Imported SWF background turns red (CP4)
Dec 16, 2009 Dec 16, 2009
Hey, guys.
I'm working on an e-learning project which requires me to embed an interactive swf file in my Captivate project.
It all works out fine except that the background of the swf turns red. I have tried a few things with the embedded swf in my attempts to make it work.
1. I placed a white box below all other elements. It did not work.
2. Turned the box into a movie clip. It did not work.
3. I noticed that the embedded image elements kept their backgrounds so I made a white png image and place it below all other elements. No change.
Please see the attached image. If anyone have any idea of what may cause this and how to solve the problem, please share!
Import export
5.7K
Guest
Hi there,
If the SWF background turns red when you just view the file in Flash Player then this might mean that the SWF is taking up too much memory. The other thing you could do is check in the source FLA file that using the Flash Timeline, you have hidden any layers that you don't want published and make sure that the Flash Publish settings option "Include hidden layers" has not been accidentally selected.
Let us know how you get on.
Best - Mark
<a href="http://macrofireball.blogspot.com/"><strong>Visit the macrofireball blog</strong></a>
Thanks for your reply!
I found the problem and it wasn't in the flash file at all. The red square was caused by a solid png image that was saved from Photoshop WITH transparency. When I saved it again without the transparency it looked like it was supposed to.
LOL! I would have to surmise that this situation was quite literally a "Red Herring"!
http://en.wikipedia.org/wiki/Red_herring
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Guest
Dec 17, 2009 Dec 17, 2009
Delighted to hear that you managed to squash this gremlin. 🙂
Best - Mark
I'm having the same issue but none of the solutions described here work.  My red screen appears at a specific point in the animation--when we show circles on specific parts of a piece of equipment.
Hi there
Does it begin by displaying some red blocks, then continue until the whole screen turns red and it remains that way? If so, you are likely seeing memory exhausted. Otherwise known as the "Red Screen Of Death". If that's the case, I'm guessing there is a lot of Full Motion Video clips?
Cheers... Rick
SorcerStone Blog
Captivate eBooks
Dec 18, 2009 Dec 18, 2009
No. That's not the behavior.
The animation plays fine to begin with. The animation show a piece of equipment. Then it zooms in and highlight parts of the equipment by showing some yellow outlines.  It is at this point that the jpg showing the equipment is replaced with the red background on top of which, we can see the yellow outlines.  Then as the animation progresses, the red background disappears. This behavior ONLY happens when the movie is inside Captivate. Have no idea of what's happening.
Guest
Dec 19, 2009 Dec 19, 2009
Hi there,
If this is happening when you view the published Captivate project file, then you might want to try publishing again but this time externalizing the animation. You can do this by selecting the option I have highlighed in the screen shot below.
If that does not solve the problem and you can spare the time, I would suggest that you report this bug to the Captivate team. You can do this by clicking on the Feature Request / Bug Report link which can be found in the Useful Links pod of the Adobe Captivate forum web page.
Best - Mark
Best - Mark
Dec 21, 2009 Dec 21, 2009
HI Mark, externalizing resources work. Hum..., what was the problem? I have not had to that before, only with this particular animation.
Anyway, it worked.
Have a great holiday.
Jan 04, 2010 Jan 04, 2010
I've seen this odd behavior before when taking Illustrator files with clipping masks and importing them into flash. All of a sudden there are red boxes everywhere. Using .PNG or .JPG didn't produce the same result.
Help resources
