Pedro Vareta
Right page only numbering
May 4, 2009 5:44 PM
Hi everyone,
My question is:
I want to automatically number my pages, but to always have both page numbers on the right page only (pgs 4-5 for example), leaving the left hand page blank.
Is there a way to do this?
Pedro
    May 4, 2009 5:52 PM   in reply to Pedro Vareta
    On the right master page, draw a text box where you want the page numbers and Type > Insert Special Character > Markers > Previous Page Number, then a hyphen, then Type > Insert Special Character > Markers > Current Page Number.
    Ken Benson
    May 4, 2009 6:06 PM   in reply to Kenneth Benson
    BUT... you have to thread that to an empty frame (except for possibly a frame break to force the text to the right page) on the previous page or the previous page marker won't work. This was covered a couple of weeks ago (but in reverse, I think) if you do a search.
    May 4, 2009 6:09 PM   in reply to Peter Spier
    Thanks, Peter, I didn't know that part.
    Ken Benson
    May 5, 2009 5:10 AM   in reply to Kenneth Benson
    The "next" and "previous" page markers are primarily used for jump lines in newspapers or magazines, and they work by reading the page number of the next or previous frame in a thread. Normally they are placed in a separate frame from the flowing text (so they won't move with it), but they'll work inline too. The only caveat is whatever frame they are in must touch the threaded frame from which you want to draw the reference, otherwise they just show the current page number.
    May 5, 2009 4:51 PM   in reply to Pedro Vareta
    Yeah, I can't make it work either. I can make it work on a live spread, but when I put the same threaded frames on the left and right master pages, it just shows the current page.
    Peter, have you seen this work? I never used previous or next page before (obviously, since I gave such simplistic advice first time around).
    Ken Benson
    May 5, 2009 5:12 PM   in reply to Kenneth Benson
    It's starting to come back to me now. You'll recall I said this had been discussed recently?
    It turns out that it only works if you override the master frame onto the live document page. You can put it onto the master for convenience, but you'll have to go through and override all the pages to make it work.
    It might be worth looking for that other thread. It's possible Dave or someone suggested a scripting solution, but I'm afraid I really don't recall. I think there was a reference to an InDesign Secrets article, though, and maybe there was a better technique in the comments.
    Peter
    May 5, 2009 5:22 PM   in reply to Peter Spier
    OK, here's the link to the ID Secrets article. http://indesignsecrets.com/previousnext-page-number-on-same-page.php
    One suggestion was to put a cross-spine frame on the master and use a current page marker, but we've had a couple of posts today about cross-spine master objects not printing or exporting to PDF correctly, soooooo....
    I'm afraid the only answer is to override. Does it make you feel any better that this is one of the things that USED TO WORK in CS3?
    May 5, 2009 5:33 PM   in reply to Peter Spier
    This particular kind of cross-spine frame isn't going to cause a problem; it was, for whatever reason, text in a frame on the right page on top of a cross-spine frame that was getting covered by the cross-spine frame that should have been underneath it.
    That said, I can't make this work with a cross-spine frame anyway.
    I like the idea in the article to anchor a current page number in a frame on the left page and then push the anchored frame over the spine to the right page.
    Ken Benson
    May 6, 2009 4:31 AM   in reply to Kenneth Benson
    I can't make ANY of them work without overriding the frame on the left page, but all work if you do.
    The secret to the cross-spine technique is there has to be more of the frame on the left page than on the right.
    I'm filing a bug on this.
    May 7, 2009 5:29 AM   in reply to Pedro Vareta
    You have to override the correct frame, which is the one on the left page, not the one on the right, if that helps.
  • John Hawkinson
    Jun 25, 2009
    Dec 22, 2009 10:42 PM   in reply to Pedro Vareta
    Bob Bringhurst posted about this on his blog in June, in Page Numbering on a Single Spread Page. His solution requires a manual override on every page where you'd want to do this (which could be a lot).
    I wrote a quick script that does all the overriding for you.
