How does one rasterize a transformed vector capturing it's new dimensions without pixelation?
Challenge: To render a bitmap of a transformed vector display object without pixelation. Specifically, after a mx.controls.Text is transformed, a bitmap snapshot is needed to be taken of the new object including the dimensions. I should note that the reason I am needing to get a bitmap snapshot is do to some shaping to the text.
Problem: However, doing so results in pixelation or the original dimensions of the transformed Text. It appears that flash.display.BitmapData::draw cannot get the new transformed display.
Example: http://sources.novelastudios.com/flash/matrix_adustments/MatriciesAndD imensions.html#
When the application creation complete is fired a snapshot is made. Change the matrix width (transform.matrix.a) and then re-render a snapshot / bitmap. Notice it retains the original, non-transformed values. Therefore and considering it is a rastered snapshot, when the snapshot/bitmap is scaled it becomes pixelated. Example version is now 1.1.0.0
Also at http://flashmoment.blogspot.com/2009/11/rasterize-transformed-vector-w ithout.html
Hello Alex,
I apologize for the confusion and thanks for asking for clarification.
When a flash.display.InteractiveObject is scaled on the x axis (or any axis) using transform.matrix, flash.display.BitmapData::draw cannot capture the new dimensions of the display object. This can be seen in the example:
The primary objective is to be able to transform / scale a InteractiveObject's dimension (in this case mx.controls.Text) and then resample/render the bitmap with the new dimensions.
Alex, I've uploaded a new version (the proof of concept). It is a bit messy at 1.2.0.0, but shows the results correctly for now. I must say though that this seems like a workaround to me. Do you consider this a workaround?
Workaround: I give credit to Guy Stables (needs a link) and Alex Harui (http://blogs.adobe.com/aharui).
Essentially, the workaround is as follows:
No. I think of the transform like a magnifying glass applied to the object. The object doesn't know it has been transformed, but the parent, who is looking through the magnifying glass, does and sees the transformed result so that's what you need to capture.
Alex Harui
Flex SDK Developer
Adobe Systems Inc.
Alex, I suppose I view this differently.
There are two primary issues I see:
1. If a view object changes, I believe the properties of that object should reflect those changes. Specifically, to me it's surprising to have a display object be transformed and it's properties still reflect that it hasn't. In this example, it makes sense only if the transformation was taking place on the parent not the child.
2. The matrix could be used as a model and seen as such. However, adjustments to matrix properties do not get dispatched which make it near impossible to use as a functional model.
These two things nullify the event dispatching and ability to listen directly to an object, which forces the usage of a Design Pattern that is overkill but required.
What do you think?
Almost nothing in the Flash Player dispatches events when changed. It makes watching for changes very difficult. The Flex Framework has taken the time to get the 80% cases to dispatch events, but there is a performance cost to doing so and it isn't always possible to trap changes. Rotation and Scale is better handled in Flex 4 (although the Spark components can be a bit slower because of it).
Some properties are immediately modified by transform changes and vice-versa (scaleX/Y is reflected in the transform and vice-versa). But if a object positioned a rectangle at 50,50 to 100, 100, then got scaled, the xy of that child rectangle is still 50,50 and I think that is correct. That's why I think of scale as a magnifying glass above object.
Alex Harui
Flex SDK Developer
Adobe Systems Inc.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
