Gary.Fleming
BAM ES2 Starting point
Dec 8, 2009 4:04 AM
I'm not 100% sure this is the right forum for this but I can't see a better fit...
I've got a BAM ES2 instance running, and a LiveCycle ES2 instance running on another server with a few deployed processes. How do I actually use the BAM to do any sort of monitoring or reporting on those deployed processes? The documentation explains some of the high-level concepts (cubes etc) but doesn't appear to provide any "how to" information.
I'm basically looking for a tutorial or documentation that will let me actually use the thing, as it's not particularly intuitive or obvious how you use your processes as input to the BAM.
Any starting point at all would be appreciated.
    Dec 8, 2009 7:05 AM   in reply to Gary.Fleming
    See the materials attached..
    Hope they will be useful to you.
    -Nith
    Dec 9, 2009 5:59 AM   in reply to Gary.Fleming
    The only thing you should have to do is check the "Auto Generate BAM Dasboards" checkbox in the properties of your process (under Configure/Advanced).
    That should automatically create a set of dashboards you can use from the dashboard interface.
    Jasmin
    Dec 9, 2009 6:24 AM   in reply to Gary.Fleming
    Right-click your process and select "Properties".
    See the attached screenshot.
    -Nith
    Dec 9, 2009 6:30 AM   in reply to Gary.Fleming
    Sorry, I'm using workbench ES (not ES2).
    As suggested by Jasmin, point to configure->Advanced option and then try.
    -Nith
    Dec 9, 2009 7:16 AM   in reply to Gary.Fleming
    Make sure to deploy your application  once the checkbox is checked.
    Jasmin
    Dec 9, 2009 9:02 AM   in reply to Gary.Fleming
    Then something might not be installed/configured properly.
    Any error in the server.log file.
    You don't see anything in the BAM dashboard interface?
    Jasmin
    Dec 9, 2009 10:15 AM   in reply to Gary.Fleming
    Is the process short lived or long lived?
    Paul
    Dec 9, 2009 10:36 AM   in reply to pguerett
    Good point. It has to be long- lived, otherwise there's no data saved in the database.
    Jasmin
    Dec 10, 2009 5:43 AM   in reply to Gary.Fleming
    What about chapter 6 of the installation guide located at http://help.adobe.com/en_US/livecycle/9.0/install_jboss.pdf?
    Jasmin
    Jun 24, 2010 8:04 AM   in reply to Jasmin Charbonneau
    Is there any posiible way that we can get form field values into BAM Reports
    Jun 24, 2010 8:08 AM   in reply to $Nith$
    I am trying to create a UDF for BAM ES2 and it requires cognosAPI.jar any idea were i can download this.
    I tried searching it in Adobe ES2 installables as specified in the documentations but did not find it
    Jun 24, 2010 10:17 AM   in reply to Dhanesh S
    IN ES2, we have this new BAM wizard that allows you to expose process variables in BAM dashboards.
    You can find more information under
    C:\Adobe\Adobe LiveCycle ES2\LiveCycle_ES_SDK\misc\Business_Activity_Monitoring\LavaActivitySu ite\BAMWizard\bam_wizard_guide.pdf.
    Jasmin
    Jun 24, 2010 11:08 AM   in reply to Jasmin Charbonneau
    Jasmine the value i require for my BAM report is not in individual process variables but its stored as xml (formdata) in database is there a way we can access this in BAM
    Jun 24, 2010 11:14 AM   in reply to Dhanesh S
    You could use a setValue and extract the data you want from the form data into process variables.
    Otherwise you would have to create your own dashboard using the BAM Workbench interface.
    Jasmin
    Jun 24, 2010 11:20 AM   in reply to Jasmin Charbonneau
    I have created my own dashboard but i guess we have to write UDF for extracting values from form data and there is no other options that adobe provides
    Jun 24, 2010 11:49 AM   in reply to Dhanesh S
    Like I said, your other option is to extract the data with LC in separate process variables.
    This gives you two advantages:
    1- You can use the BAM wizard to create some dashboards from you.
    2- It will create a separate column in the database for every variable it creates. That makes it easier for you to query the data from a custom dashboard.
    Jasmin