    It walks each master spread and finds all the text frames with current (auto)/prev/next page number markers, and then walks all the pages that master spread is applied to and overrides each of those text frames.
    Unfortunately it appears that the textFrame.override() method somehow breaks story/text Frame threading (is this a bug?). So the script has to workaround it. I do so with labels, by assigning a label to each master page textFrame that needs to be overriden, and then finding those overriden labels on each document spread and re-establishing the threading that existed between the same labels on the master page.
    This script doesn't do anything clever if you have a spread with 1 or 3+ pages, so you'd have to deal with such cases by hand. It also removes any existing labeled overrides before it runs, which I guess might not be desirable in some cases, in which case you could comment out section (3.).
    If anyone wants to do this (I'm not sure why…), enjoy:
    // John Hawkinson <jhawk@mit.edu>
    // For each master spread:
    // 1. Find textFrames on the master spreads with threaded next/prev story frame, label them
    // 2. Find the set of spreads with the master applied
    // 3. Remove existing overrides
    // 4. Override the item on all such pages.
    // 5. Restablish threading for labeled items on such pages
    var debug = 0;
    var d = app.activeDocument;
    for (n=0; n<d.masterSpreads.count(); n++) {
         var ms = d.masterSpreads[n];
         if (debug)
           $.writeln("Processing master spread " + ms.name);
         var tfTodo = new Array();
         var labels = 0;
         for (m=0; m< ms.textFrames.length; m++) {
              var tf = ms.textFrames[m];
              if (tf.parentStory.textContainers.length > 1)
                for (l=0; l<tf.parentStory.characters.length; l++) {
                  if (tf.parentStory.characters[l].contents==SpecialCharacters.AUTO_PAGE_NUMBER ||
                  tf.parentStory.characters[l].contents==SpecialCharacters.NEXT_PAGE_NUMBER ||
                  tf.parentStory.characters[l].contents==SpecialCharacters.PREVIOUS_PAGE_NUMBER) {
                     tfTodo.push(tf);
                     tf.label="MP"+(++labels);
                     break;
              } // for … tf.parentStory.characters
         } // for … ms.textFrames
         for (m=0; m<d.spreads.length; m++) {
              var ds =d.spreads[m];
              if (ds.pages.length==2 &&  // Don't mess with single-page or 3+ page spreads
                  ds.appliedMaster && ds.appliedMaster.id==ms.id) {
                if (debug)
                  $.writeln("  Document spread "+m+" ("+
                     ds.pages.everyItem().name+") has this master");
                for (l=1; l<=labels; l++) { //  1-indexed
                   try { ds.pageItems.itemByName("MP"+l).removeOverride(); }
                   catch (e) { if (e!="ReferenceError: Object is invalid") throw(e); }
                for (l=0; l<tfTodo.length; l++)
                     if (tfTodo[l].parent.side == PageSideOptions.LEFT_HAND)
                        tfTodo[l].override(ds.pages[0]);
                     else
                        tfTodo[l].override(ds.pages[1]);
                // Unfortunately threading is not preserved by the textFrame.override() method
                var masterNext;
                for (l=1; l<=labels; l++) //  1-indexed
                        if ((masterNext=ms.pageItems.itemByName("MP"+l).nextTextFrame) != null)
                          ds.pageItems.itemByName("MP"+l).nextTextFrame =
                            ds.pageItems.itemByName(masterNext.label);
            } // if … ds.appliedMaster.id
         } // for … d.spreads
    } // for … d.masterSpreads
    exit;
    Jan 29, 2010 11:22 PM   in reply to Pedro Vareta
    I have an alternative to set the page-numbering for spread page correctly.
    1. Create Master pages 'A', and insert current page number on the right page.
    2. Create another master pages 'B', and create an very wide text box, which started from the bleed area of the left page and across the spine. Please refer my attached pictures.
    3. When add pages to your contents, you just need to apply Master page 'B' to all the 'left' pages and Master page 'A' to the 'right' pages. You don't need to activate the page number from the master page.
