Locked
Cairngorm 3 - getting started
Guest
Dec 02, 2009 Dec 02, 2009
Hello,
I extracted the Cairngorm 3 source from svn.
Somewhat naively I typed
mvn clean package install
from the build-parent folder
That gave all kinds of missing dependencies most of which I was able to resolve using the libraries available in the svn extract
Currently I am still missing 2 which I can't seem to fix
1) org.spicefactory:cinnamon:swc:1.0.1
2) com.adobe.flexunit:flexunit:swc:4.0-beta-2-eventful
Is what I am trying to do not intended? Any other guidance as on how to resolve this?
Many thanks indeed
Peter
Cairngorm
5.0K
Adobe Employee ,
Dec 03, 2009 Dec 03, 2009
Hello Peter,
As you guessed you need to install the swc in your maven repository.
Locally what we have is a nexus server serving all those dependencies, unfortunately this nexus server is not public.
Let's hope it will be one day.
meanwhile the two swc you are missing should be available in the flexunit4 project swcs (on opensource.adobe.com)
the cinnamon swc is a spicefactory project, you will find it, on their web site.
Nevertheless I'll do my best to publish a decent repository at some point, I wished I had the time to do it now.
Cheers,
François
Guest
François,
Thanks for taking the time to help me
I found what I needed wrt the cinnamon dependancy I think. I am however less certain what swc from the flexunit download I need to attach to com.adobe.flexunit:flexunit:swc:4.0-beta-2-eventful.
Would you have any guidance there?
Peter
Adobe Employee ,
Hello Peter,
Thanks for the feedback I double checked, and you are right it does not make much sense and I could not figure out where this swc was supposed to be released.
So I refactored a bit the code and now you should just depend on flexunit 4 beta 2.
Update the source code from svn, you'll see !
Cheers !
François
Guest
Dec 04, 2009 Dec 04, 2009
Hello François,
Seems as I go along I run into new dependencies that are difficult to get at.
1) com.adobe.lcds:fds_rb:rb.swc:en_US:2.6.1
2) com.adobe.lcds:fds:swc:2.6.1
3) com.adobe.lcds:playerfds:swc:2.6.1
This is currently missing.
Perhaps I should just wait a bit before trying to give Cairngorm 3 a test drive
Any guidance?
Peter
Adobe Employee ,
These one are lcds (LiveCycle Data Service), and so you need to download lcds 2.6.1.
This is not open source software, it should only be needed by the library IntegrationDM.
Cheers !
François
PS: Cairngorm 3 is still beta but you may also test drive cairngorm3 by downloading the released beta swc, look at the wiki
Engaged ,
Hi Peter,
while we use Maven/Hudsion internally to build and control quality of Cairngorm 3 libraries, it wasn't our main priority at this point to also let others leverage this infrastructure. Just out of time/resource constraints we currently focus on guidelines and libraries around client side architecture. However, at a later point, we do plan to share more information on build automation and look forward to exchange ideas around this area. That said, why does this prevent you from viewing the current content i.e. around libraries?
Alex
Guest
Thanks for the answers.
I was unaware a binary beta download was out there somewhere. I will try to find it.
Currently not much seems to be working on the wike
http://opensource.adobe.com/wiki/display/cairngorm/ results in a confluence system error
org.springframework.transaction.UnexpectedRollbackException: Transaction rolled back because it has been marked as rollback-only
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:626)
Stack Trace: [hide]
     at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor$1.beforeResult(XWorkTransactionInterceptor.java:89)
     at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:181)
     at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35)
     at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165)
Peter
Adobe Employee ,
Mar 09, 2010 Mar 09, 2010
fds-2.6.1.swc
fds_rb-2.6.1.rb.swc
Those two I found under
cairngorm3/tags/Integration-0.2/libraries/Integration/libs/
they were synced from SVN:
