Hi, I've been trying to encode an .avi file (edited in and exported from PPr1). It's 1024x576, square pixels, and in the Encore preview box (under "outcome" tab), just before transcoding, it looks fine but when transcoding is done, the video is cropped on the sides.
Could you tell me what I should do please? thanks in advance
I'm having the same problem, I think. I'm working on an Encore CS4 DVD project and I imported an AVI file with 1050x576 resolution, with a square pixel aspect ratio (PAR). This video is used on a motion menu.
For some reason I'm still to figure out why, when Encore transcodes this video, instead of resizing it to 720x576 with the PAL Widescreen PAR (1,46), it crops the video on both sides and leaves it with a 4:3 aspect ratio.
What am I doing wrong?
The video was created on After Effects. In order to solve this problem I created a new compostion on AE with a 720x576 resolution and with a PAR for a widescreen aspect ratio. I placed the original composition (which has a 1050x576 resolution, square pixel) and rendered the new composition to an AVI file. This way it worked correctly.
Nonetheless I would expect that Encore could understand that a 1050x576 video, square pixel, was a PAL widescreen video and shouldn't simply trim it on the sides.
