[svn:fx-trunk] 12635: Remove support for library://ns.adobe.com/flex/ halo namespace completely.
Dec 7, 2009 4:19 PM
Revision: 12635
Revision: 12635
Author: klin@adobe.com
Date: 2009-12-07 16:14:44 -0800 (Mon, 07 Dec 2009)
Log Message:
Remove support for library://ns.adobe.com/flex/halo namespace completely. Removed references in config files as well as other files that weren't previously updated.
QE notes: No
Doc notes: No
Bugs: SDK-24568
Reviewer: Pete
Tests run: checkintests
Is noteworthy for integration: Yes
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24568
Modified Paths:
flex/sdk/trunk/frameworks/air-config.xml
flex/sdk/trunk/frameworks/flex-config.xml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/ColorBurnShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/ColorDodgeShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/ColorShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/ExclusionShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/HueShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/LuminosityShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/SaturationShaderExample.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/ shaderClasses/examples/SoftLightShaderExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/ComboBoxExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components /examples/TabBarExample.mxml
flex/sdk/trunk/frameworks/projects/wireframe/defaults.css
flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.css
flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/GraphicsTag sTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/Ellip seBasic2.mxml
flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/RectB asic3.mxml
flex/sdk/trunk/frameworks/tests/basicTests/graphics/views/comps/TextG raphicBasic1.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/AccordionTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/AlertTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ButtonTests.mxm l
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/CheckBoxTests.m xml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/CollectionTests .mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ColorPickerTest s.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ComboBoxTests.m xml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/DateFieldTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/FTETextTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/FocusManagerTes ts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ImageTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ListAndDataGrid Tests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/MXItemRendererT ests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/MenuBarTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/MenuTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/NumericStepperT ests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/ProgressBarTest s.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/RPCDataBindingT ests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/RadioButtonTest s.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/SWFLoaderTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/SliderTests.mxm l
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TabNavigatorTes ts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TextAreaTests.m xml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TextInputTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TextTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/halo/views/TreeTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/BorderContaine rTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/ButtonBarTests .mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/ButtonTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/CheckBoxTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/ComboBoxTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/DeferredInstan tiationTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/DesignLayerTes ts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/DropDownListTe sts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/EasingTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/LayoutTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/ListDragDropTe sts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/NumericStepper Tests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/PanelControlBa rTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/RadioButtonTes ts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/ScrollBarTests .mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/SliderTests.mx ml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/StyleManagerMo duleTest.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/StyleManagerTe sts.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TextAreaTests. mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TextInputTests .mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TileGroupTests .mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/TitleWindowTes ts.mxml
flex/sdk/trunk/frameworks/tests/graphics/GraphicTags_checkin.mxml
flex/sdk/trunk/frameworks/tests/graphics/comps/EllipseBasic2.mxml
flex/sdk/trunk/frameworks/tests/graphics/comps/RectBasic3.mxml
flex/sdk/trunk/frameworks/tests/graphics/comps/TextGraphicBasic1.mxml
flex/sdk/trunk/frameworks/tests/layout/layout.mxml
flex/sdk/trunk/frameworks/tests/spark/sparkTest.mxml
flex/sdk/trunk/frameworks/tests/states/statefulAttributes.mxml
flex/sdk/trunk/frameworks/tests/states/statefulNodes.mxml
flex/sdk/trunk/frameworks/themes/Institutional/Institutional.css
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar. jj
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLName spaces.java
flex/sdk/trunk/samples/explorer/explorer.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ButtonBarFirstB uttonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ButtonBarLastBu ttonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ButtonBarMiddle ButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/CheckBoxSkin.mx ml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ComboBoxButtonS kin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ComboBoxSkin.mx ml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/DropDownListBut tonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/HScrollBarThumb Skin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/HScrollBarTrack Skin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/HSliderThumbSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/HSliderTrackSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/NumericStepperS kin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/RadioButtonSkin .mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ScrollBarDownBu ttonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ScrollBarLeftBu ttonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ScrollBarRightB uttonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ScrollBarUpButt onSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/SpinnerDecrButt onSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/SpinnerIncrButt onSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/TabBarButtonSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/ToggleButtonSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/VScrollBarThumb Skin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/VScrollBarTrack Skin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/VSliderThumbSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/VSliderTrackSki n.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/fu llScreen/VideoPlayerFullScreenButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/fu llScreen/VideoPlayerPlayPauseButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/fu llScreen/VideoPlayerVolumeBarMuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/fu llScreen/VideoPlayerVolumeBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/fu llScreen/VideoPlayerVolumeBarTrackSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/no rmal/VideoPlayerFullScreenButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/no rmal/VideoPlayerPlayPauseButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/no rmal/VideoPlayerVolumeBarMuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/no rmal/VideoPlayerVolumeBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/arcade/skins/mediaClasses/no rmal/VideoPlayerVolumeBarTrackSkin.mxml
flex/sdk/trunk/samples/themes/arcade/src/defaults.css
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/ButtonBarMiddle ButtonSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/DropDownListBut tonSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/NumericStepperS kin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/PanelSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/mediaClasses/fu llScreen/VideoPlayerFullScreenVolumeBarMuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/mediaClasses/no rmal/VideoPlayerVolumeBarMuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/mediaClasses/no rmal/VideoPlayerVolumeBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/cobalt/skins/mediaClasses/no rmal/VideoPlayerVolumeBarTrackSkin.mxml
flex/sdk/trunk/samples/themes/cobalt/src/defaults.css
flex/sdk/trunk/samples/themes/graphite/src/defaults.css
flex/sdk/trunk/samples/themes/spark_cobalt/spark_cobalt.css
flex/sdk/trunk/samples/themes/spark_desert/spark_desert.css
flex/sdk/trunk/samples/themes/spark_graphite/spark_graphite.css
flex/sdk/trunk/samples/themes/spark_sage/spark_sage.css
flex/sdk/trunk/samples/themes/spark_sky/spark_sky.css
flex/sdk/trunk/samples/themes/zen/src/defaults.css
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ApplicationSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ButtonBarFirstButtonS kin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ButtonBarLastButtonSk in.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ButtonBarMiddleButton Skin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ButtonBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/CheckBoxSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ComboBoxButtonSkin.mx ml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/DropDownListButtonSki n.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HScrollBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HScrollBarThumbSkin.m xml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HScrollBarTrackSkin.m xml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HSliderSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HSliderThumbSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/HSliderTrackSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ListSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/PanelSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/RadioButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ScrollBarDownButtonSk in.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ScrollBarLeftButtonSk in.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ScrollBarRightButtonS kin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ScrollBarUpButtonSkin .mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ScrollerSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/SpinnerDecrButtonSkin .mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/SpinnerIncrButtonSkin .mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/SpinnerSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/TabBarButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/TitleWindowCloseButto nSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/TitleWindowSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/ToggleButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VScrollBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VScrollBarThumbSkin.m xml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VScrollBarTrackSkin.m xml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VSliderSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VSliderThumbSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/VSliderTrackSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/FullScreenFullScreenButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/MuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/PlayPauseButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/ScrubBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/VolumeBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/VolumeBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/fullScre en/VolumeBarTrackSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/F ullScreenButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/P layPauseButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/S crubBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/S crubBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/S crubBarTrackSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/V olumeBarMuteButtonSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/V olumeBarSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/V olumeBarThumbSkin.mxml
flex/sdk/trunk/samples/themes/zen/src/zen/skins/mediaClasses/normal/V olumeBarTrackSkin.mxml
flex/sdk/trunk/webapps/webtier/WEB-INF/flex/flex-config.xml
