Framemaker 8 not starting up in Windows 7 (64-bit)
Guest
Oct 18, 2009 Oct 18, 2009
Framemaker 8 installed without any warnings on a new machine (Lenovo X301) running Windows 7 64-bit. But, unfortunately the software does not run. After clicking the executable, I see a 32-bit Framemaker task running in the task manager, but nothing appears on the screen.
The pdf maker seems to work fine.
Any ideas?
Thx,
Boris
4.1K
Enthusiast ,
Did you try setting the FM exe compatibility settings to XP or Vista?
Guest
No, I haven't. How can I do this?
Boris
Guest
Oct 19, 2009 Oct 19, 2009
I figured this out now... The program runs fine in Win 2000 compatibility mode.
Boris
Nov 02, 2009 Nov 02, 2009
Could you share your solution with the forum
Guest
Sure.
Navigate with the file explorer to the directory in which the FrameMaker executable lives (usually C:\Program Files (x86)\Adobe\FrameMaker8). Right-click the executable file FrameMaker.exe and hit Properties. Click Compatibility, check "Run this program in compatibility mode for:" and select Windows 2000.
Hope this helps.
Dec 13, 2009 Dec 13, 2009
Interesting. I wonder why this is required. I've been using FM 8 and FM 9 on 64-bit Vista without compatibility settings. My Windows user has administrator rights on the local machine. Could that make a difference?
Guest
I have admin rigths on the machine where I observed the problem. The program worked only after setting the compatibility mode for me with Win 7.
Dec 14, 2009 Dec 14, 2009
Hmmm,
Frame 8 acts like it's running on Win7 (64) but it keeps crashing. I'll have to try the compatibility thing to see if that helps.
Dec 15, 2009 Dec 15, 2009
FM 8 used to crash a lot on my Vista machine. Things improved after installing every available patch. Don't know whether that helps on Windows 7 (or whether there are still new patches for FM 8) - it helped on Vista.
