I get the error "Cannot use adobe reader to view pdf in your web browser. Reader will now exit. Please exit your browser and try again" in Windows 7 x32 and Windows 7 x64 with Acrobat pro 8.1.7. This happens when trying to open a PDF file in Internet explorer 8.0.760 or when I open a PDF in Quickbooks 2008. If I answer ok or cancel the file opens normally. If I open acrobat 8 first then the pdf files open as expected. I also tried a copy of Acrobat reader with no difference in the outcome. Since this happens on two different computers one fresh copy of windows 7 x64 the other an upgrade to windows 7 x32 and they used to work before the change to windows 7, I assume there is some kind of incompatibility with windows 7 and acrobat. Is this a known issue and will it be fixed in an update to acrobat in the near future?
Exactly the same problem here. Using Windows 7 Professionnal (32b) with Mozilla FireFox 3.5.4 with Acrobat Pro 8.1.7 (bundled with my Creative Suite CS3). Except for the error message, most of time the PDF are displaying correctly into my web browser.
I hope Adobe will release an hotfix soon because this is annoying and some time my PDF aren't displaying for real and I have to refresh... quit my browser... ect.
Let's go Adobe, do something! ![]()
You mean you install Adobe Reader (free version) OVER your actual Adobe Acrobat Professionnal? Because if I go inside my file association into Firefox all the choice I got in the scrolling menu is "Adobe Acrobat plugin (inside FireFox)" or "Adobe Acrobat 8 Profesionnal". There's nothing about Adobe Reader... that's why I assume you install Adobe Reader (free) over your Adobe Acrobat Pro.
It's a possible solution I guess, but it's kinda annoying because I prefer to use the real Adobe Acrobat Professionnal to read my PDF because I use the advanced feature only included into the Pro. Reader version (Free) are very limited and I don't want to have to save all my PDF on desktop then open it manually into Adobe Reader Pro...
Generally installing both Reader and Acrobat is not recommended by Adobe. They may interact and create problems using one or the other. As far as the compatibility of Win7 with Acrobat versions, it would be nice to give a link to the compatibility statement that was made. In looking at the system requirements on the Adobe site for AA9 versions, there is not comment about Win7. Also, 64-bit versions have also been problematic. So specific references to the compatibility statements would be appropriate when stated.
I'm not familiar with Win7, but maybe You could investigate a little bit according to this good old tweak:
Quote from message by Reinhard Franke - 07:48am Jul 30, 2003 Pacific:
"[HKEY_CLASSES_ROOT\Software\Adobe\Acrobat\Exe]
There you will find the full path to the program IE will use (Acrobat or Reader exe)."
E.g. "C:\Programs\Adobe\Acrobat 7.0\Reader\AcroRd32.exe"
The Windows 7 compatibility site says that Acrobat 9 is compatible. It's silent on Acrobat 8. I ran the Windows 7 compatibilityt checker before I upgraded and Acrobat 8 was not flagged as incompatible. However, it did not appear in the list of specific programs that are compatible (or not). It is certainly compatible in the sense that everything works except for getting the stupid message.
Same problem here.
None of the above sollutions helped. To bad.
I hope there will be a sollution soon as I really need version 8 to test my SAP Interactive forms (PDF within SAP Webdynpro)
You're right Bill.
Most internet advices on the issue regards an alternative browser and/or an alternative reader.
E.g.: "Several users have been able to quickly an easily work around this issue by installing and using an alternative PDF reader. One good choice is the free Foxit Reader."
Maybe You could do the testing with Foxit Reader. Or I may suggest PDF-XChange Viewer.
http://download.cnet.com/PDF-XChange-Viewer/3000-10743_4-10598377.html
Here is the workaround/fix.
1. Open Acrobat 8.1.7
2. Go to Edit > Preferences > Internet
3. Uncheck "Display PDF in Browser"
Now when you click on a PDF link in a browsing session it will launch Adobe Acrobat Pro in a separate window to view the PDF instead of trying to view it inside of Internet Explorer.
