Save for Web & Devices Box Greyed Out
Nov 3, 2009 8:32 PM
Hey everyone,
I'm trying to save a Photoshop CS4 file for Web & Devices so I can have Photoshop compile the slices and the CSS so I can hand-design rollovers. Unfortunately, all of a sudden the dialogue box for Save For Web & Devices is greyed out... I've check online, changed color profiles, deleted save for web and devices library files, updated Photoshop, nothing. I've even checked past .psds I've designed that I've saved for Web & Devices and haven't changed since--even the Web & Devices box is greyed out for them. Help! What do I do? I need to do this before Friday. Thank you!
WebsiteInDistress
    Nov 4, 2009 1:50 AM   in reply to WebsiteInDistress
    Check your ducument color depth and mode. It must be 8bit RGB.
    Mylenium
    Nov 4, 2009 5:29 AM   in reply to Mylenium
    SFW will convert to 8bit (and to working RGB space / sRGB?). I wonder if this isn't a custom SFW key command issue. Or even just a PS pref issue. OP doesn't state that he explicitly reset them.
    Nov 4, 2009 8:41 AM   in reply to WebsiteInDistress
    Reset your PS prefs. Hold down command-option-shift as / when you launch PS. Be sure you get the confirmation dialogue box.
    Nov 4, 2009 10:05 AM   in reply to WebsiteInDistress
    Are you saying that you got the confirmation message to show preferences were reset but the problem still exists? - - - or are you saying that you cannot confirm preferences were reset?
    Feb 24, 2010 6:11 AM   in reply to WebsiteInDistress
    I had this same issue, it was after I installed a scanner twain that over
    wrote my import-export plugins.  I pulled a save for web plugin from my photoshop cs3 plugins and whola, it was available again.  Not sure why your plugin went bad, but this might be worth a try
    Jan 28, 2011 3:09 PM   in reply to WebsiteInDistress
    Go to your plug-ins folder (Applications > Adobe Photoshop CS4 > Plug-ins > Import-Export)
    If you are missing the "Save for Web.plugin" that is the reason why it is grayed out.
    If you have a friend with CS4, just ask them to email you that plugin file, put it in the "Import-Export" folder. Restart Photoshop after copying the file, open up your working file, and it will work!
    Jun 14, 2011 5:38 AM   in reply to moosequestrian
    Hi
    I'm also having the same problem with the Save for Web & Devices Box Greyed Out.
    I think it's the plugin that's corrupt,  as I've tried deleting preferences and seetings. I can't find the photoshop cd to  reinstall it.
    Has anyone got the MAC CS4 Photoshop "save for web  plugin" (Users/[Username]/Library/Preferences/Adobe/Plugins/Adobe Save for Web CS4/Photoshop/Adobe Save for Web CS4 Prefs) that they could send me.
    Thanks very much
    Abi
