After spending over an hour with tech support, the second level technician confirmed that there are currently some incompatibilities with PSE 8 when interacting with other programs inside of Windows 7. Specifically, I have identified (and Adobe confirmed) that neither the Photo Mail nor the Ceiva functions will work correctly. Others (such as mail attachment) do work. All apparently work with Vista and other OSs.
I was told that there are certain bridging files that existed in Windows Vista (and XP) that no longer exist in Windows 7. Adobe is aware of the problem and working on a patch. It's not clear to me why they didn't post this information (and any other known bugs) in the Knowledgebase...but I hope this saves others some time with tech support.
Adobe did not give me any commitment for when the fix will be available.
-bs
What exactly was your problem or error? I'm using PSE 8 with 64-bit Windows 7 and have use Photo Mail in conjunction with Outlook without a problem. I just tried again, and everything worked fine.
I have not tried Adobe Email Service with Win 7 yet. Is that where the problem occurs?
Don S.
PSE8 crashes every single time that I attempt to do a Photo E-mail (from the sharing window). The crash occurs in the step following selection of the addressees (where you would normally select the kind of frame, pictures per page, etc). The problem was reproduced using a fresh install, using a fresh catalog (with only a handful of pictures) and using a new user account with nothing else running on the computer (msconfig cleaned out). Adobe tech support was online (screen sharing) during the troubleshooting. The first level technician was unaware of the bug...but as soon as he escalated it to the next level, he was told to simply stop troubleshooting because it was a known issue with a known resolution that would presumably be fixed.
As for Ceiva, PSE8 simply will never fully connect with the system...thus preventing the ability to send to the Ceiva system. Again, tech support confirmed the bug (this time more quickly fortunately).
-Bruce
Bruce,
Have you tried running PSE 8 as an administrator? In an earlier version, I had trouble emailing from within PSE and running it as an administrator (right clicking on the program link) bypassed the problem. Whatever is is causing your problem apparently does not affect all Win 7 installations, since I am not seeing the same problem - thank goodness.
Good luck.
Very interesting. I DID get photo mail to work when I did the right-click administrator procedure. It did NOT work when I
created a new adminstrator level user though. I'm not sure what the difference is in how Windows 7 handles these.
This did NOT, however, solve the CEIVA problem.
Thanks for the idea. At least I'm more functional now.
-Bruce
On Vista and Windows 7, running a program by right-clicking and selecting Run As Administrator is different than running in an account that is a member of the Administrators group. A program doesn't actually acquire administrator priviliges until it explicitly asks to run as administrator (prompting you) or until you invoke Run As Administrator.
The installation of PSE is buggy and doesn't always check to make sure that it has the proper access priviliges to all the folders it needs. PSE itself is buggy in that it doesn't properly report many error conditions (such as not being able to write a folder). So running it as administrator gives it those priviliges.
Adobe tech support isn't very competent and often gives out wrong information.
Did you try running PSE 8 as an Administrator by right-clicking on its icon? That might help. I don't think the pop-up re. Photoshop.com is related to your problem. FWIW I had some trouble myself yesterday. I have not sorted it out yet, but did get it to work again. Maybe there was a problem at Adobe causing the problem?
Don S.
I tried running PSE 8 as administrator. Still does not work. Photomail
hangs up at point where email form should appear. All worked fine until two
days ago when the Photoshop.com popup appeared. After that, contacts files
were erased and photomail or attachments ceased to work. I have checked all
settings and find nothing wrong.
I cannot get PSE8 to connect to Ceiva either. I completely reinstalled windows and installed PSE8 as the first thing to insure no other conflicts and it still won't show me Ceiva frames that are on my account. I called Adobe help and was told that Adobe doesn't support Ceiva and that maybe my trial period is over. But they are full of sh*t because it says that it supports Ceiva frames right on the box and it is not a trial service. When I talked to Ceiva they said to talk to Adobe as it is their product that is not working. Anybody know of a fix yet? I'm using Vista.
Dear ceivauser-
Please post here http://forums.ceiva.com/forums/show/23.page and we'll get it figured it out. Make sure to include your username so that it can be investigated.
ceivajoe
