My code collapses keep on disapearing.
thanks
I also have this problem.
I have 20+ sites that I manage in Dreamweaver CS4 (Version 10 build 4117). Most sites remember code collapse fragments on all files, but I have one site that only partially works. There are two files in particular that show code collapse errors. I can collapse either using the Code Collapse Full Tag button, or I can collapse a selection while I am working on the file. But if I close and reopen, the code collapse fragments are forgotten - this happens even if I save the doc. How do I troublehoot / fix code collapse errors?
Thanks for your help!
Jason
You know you're asking this on the ColdFusion Builder forum, not the DW forum, right?
Adam
What do you mean by disappearing? Previously collapsed code re-expands itself? The option to collapse code actually disappears from the editor window? Your question is bit vague...
Adam
Adam - sorry to post here, I meant to post in DW. To clarify - I select a segment of code, say from line 100 to 200 and collapse the selection. On most projects, when I close DW and come back later, the previously collapsed 100 lines are still hidden. I can click the expand handle and then the code will appear, and I can move on. On a couple cfm files, I will collapse, the same lines 100 - 200, and when I close DW and come back later, the 100 lines are un-collapsed. It looks like there is possibly some sort of corruption in the file that manages the collapsed code.
