The only way I have found to do this is to copy the contents of the original into a new document.
Here is my code:
tell application "Adobe Illustrator"
activate
open your_doc.ai --replace with your filename and path
tell me to do shell script "sleep 3"
tell application "System Events" --Select all.
tell application "Adobe Illustrator" to activate
key code 0 using command down
end tell
tell application "System Events" --Group objects, may not be necessary.
key code 5 using command down
end tell
tell application "System Events" --Copy selection.
key code 8 using command down
end tell
close this_file without saving --out with the old, in with the new
--make a new artboard with the appropriate dimentions
set docRef to make new document with properties {«class caCS»:«constant eCLSeCyM», «class pSHw»:205.2, «class pSHh»:61.2, «class pNAr»:1, «class pALy»:«constant eDALpGrR», «class pASp»:20.0, «class pARC»:3}
key code 9 using command down
end tell
end tell
In the above, "«class pSHw»:" is width in pixels, "«class pSHw»:" is height in pixels, «class pNAr»: is the number of artboards.
The artboard with automatically be centered.
I figured this out from messing with the default scripts.
There is no way to do it in the current document, so this is the only workaround.
Cheers.
I use Applescript, so I do not know if this works for anybody else, but this is where I ended up:
tell current document
tell artboard 1
--get original page size
set artPage to artboard rectangle
set x1orig to item 1 of artPage
set y1orig to item 2 of artPage
set x2orig to item 3 of artPage
set y2orig to item 4 of artPage
--determine new page size (add half inch in each direction)
set x1new to (x1orig - 36) as real
set y1new to (y1orig + 36) as real
set x2new to (x2orig + 36) as real
set y2new to (y2orig - 36) as real
--set new page size
set artboard rectangle to {x1new, y1new, x2new, y2new}
end tell --artboard
end tell --document
end tell --AI
I wrote a Javascript that will resize the artboard in Illustrator CS4.
FitArtboardToArt.jsx
DESCRIPTION
In Adobe Illustrator CS4, fit the artboard to the visible bounds of a document.
NOTE: The script leaves behind some artifacts in the document window but is correct.
Darryl Zurn, 2009-11-25 daz-scripting@zzzurn.com
if (app.documents.length > 0) {
var docRef = app.activeDocument;
if (docRef.artboards.length > 1)
alert('Need exactly one artboard');
quit;
// Found 1 artboard
var myVisibleBounds = docRef.pageItems[0].visibleBounds;
// The VisibleBounds rect is in this order: left, right, top, bottom
// so use variables to show which side we are using
var myLeft = 0; var myRight = 1; var myTop = 2; var myBottom = 3;
for ( var i = 1; i < docRef.pageItems.length ; i += 1 )
// We want the ultimate maximum bounds, so select the minimum left and bottom, and max right and top of our rect.
myVisibleBounds[myLeft ] = Math.min( myVisibleBounds[myLeft ], docRef.pageItems[i].visibleBounds[myLeft ] );
myVisibleBounds[myRight ] = Math.max( myVisibleBounds[myRight ], docRef.pageItems[i].visibleBounds[myRight ] );
myVisibleBounds[myTop ] = Math.max( myVisibleBounds[myTop ], docRef.pageItems[i].visibleBounds[myTop ] );
myVisibleBounds[myBottom] = Math.min( myVisibleBounds[myBottom], docRef.pageItems[i].visibleBounds[myBottom] );
// We have our maximum bounds, so use it to set the document's (only) artboard
docRef.artboards[0].artboardRect = myVisibleBounds;
else {
alert('Open a document before running this script', 'Error running FitArtboardToArt.jsx');
I amended panda42_s script to allow variable adjustment of height and width:
tell artboard 1
set newHeight to text returned of (display dialog "enter increase in height in mm" default answer "")
set newWidth to text returned of (display dialog "enter increase in width in mm" default answer "")
set x1new to (x1orig - newWidth / 2 * 2.834645) as real
set y1new to (y1orig + newHeight / 2 * 2.834645) as real
set x2new to (x2orig + newWidth / 2 * 2.834645) as real
set y2new to (y2orig - newHeight / 2 * 2.834645) as real
--set new page size
end tell --artboard
end tell --document
end tell --AI
Sorry forgot to take comment out of previous post (not that it stops it from working):
tell artboard 1
--set new page size
end tell --artboard
end tell --document
end tell --AI
Hi D Zurn
Your script is really working great. Is it possible that we can maintain some certain distance instead of fitting exactly? I mean now it is exactly fitting with artwork. I am requesting to maintain 10mm from 4 sides.
