, im not a beginnner editor so i dont know why i cant understand this concept. Yes there is a joined complete triangle in the middle of both clips. From what your saying, i dragged the triangle in the middle to the beginning of the first clip and it just made the whole first clip disappear. what am i doing wrong?
Before you add a clip to Replace with AE comp. drag the clip a track higher and add frames to the front and back of the clip (each side the duration of a transition) then send it to AE.
Do your stuff in AE and bring the clip back into Pro.
Your clip is now too long, trim it back to its original length on the timeline and add the transition. There should not be any diagonal lines which means insufficient media.
Instead of dragging the clip a track higher you can also copy it and put it superimposed over the original clip.
Aug 07, 2012 Aug 07, 2012
Ann Bens
The tip to trim of 15 frames of the left clip on the right side and 15 frames on the left side of the right clip works fine
but what can you do if you have more then 70 or 100 clips in your timeline.
is there a sorter way to do this?
thanks.
Kostas K. wrote:
Ann Bens
thanks.
Select all clips and do a ripple trim.
Guest
ann i appreciate your reply but your way seems more confusing than the first one. @Bill is there anyway you could possible make a video for your method so i could understand it? I would highly appreciate it! I dont understand why such a sophisticated program would make something so simple so complicated.
There is no other way, adding transitions is all about having enough handles to put them on.
Linked comps from AE do not have handles. You need to create them first.
