Optional Vertical Space Character
Nov 6, 2009 4:15 AM
Paragraphs can have a "space before" and "space after" attribute, as you probably know. The nice thing about this is that if the paragraph is at the top of the page, the space before disappears.
I would like to have a vertical space character that does the same. You insert it into a line by itself (Type>Special Characters>Vertical Spacer). It makes a vertical gap based on the leading you give it.
BUT! if it appears as the top line of a text frame, it will disappear.
Why is this good? Because it saves having to create a lot of paragraph styles to deal with each situation. For instance, currnetly, I may need the following styles:
Block Quote Standalone [space before and space after]
Block Quote beginning [space before no space after]
Block Quote Middle [no space before no space after]
Block Quote End [no space before space after]
Block Quote Standalone Indented
Block Quote beginning Indented
Block Quote Middle Indented
Block Quote End Indented
That's 8 styles all for the different combinations of block quotes. If I had a "vertical space" character, I would need only two styles:
Block Quote; and
Block Quote Indented.
Much easier to manage! The variations could be simply managed by inserting a vertical spacer as needed. Really useful idea, and similar to the way dedicated typesetting systems used to work several decades ago.
Ariel
    Nov 6, 2009 5:53 PM   in reply to [Ariel]
    Why so many different styles for block quotes? Would a forced line break (Shift Space) help keep that list down?
    Nov 7, 2009 1:02 PM   in reply to [Ariel]
    Ah, I see. You might blockquote more than one paragraph, and you are fully justifying the text. Yeah, that’ll take more than one style.
    Sounds like a job for the also-requested and much more versatile Conditional Formatting.
    Nov 8, 2009 11:04 AM   in reply to Scott Falkner
    You can do what you want now, although it’s a bit of a kludge. Just make a new style (I’ll call it “Spacer”) that has the Space After you want, less 0.1 pt. Give the style leading of 0.1 pt. Insert a blank paragraph in this style before and after each quote. If a quote ends up in the next text frame or page, the Spacer style will still be on the previous page, unless your text frame cannot accommodate one tenth of a point of extra content, which I doubt. Similarly if the quote comes at the end of a frame, the same thing will happen, since adding the line at the end of a frame only requires 0.1 point.
    Nov 10, 2009 1:44 PM   in reply to [Ariel]
    Arïel wrote:
    The only minute disadvantage is that if facing frames - one has a footnote
    at the bottom, and one doesn't, they can never align perfectly (off by
    .001pt)
    Ariel
    Good to know if I’m outputting to a device with a resolution of 72,000 dots per inch.
