A new Encore user's experience.
Dec 7, 2009 11:57 PM
Being as this is a louge this might be a place to share.
First, I am not a pro, but I have been using Premiere since 4.2 to produce simple teaching videos and over time have gotten to where I have done more fun stuff and even a couple of events, for money even.  Until recently I created my DVDs using Sony DVD Architech.
So all week I've been editing video from a race held near here recently (motorsports, 24 Hours of LeMons) where I attended with a team with the idea of getting photos and video and putting together something the team and friends would enjoy.  I got some good in-car video, and some not so good, but that's another matter.
For this project I decided to finally try using Encore to create the DVD.  The Sony software didn't do Blu-Ray and I wanted to try that, too.  So I start up Encore and when it finally loaded I started a project in the usual Adobe style then was presented with a screen I simply could not figure out.  I poked around trying to figure out what the basic procedure was and found the "import" function, tried to import and mgep file, and I got my first blue screen ever on this system.
Rebooted, and restarted Encore, I explored more on my own.  I can usually figure out these things on my own.  I explored the menus and buttons, and figured out that an asset was probably anything I wanted to put on the DVD.  Other than that I was pretty much stuck.  I imported another mpeg file and that worked, but I finally gave up and decided to try "Help".  That took me to the Adobe site, and that to the Lynda tutorials, which were just what I needed.  I went through them one-by-one and they answered most of my questions.  They were excellent.  Quick, clear, and just the right amount of detail for a tutorial.  Adobe did good with that one.
With Lynda's help I was off and running.  I figured out how to create menu templates by examining the ones that came with Encore and I figured out how to change the order and other settings for each button.  Everything was going smoothly now.  I had a project that had a menu and three videos.  The preview feature was also working great.  But, the highlight I used for my buttons is a green dot that has an inner shadow.  In preview I only get a green dot.  No shadow.  Later on the DVD itself, same thing.  I later learend by reading in these forums that that is the fault of the DVD player.
I still had room for one more button, and I still had lots of photos I had not used, so I tried the slide show feature.  It looked like it would a good job just showing photos, and for this project I thought it would be a nice little extra.  I know that some people here consider it to be a comsumer gimick and just seeing it in Encore made me think the same thing, as if Adobe wanted to be able to match the features of (much) lesser DVD authoring programs.  No matter.  I'd also learn, by experience that this feature still needs a little work.  Again, I am not a pro, so if I notice something that needs fixing it must really scream out at you guys and gals.
It was pretty easy to import my photos and add them to the slide show, but I soon learned that 99 photos is the max for a slide show.  I suppose that is OK.  Next, I learned that the shortest time I could display a slide is about 1.2 seconds.  I was hpoing to be able to run through some of my photos quickly to simuate a stop-action sequence for those times when I just held the shutter release button and snapped away at the action, such as a car spinning off into the dirt.  It could be that this limit is due to the cross-fade transitions I had set as the slide show's default transition.  I'll try it again later without transitions to see what happens.
Adding and removing slides turned out to be a real pain.  When addidng slides in mass I'd get an error saying there was something wrong with a slide.  I forget what the other errors were, but I got a lot of them.  They were probably related to the number of slides I was placing in the timeline, over 99 total.  But besides the errors, Encore really slowed down.  It took maybe 10-15 minutes for it to get back to normal, or just about how long it took me to give up and go off and fold laundry.  So then I tried to delete some slides and that took for ever, especially if the slide was near the beginning of the show.  I figure Encode must be reprocessing the whole show somehwow.  But after these problems something seemd to be wrong with Encore.  It was slow when doing anything.  I closed it and started it up again.  It was all better again.
In previews the slide show looked good, but I realized that I needed to resize the photos.  I did this in Photoshop for a handful then came back to Encore, expecting it to update itself, seeing as assets like these are external to the Encore project itself, but that didn't happen.  If I edited a video and came back to Premiere it would re-import the video.  Apparently this doesn't happen in the slide show.  I deleted the slide show and started again.  At least it is easy to set up new slide shows, except as noted above.
The do-over worked.  The slide show looked good.
I burned a DVD and the results were excellent, except for, again, the slide show.  The show ran OK, but at the end of each transition there was a little flicker, more like a contrast glitch.  Annoying, and it has to be fixed or else the slide show feature will be useless, even for me, except for personal use.
Other than that, all was good.  I edited video and Encore reimported it and the burn was successful and it looked great, well, on my analog TV.  I still don't have digital as I canceld cable and quit watching TV nearly 2 years ago.  But it was working, minor changes were easily handled, etc.
I then tried the Flash feature, and it worked well, except that the video frame is not centered (too far to the right).  The HTML code was simple enough.  The video plays in a table whose width is 99% of the screen the cell justification is centered.  I'm sure I could deal with that in my own pages.  But, a bigger problem, again involving the slide show.  The VCR controls would pop up at the start, or end, of each slide, and then would disappear again on its own.  Again, the slide show is a nice feature but I can't use it if the controls are going to be going up and down throughout the show.
I also exported an image and will be trying that out later.  Being able to create an image for the DVD is nice.  It means I won't have to use Encode for future burns, and I might have trouble keeping up with the 80 GB of files I have in this project.
Mike
    Dec 21, 2009 6:23 AM   in reply to KStreetStudio
    Thanks for reporting.
    I'm one of those folk, who shies away from SlideShow in En, choosing to do that in PrPro and then Exporting a DV-AVI.
    Though this is not a "technical" forum, I'll risk Jeff & Neil's wrath and throw out one comment. If your still images were not resized to your Project's Frame Size, say 720 x 480, PAR = 1.22 (for NTSC 16:9 in this example), you are asking the program to downsize all of your 99 stills. That WILL slow things to a crawl. Also, I feel that resizing in Photoshop, rather than En, or PrPro, will give you better results. This is a time, where bigger is not better. If you redo, or do a similar Project, explore resizing the stills in PS first, and then Importing those. This ARTICLE might give you some tips on automating the resizing, prior to Import.
    OK, enough of that technical drivel. Thanks again for sharing!
    Hunt
