graydl
Can ACR 5.6 be installed for LR or Elements on OS X
Nov 19, 2009 10:14 AM
Downloaded the release candidate and it won't install.  Is there a way to manually install it for Lightroom and Photoshop Elements and Bridge CS3 on a Mac?
    Nov 19, 2009 10:20 AM
    Lightroom does not use the ACR plug-in!  But there is a release candidate of Lightroom 2.6 available for download.
    Community Member
    Nov 19, 2009 11:19 AM
    To accomplish a manual install on Windows you can copy and rename the file:
    Re: Can ACR 5.6 be installed for LR or Elements on OS X\extensions\AdobeCameraRaw5.0All-121109114152\Assets\1003
    Which appears to be about the right size (11MB) for Camera RAW.8bi (32-bit).
    I believe there is an analogous process for the Mac install image, but I don't know what it is.  You could probably poke around in the folders on the disk-image and find it.  You might check the size of Camera RAW 5.5 to get an idea how large it should be on your system.
    What you can't install by this procedure are all the camera-specific profiles for newly supported cameras in this version.  You would probably need to install the LR 2.6 RC to get those.
    If you do find and successfully manually install the Camera RAW plugin from the Mac installer image, you might post your results, here.
    Community Member
    Nov 19, 2009 12:07 PM
    The OP said CS3!
    Community Member
    Nov 19, 2009 3:26 PM
    On Windows, ACR 5.6 RC works with Elements 6 so I expect it would work with 7 as well.
    I would search your hard-drive for all instances of the Camera Raw.plugin and replace them with the one extracted from the DMG, after, perhaps, renaming the old copy to something with a different extension just in case you need to put it back.
    Nov 19, 2009 4:12 PM
    ssprengel.
    It works exactly as you described.
    I renamed the 1003-file to Camera Raw.8bi and replased it with the "old 5.5"
    No restart of anything else than PSE.
    Message came up saying ACR 5.6 is RC expiring end of january.
    I have Windows7 and PSE 7.0-32.
    Thanks! /Erik
    Community Member
    Nov 19, 2009 4:15 PM
    If you do a Elements / Help / About Plugin... / Camera RAW what version does it say?
    Community Member
    Nov 19, 2009 5:26 PM
    PSE Help says: Camera Raw 5.6.0.134
    Community Member
    Nov 19, 2009 5:42 PM
    Graydl, what version of ACR does Elements / Help / About Plugin... / Cmaera RAW indicate?
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