Ok, I just resolved this issue on my machine - running Windows 7 and Adobe 8.1.5 Professional - by just disabling the Adboe Splash Screen under Edit / Preferences / General / Application Startup.
I also disabled the "Getting Started with Adobe Acrobat 8 Professional" screen that comes up when you open Adobe, by selecting the "do not show at startup" option on that window. See attached screen capture.
Hope it helps you folks out there!
cheers
I have this issue several times on various users PC's. What I've done to resolve is the following Registry import:
1. Create a .reg file using Notepad
2. Copy the following in document (all in between the hashmarks) or use registry doc i attached to this response
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\acrobat\DefaultIcon]
@="C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\acrobat\shell]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\acrobat\shell\open]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\acrobat\shell\open\command]
@="C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe /u \"%1\""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\SOFTWARE\Adobe\Acrobat\Exe]
@="\"C:\\Program Files\\Adobe\\Reader 9.0\\Reader\\AcroRd32.exe\""
3. Save as something like AdobeFix.reg
4. Run regedit and import this entry into your registry then restart PC.
People don't use blakmoon71 sollution unless you are working on a test machine.
On my machine it totally screwed my adobe reader.
I get more errors than ever, and no more pdf viewing inside a webbrowser.
You could try a "modificated" version of blackmoons suggestion:
1) In Windows Explorer change the default application for the file type pdf to the Adobe Reader.
2) In the registry edit only this key "[HKEY_CLASSES_ROOT\Software\Adobe\Acrobat\Exe]" manually
to the full path to the Adobe Reader.
E.g. "C:\Program files\Adobe\Acrobat [version]\Reader\AcroRd32.exe"
tvandersluijs - I'm sorry if that screwed up your machine however:
1. What version of Adobe Reader are you using because as you can see the registry entry is for Adobe Reader 9, if ur using Adobe Reader 8 then u need to specify ur version as PAllens entry suggested - "E.g. "C:\Program files\Adobe\Acrobat [version]\Reader\AcroRd32.exe""
2. I've used this solution significantly because I have come across this specific issue for multiple users.
3. All the registry entry does is tell Windows what program to use by default to open/view PDF documents.
My intention wasn't to screw up ur machine or anybody elses as I said I've used this solution many times however what I've should gave is the disclaimer to backup ur registry before u make mods so u can revert back in case. Also the ony other thing I can think of is that this solution was for Windows XP using registry editior 5, I'm noticing that the title of this thread is Windows 7.
Don't Worry blakmoon71. (yes I am using version 8, or I was using version 8... read on... read on....)
It could not get any worse anyway, right ?
And it actually helped at the end.
First I could not use Reader 8 or 9 having the "cannot use adobe reader to......" error.
After your so called fix, it was totally screwed.
So I did a uninstall of 8. Restarted, did a clean of my register with CCleaner, did another restart, started Windows 7 into save mode, did another clean of my register with CCleaner, did a restart.
Then I installed Adobe Reader 9 for windows 7.
And guess what !
The problem is gone !
No more "Cannot use adobe reader to view pdf in your web browser" error !
Wowowowooo !!!!!!!!!!!!!!!!!!!!!
Finally it is gone. Don't know if the error would be gone if I installed reader 8 again. But for now I'm a happy person.
So blakmoon71, thank you very much after all !!
Had the exact same problem on my computer running Windows 7 and Acrobat Pro 8.1. I also have both Firefox and IE 8.
The solution that worked for me was really simple, just open Firefox and in the Tools menu, choose Internet options, goto the programs tab and change the associated action for PDF files to Use Adobe Acrobat 8.1.
This solved the problem both in IE and Firefox. Hope this helps.
I've also been experiencing this same issue, for about three months now. (http://forums.adobe.com/thread/480371?tstart=0). I'm not exactly an expert in these things, but I'm guessing the issues track back to the nppdf32.dll plugin. For Firefox, it has not been updated since 8.1.3. For Internet Explorer, the plugins appear to be from 8.1. I opened nppdf32.dll with a hex editor, and although I couldn't find much of anything of any use to me, I did find the error message we're all seeing buried in the code. Perhaps all that needs done is an update to the browser plugins?
