c.semler
How to install DW 8 Patchpackage.msp for Windows 7?
Dec 25, 2009 9:45 AM
I have DW 8 which ran great on Vista Home Premium. I have upgraded to Windows 7 and have many issues with DW 8.
I would like to install the 8.02 patch, but it will not install via usual method. I then downloaded Patchpackage.msp and have attempted to install it via the Command Prompt. As I am not familiar with this maneuver, I need some help to accomplish this. Can anyone offer any assistance in this matter?
Thank you in advance,
Clyde Semler
    Community Member
    Dec 28, 2009 9:15 AM
    Here is a good discussion from someone who asked the same thing in the Microsoft forums:
    http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/d96 82642-25ec-4858-aee8-2abf123aaa08
    Community Member
    Dec 28, 2009 1:29 PM
    You need to be running Win7 as an Administrator.  Did you right click on CMD?  Choose Administrator?
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    www.alt-web.com/
    www.twitter.com/altweb
    www.alt-web.blogspot.com
    Community Member
    Dec 28, 2009 2:05 PM
    That's correct.  It means you need to navigate in the command prompt to where the file is located.  I believe it is still the same old "cd" command to change the directory to where the file is located.  Otherwise, you can just substitute the "patchpackage.msp" text with the full path to your file ie: C:/Users/Username/User Documents/...etc./patchpackage.msp.
    Community Member
    Dec 28, 2009 2:10 PM
    From MS Web site:
    Here’s a trick to install 8.02 patch of Dreamweaver on Windows 7 machine.
    1.     Download the file from the link below.
    http://www.adobe.com/support/dreamweaver/ts/documents/kb400150/DW802_u nwrapped.zip
    2.      Unzip the installer to a folder which can be easily located.
    3.     Now run a command prompt in elevated mode.
    To do so,
    a)      Go to start and type cmd in the search field.
    b)      Right click on cmd from the list and choose run as Administrator.
    4.     Navigate to the saved folder where patchpackage.msp file is located and type in the following.
    msiexec /update patchpackage.msp
    5.     Press Enter.
    6.     The patch will begin to install.
    By now you should have successfully installed
    8.02 patch.
    Make sure you UNZIP the installer file and Save it to an easily accessed folder on your hard drive such as MYDOWNLOADS or whatever folder you typically use.  If you're unable to save or access the file, you need to log-off and log-on as Administrator.
    Browse to the file and type the command string exactly as shown above.  It should work.
    Nancy O.
    www.alt-web.com/
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
