link named anchor to specific tab on widget
Dec 1, 2009 6:35 AM
I have a page - http://jenniferyarro.com/schedule_postcard.htm.  I want it to link to the named anchors within a tabbed Spry widget - see page http://jenniferyarro.com/schedule_detail.htm.
I put a named anchor inside each tabbed panel, I also tried to put the anchor on each tab.  Neither one works. It appears that the anchor sees the widget as one object, therefore I am taken to the correct page, but always to the same tab (ie the one that is set as default).  I was wondering if there is a way to have it link directly to the tab that I want open.
Lisa
    Dec 2, 2009 4:45 AM   in reply to lisaellensegal
    You want something along the following lines.
    In the link from the external page have a querystring in the link
    i.e. mytabbedpanelpage.html?panel=2
    Then have a bit of script in the tabbed panel page.
    var params= Spry.URLutils.geturlparamsasobject();
    if (params.panel)
    TabbedPanels1.showPanel(params.panel);
    Check out the Spry documentation for exact syntax as at work at present and not in front of documentation.
    Regards
    Phil.
    Dec 2, 2009 5:28 AM   in reply to lisaellensegal
    May 24, 2011 11:32 AM   in reply to lisaellensegal
    The instructions above SEEM like just what I need - but when I update the script at the bottom of the code to
    var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", {defaultTab: params.tab ? params.tab : 0});
    The content from all of my panels moves to one panel, and the widget no longer works.
