Unlocking Locked Layers
Dec 7, 2009 6:06 PM
I'm trying to unlock layers in a document through Javascript (CS3/4).
function clearAllLocks(doc){
    var layers=doc.layers;
    for(var i=0;i<layers.length;i++){
    if (layers[i].locked){
       layers[i].locked=false;
This function runs fine (no errors reported). Here's the problem: This does nothing. All subsequent operations on the layers result in a "layer cannot be modified" error. Is there something that I'm missing?
I've noticed the problem even if I manually unlock the layer. The only thing that works is to manually do the following:
a. unlock the layer
b. duplicate it
c. delete the old layer.
d. rename duplicate layer to the old one
Any help from the gurus will be highly appreciated.
A.
    Dec 7, 2009 10:36 PM   in reply to Anurag Mendhekar
    the following script does those steps(or it should do, as i dun have to test it now):
    how it works: select an item from the current document that's in the layer that you want to use as the original layer:
    var doc = app.activeDocument;
    clearAllLocks(doc);
    var sel = doc.selection;
    var layer = sel[0].parent;
    var lyrName = layer.name;
    var nL = layer.duplicate();
    nL.name = lyrName;
    layer.remove();
    hope it helps;
    cheers;
    Dec 8, 2009 2:31 AM   in reply to Anurag Mendhekar
    this should work with whatever you need ... since you weren't very precise about your problem i can only confirm that:
    - operations that are made on a locked or non visible layer cause errors on Windows machines and cause program crash on Mac machines(took me half an hour to figure out that lol)
    clearLayerOverrides(doc);
    function clearLayerOverrides(doc){
        if (!layers[i].visible){
           layers[i].visible=true;
    function moveItems(fromLayer, toLayer){
         for(j = fromLayer.pageItems.length - 1; j >= 0; j--) {
              fromLayer.pageItems[j].duplicate(toLayer);
    var nL = doc.layers.add();
    nL.name = lyrName;
    moveItems(layer,nL);
    layer.remove();
    hope it helps;
    cheers;
