Today I change Template - Update all files based on the template - synchronize entire site.
What I Like to do: change Template - Update all files based on the template
and then in the same window button with ftp upload changed files!
Why do I want this:
Do we have solution for this today?
Or can this be something to suggest for next version?
Thanks for any suggestion
Not sure if there is anything set up in DW yet, it does give a status window of what files were updated, you could possibly work backwards form that list (still a bit cumbersome). I also believe that if you change the template and upload it to your server, it will prompt you as to whether or not you'd like to "include dependant files", and (in theory) it will also upload the files linked associated with it... but that may need to be tested to see how well it works on a larger site.
As a possible alternative, you could use "Server Side Includes" - which is a single file which contains a portion of your page (the top navigation, footer area, etc.), and any page that uses this element will automatically update when you upload just that one element. Here is a link which explains it better: http://www.smartwebby.com/web_site_design/server_side_includes.asp and there are several others on the web that offer more detailed explainations - one caveat is that the web server you use would need to be set up to accept SSI... most do, but something you'd need to look into beforehand...
Hope that helps,
Jesse
The solution is to make a ftp queue file for FileZilla based on the logfile from the template changes.
Check out my php script for Dreamweaver logfiles. It creates FileZilla XML queue files ![]()
http://flashdictionary.filomatic.de/php/php_xml/xml_example_03.php
