Paragraphs can have a "space before" and "space after" attribute, as you probably know. The nice thing about this is that if the paragraph is at the top of the page, the space before disappears.
I would like to have a vertical space character that does the same. You insert it into a line by itself (Type>Special Characters>Vertical Spacer). It makes a vertical gap based on the leading you give it.
BUT! if it appears as the top line of a text frame, it will disappear.
Why is this good? Because it saves having to create a lot of paragraph styles to deal with each situation. For instance, currnetly, I may need the following styles:
Block Quote Standalone [space before and space after]
Block Quote beginning [space before no space after]
Block Quote Middle [no space before no space after]
Block Quote End [no space before space after]
Block Quote Standalone Indented
Block Quote beginning Indented
Block Quote Middle Indented
Block Quote End Indented
That's 8 styles all for the different combinations of block quotes. If I had a "vertical space" character, I would need only two styles:
Block Quote; and
Block Quote Indented.
Much easier to manage! The variations could be simply managed by inserting a vertical spacer as needed. Really useful idea, and similar to the way dedicated typesetting systems used to work several decades ago.
Ariel
Perhaps. Not sure I understand. Could you elaborate?
But let me explain. Here's an example. A regular long block quote will need 3 styles, depending on whether there needs to be a line space before or after the paragraph:
BlockQuoteBeginning BlockQuoteBeginning BlockQuoteBeginning
BlockQuoteMiddle BlockQuoteMiddle BlockQuoteMiddle BlockQuoteMiddle
BlockQuoteMiddle BlockQuoteMiddle BlockQuoteMiddleBlockQuoteMiddle
BlockQuoteMiddleBlockQuoteMiddleBlockQuoteMiddleBlockQuoteMiddle
BlockQuoteEnd BlockQuoteEnd BlockQuoteEnd BlockQuoteEnd
And then you need a separate style for a standalone block quote, that needs a line space both above and below. So that's 4 common styles.
Then, occassionally, each of these for will sometimes not need indentation. So that's another four styles.
Also, if the book requires block quotes in footnotes (a bad idea, IMHO, but the choice is not up to me), that's another 8 styles for the same reason.
The forced line break that you mention, if I've understood correctly, wouldn't work with justified paragraphs, since it will force the line before the forced break to be fully justified?
Ariel
You can do what you want now, although it’s a bit of a kludge. Just make a new style (I’ll call it “Spacer”) that has the Space After you want, less 0.1 pt. Give the style leading of 0.1 pt. Insert a blank paragraph in this style before and after each quote. If a quote ends up in the next text frame or page, the Spacer style will still be on the previous page, unless your text frame cannot accommodate one tenth of a point of extra content, which I doubt. Similarly if the quote comes at the end of a frame, the same thing will happen, since adding the line at the end of a frame only requires 0.1 point.
Scott, that looks like a clever workaround. In fact, ID let's you go down to
.001pt for the leading, so much the better. This is also nice because it's
easy to change the size of the space: say from a full line space to a half
line space, by changing the paragraph style definition.
The only minute disadvantage is that if facing frames - one has a footnote
at the bottom, and one doesn't, they can never align perfectly (off by
.001pt) since you'll be needing that extra space. Which is completely
theoretical anyway, since when the press sheets are folded the inaccuracies
are orders-of-magnitude greater than that.
The only other practical problem here is if someone else needs to work on
the file. It'll take them a while to figure out what's going on.
Still, I think I will try this for the next book. Put it to a real-world
test. Nevertheless, it would be more elegant to have a special character
available, which I'd like. In fact, there should be another special
character which does the opposite as well: Only makes a space if it falls at
the top of a frame. That would be useful for dropping subheads slightly if
they fall at the top of a frame, so that the next line of body text will
fall on a baseline grid.
Ariel
