I was using this script in illustrator cs4 on a mac running 10.5 and all was good
tell application "Adobe Illustrator"
activate
set theName to name of current document
set theNamecount to count of theName
set thePath to the file path of current document as string
set pathCount to count of thePath
set pathCount to (pathCount - theNamecount)
set newPath to (text 1 thru pathCount of thePath)
set newName to "Die for " & theName
set finalPath to newPath & newName
save current document in file finalPath as eps ¬
with options ¬
{class:EPS save options, compatibility:Illustrator 8, preview:color Macintosh, embed linked files:true, include document thumbnails:true, CMYK PostScript:true, PostScript:level 2, embed all fonts:true}
beep 2
activate
end tell
Then I upgraded to Snow Leopard now when i run the script I get this message
error "Can’t make «data fss 9CFF84A2B8001F4F75747369646520436F7665722046696E616C20312342384132413 32E61690000000064E76706D8298F1EE9D902207CE1FFBF28E1FFBF88578F1EE9D9022 0» into type string." number -1700 from «data fss 9CFF84A2B8001F4F75747369646520436F7665722046696E616C20312342384132413 32E61690000000064E76706D8298F1EE9D902207CE1FFBF28E1FFBF88578F1EE9D9022 0» to string
Thanks in advance.
Rod
oddly enough seems like illustrator is giving you an outdated "file specification" object(class fss means that), which i think it has been deprecated since snow leopard. since i can't test it right now you might want to change that line to:
set theOutdatedPathObj to the file path of current document
set thePath to (POSIX path of theOutdatedPathObj) as string
hope it helps.
cheers;
G'day
I have the same problem.
set theOutdatedPathObj to the (current document's file path)
--set fp to (POSIX path of theOutdatedPathObj) as string
end tell
returns
«data fss 9CFF6D0609001B33303234302D3930343537205B436F6E7665727465645D2E657073C C4C000000016169465323E0EF181D9698CC1D5D5A34BFFFCCF0636F72650000000A033 B»
What can I do to fix, please?
Regards
OzSanta2
Hi
Try this script it seems to work for me.
activate
with options ¬
beep 2
activate
end tell
Let me know how you go.
Thanks Rod
G'day Rod
Your script returns...
error "Can’t make POSIX path of «data fss 9CFF6D0609001B33303234302D3930343537205B436F6E7665727465645D2E657073C DCC000000016169465323ECF0381D9748CC1D5E0A34BFFFCE70636F72650000000A033 B» into type string." number -1700 from POSIX path of «data fss 9CFF6D0609001B33303234302D3930343537205B436F6E7665727465645D2E657073C DCC000000016169465323ECF0381D9748CC1D5E0A34BFFFCE70636F72650000000A033 B» to string
I'm running an intel iMac, so perhaps it's something to do with that.
I'm now using this very cumbersome approach...
on FetchFileContainer()
set fp to do javascript "activeDocument.path"
end tell
set fp to my convertString(fp, "%20", " ") as text
set newerPath to (POSIX file fp) as text
set newerPath to newerPath as text
if "Desktop" is in newerPath then
set newerPath to newerPath & ":"
repeat 3 times
set o to offset of ":" in newerPath
try
set newerPath to items (o + 1) thru end of newerPath as text
on error
if newerPath = "Desktop:" then set newerPath to ""
end try
end repeat
set ptd to path to desktop as text
set newerPath to ptd & newerPath
end if
set C to newerPath
if "desktop" is not in newerPath then
set newerPath to items (o + 1) thru end of newerPath as text as alias
tell application "Finder"
try
set C to container of (newerPath)
end try
end tell
end if
return C as text
end FetchFileContainer
on convertString(tString, ToFind, Tochange)
set {oAStid, AppleScript's text item delimiters} to {AppleScript's text item delimiters, ToFind}
set tString to text items of tString
set AppleScript's text item delimiters to Tochange
set tString to tString as string
set AppleScript's text item delimiters to oAStid
return tString
end convertString