After years of living with this problem, I finally found an easy solution!!
This page contains a simple .reg file that fixes Adobe's PDF preview handler on 64-bit versions of Windows.
Open RegEdit and go to:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{DC6EFB56-9CFA-464D-8880-44885D7DC193}
There should be an existing AppID value, incorrectly set to {6d2b5079-2f0b-48dd-ab7f-97cec514d30b}
Change the AppID value to {534A1E02-D58F-44f0-B58B-36CBED287C7C}
Credit--> http://www.pretentiousname.com/adobe_pdf_x64_fix/index.html and Maximum PC December 2009 issue page 26
Thanks for the information, but this does not cure the issues I am experiencing with opening PDF's in a web browser with Windows 7 64-bit. This may very well cure other issues involving preview handlers on 64-bit Windows, but I think the browser issues are related to the browser plugin and its compatibility with Windows 7, and not preview handlers. After applying both registry edits discussed in the article, and then rebooting, I still get the "Cannot use Adobe Reader..." when trying to open PDF's in Firefox and IE8 on Windows 7 x64.
I did not experience this problem on Vista x64 - only 7 x64. Is this issue limited to 64-bit Windows 7, or are users also experiencing it on 32-bit Windows 7?
I had a similar problem using Firefox as a browser in Vista with Adobe Reader 9.2. The message says "The Adobe Acrobat
/Reader that is running can not be used to view PDF files in a web browser. Please exit Adobe Acrobat/Reader and exit your web browser and try again"
This is completely useless as advice and Adobe support is no help either. However, using the advice from this forum, I have tried various combinations to arrive at a solution that works:
Not the cleanest solution but it's solved six months of headaches for me!
Having read a little more, I also tried the Firefox solution from above. In my version:
I can now use both IE and Firefox - thanks for your suggestions!
After many hours of dealing with this problem, I finally got it to work. I am using Windows 7 w/ 64 bit on a Sony Vaio.
I had Adobe Acrobat 8 Pro and Acrobat Reader 9.2 loaded. I noticed that when I got the error box, it was Acrobat 8 Pro that was generating it, not Reader 9.2.
I checked file associations and it was associating pdf and pdfxml files to 8.1. I changed it to 9.2. No difference. I went into Manage Add Ons and saw that my plug ins were mostly being used from 8.1, not 9.2. Disabled and enabled the lot in many different ways, to no avail.
I finally uninstalled 9.2 so that I only had 8.1 running anything pdf and it would work sometimes....but not without the error box first. I basically gave up hope and was awaiting Adobe to fix their little problem.
Then during the day, my Sony Vaio care went off and said it was time for a scheduled maintenance. It cleans the registers, defragments etc etc, so I activated the maintenance.
Later that evening, I decided to exercise futility once more and downloaded and installed Abobe Reader 9.2 once again to try and figure out this problem.
Well....after the download, it works flawlessly everywhere it previously failed. I rechecked the file associations in Windows 7 and they are now associated with 9.2...one of them still 8.1. I checked the plug ins and they are still operating out of 8.1 except for one that is using 9.1.
So the fix for me was uninstall 9.2, do a registry clean, re install 9.2. I doubt if Adobe drummed up a fix between my problem and no problem.
Good luck.
I have been watching this forum post since I started it and so far the only thing that has mostly worked for me is setting the following; in Adobe acrobat preferences under Internet, uncheck "Display PDF in browser". This brings up a separate PDF window without the error. I have tried checking and un-checking it and every time it is checked the error comes up. So at this point to avoid getting the annoying error I just leave the "Display PDF in browser" box unchecked and get a separate window with no errors. I haven't been able to try it on my 64 bit system as I had to send it in for other unrelated issues, I will let you all know when I get it back.