If it is possible, please edit this script.
quit;
// Found 1 artboard
else {
Thanks in advance..
Regards
HARI
I got a message from another user who had modified my script to ask the user how much to add, and then did it. I thought it had been sent to the rest of the group too, but I don't see it and I think I deleted the message.
I'll try my other computer to see if the script is still around, or hopefully they can repost it to the forum.
Darryl
Hi D Zurn
Thanks for your reply,
Could you guys please post the updated script.
Thanks in advance.
Regards
HARI
First an elegant solution, and then a question.
If your goal is to reduce the size of the artboard to the visible boundaries of the artwork, this works like gang busters. (I can't take credit, but I can share it.)
#target illustrator
var doc = app.activeDocument;
doc.artboards[0].artboardRect = doc.visibleBounds;
Now, I'd like to enlarge the artboard on all sides by say, 20px. I don't want to set specific X and Y coordinates, since the art I will be running it on is variably-sized.
How do we then enlarge the artboard dimensions relatively from the new artboard values? Thanks for the Applescript, Panda, btw.
This should be easy, but I can't quite figure it out. Any help is much appreciated.
Thanks in advance, you'll be saving my rear end.
-t
OK, with some help, I have a JS ExtendScript that works, but I still need help making it more batchable.
This script below will for perform the following two changes to all open documents:
var myDocs = app.documents;
var i = 0;
for (i = myDocs.length-1 ; i >= 0; i--)
var doc = myDocs[i];
app.activeDocument= doc;
var myVisibleBounds = doc.visibleBounds; //Rect, which is an array;
myVisibleBounds[0] -= 20;
myVisibleBounds[1] += 20;
myVisibleBounds[2] += 20;
myVisibleBounds[3] -= 20;
doc.artboards[0].artboardRect = myVisibleBounds;
doc.close(SaveOptions.SAVECHANGES);
But this is limited, since you can only load so many files at once into Illustrator. Does anyone know how to point the JS at a folder?
Tom
Some thing like this should do it for CS5… Plus I did it so it's simple enough to adjust…
#target illustrator
var docVB = doc.visibleBounds;
var left = docVB[0] - 20;
var top = docVB[1] + 20;
var right = docVB[2] + 20;
var bottom = docVB[3] - 20;
var ab = doc.artboards.getActiveArtboardIndex();
doc.artboards[ab].artboardRect = [left,top,right,bottom];
Firstly… You could just save that snippet in to Illustrator's scripts folder, make a action that calls it via 'insert menu item' from the flyout, once you have the recorded and saved action use as a batch… The other way would be to have a purpose built script that does the whole of the processing for you… Much would depend up on the files in question where they are within your file system… If you need the latter then start a new topic this is an old thread…
If you go down the action route don't forget that the script call will be forgotten by the app at quit… A much complained about issue…
Great tip about "Insert Menu Item". Once I placed my script in the Illustrator CS4>Presets>en_US>Scripts folder it showed up in the menu list, and I could access it through batch. I modified the script to be used in the batch, and I'll include that here:
myVisibleBounds[0] -= 20; //left coordinate (use negative values to add artboard)
myVisibleBounds[1] += 20; //ltop coordinate
myVisibleBounds[2] += 20; //right coordinate
myVisibleBounds[3] -= 20; //bottom coordinate (use negative values to add artboard)
Thanks for your help, Muppet!
tf
