Help. Encode to MP4 or F4V?
Nov 24, 2009 10:12 AM
I have tried countless times in finding out from Adobe what would be the best solution to use the already 100s of videos encoded to H.264 in the mp4 container. Unfortunately, salesmen never know the answer yet keep asking me to buy.
What benefits, if any is there to encoding to F4V over MP4 other than the ability to inject metadata without having to use a sidecar xmp file like you would if using MP4? The only downside I see with going F4V is that files will not be playable on set tops, gaming consoles, and also iPods.
Does FMS protect files already encoded to MP4 and if not, is there a tool to rewrap the MP4 into a F4V?
My overall goal is to be able to put all metadata needed into the file and use actionscript 3 to populate the information on a web page and in the future an AIR app. I would love to pull the trigger and buy FMS but it just seems like the salesmen are reading from a brochure and never once address my questions let alone find me answers.
Any help is greatly appreciated.
    Nov 24, 2009 2:03 PM   in reply to pmasters8941
    F4V and MP4 are essentially the same file format as far as FMS is concerned.  I can answer your questions here, but first are you comparing between our F4V/MP4 recording and FLV or truly between F4V and MP4 as they're practically the same thing?
    Asa
    Dec 1, 2009 9:57 AM   in reply to pmasters8941
    Well, F4V is just a file extension that means it's an implementation of the MP4 spec that Adobe promises to understand.  I don't have a link to the ISO-spec right now, but essentially internally Adobe wanted a file extension that all products could create and not get stuck with a menu list of 3gp, mov, mp4, m4v, ... extensions that are supported and not.  That's why I say that they're the same file format.
    The only difference comes in that recorded F4Vs by FMS use MP4 fragments - the majority of mp4s out there don't, and that's because they don't have to do scalable recording on the fly.  So, you don't have to move unless you gain something from it.  FMS will write F4V files with fragments, and you can flatten them in post processing.  I'd say to go with whatever workflow works best for you - and not presume to move you anywhere unless feature set is appealing enough.
    As for protected content, I'll assume we're speaking of DRM packaging.  In that case I'm a little out of my element but they certainly do protect the file on disk and FMS is more of a pass through of their DRM content.  If we're speaking of FMS mechanisms like RTMPE or SWF Verification then we do nothing to the file and it's all 'on the wire' protections.
    Hope that helps,
    Asa
    Apr 29, 2012 2:05 PM   in reply to Asa - FMS
    Hi, I am just getting into the field of encoding for web.
    I have a 10 minute episode of a web-series which I'd like to encode as to achieve the best quality with the smallest size.
    I do want to have a DRM otion too.
    Which of the encodings will you recommend. F4V or MP4? or any other one that you may think will suit me best?
    Thank you very much
