Restarting a different applicaiton?
Dec 13, 2009 5:19 PM
hum. small question, I have 2 applications, one app ~administers~ the other. I can restart the admin application easily enough with onApplicationStart(); , but how can I restart the slave application???
-thanks
-sean
No answers?>?>?
can this even be done?
    Dec 14, 2009 2:14 PM   in reply to sean69
    <cfscript>
    applicationTracker = createObject("java","coldfusion.runtime.ApplicationScopeTracker");
    daapplication = applicationTracker.getApplicationScope("saidApplication");
    applicationTracker.cleanUp(daapplication);
    </cfscript>
    Dec 15, 2009 10:34 PM   in reply to sean69
    I assume the slave application is in a subdirectory of the admin application. I also assume the slave application's Application.cfc is within that subdirectory. All that is needed is for the admin to open any cfm page in the slave application.
    Dec 16, 2009 2:04 PM   in reply to sean69
    no - actually the slave is on a different domain altogether.
    it is possible that at some point it could be on a different server! [but not very likely]
    No problemo. You may use cfhttp to call a page in the slave application.
    Dec 17, 2009 11:12 AM   in reply to sean69
    An application restart is only relevant if you want to reset application variables in the admin application as well as in the slave application.However, you've so far mentioned no application-wide variables.
